02-09-2009, 04:26 PM | #1 |
| bench top press brake?
just wondering if anyone has found a small bench top press brake or a decent home made one that you could share a few pics of? I've been looking for something, but I can't find something that will work for me. |
02-10-2009, 12:00 PM | #2 |
02-10-2009, 06:56 PM | #3 | |
| Quote: Thanks, but that's not the kind I'm looking for. Harbor freight sells those, too. I'm looking for something like this, but in a bench top version, maybe 5 tons of pressure at the most. | |
02-10-2009, 07:48 PM | #4 |
Quarry Creeper Join Date: Apr 2007 Location: St. Louis
I remember seeing somewhere a brake, shear and roller as a benchtop unit. Now if I could remember.
02-10-2009, 09:20 PM | #5 |
Quarry Creeper Join Date: Dec 2008 Location: fairfield
i might have to head harbor freight this week and pick up a brake
02-11-2009, 12:30 AM | #6 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
Only small ones I've ever seen http://www.harborfreight.com/cpi/cta...emnumber=90757 http://www.micromark.com/MINIATURE-S...RAKE,8395.html |
02-11-2009, 02:38 PM | #7 | |
http://www.use-enco.com/CGI/INSRIT?P...&PARTPG=INLMK3 | |
02-11-2009, 06:19 PM | #8 |
If you are looking for just a brake, you might want to consider a box/pan brake. They have removable fingers that will allow you to bend boxes. As you bend sides you need clearance for the adjoining sides, that's where the fingers come in handy. Yes they cost more but are worth it in the end.
02-11-2009, 06:29 PM | #9 | |
hmm, these are closer to what I had in mind, I just think that .125 aluminum might be too thick for these to handle for bending on the brake. | |
02-12-2009, 07:38 AM | #10 | |
02-12-2009, 07:54 AM | #11 |
I saw this awhile back, and plan to make something similar for our 12 ton floor press at work. It's not what you are looking for, but I think it's closer than my other failed attempts. http://www.shopoutfitters.com/Univer...handybend.html |
02-12-2009, 05:39 PM | #12 | |
I kind of like that ENCO, but it says it's only for 20 gauge material, which is about 1mm thick. 1/8" is about 3mm thick, so I'm not sure it could handle the material that I need to work with. Last edited by BigSki; 02-12-2009 at 05:43 PM. | |
02-12-2009, 09:09 PM | #13 |
Rock Crawler Join Date: May 2008 Location: Mansfield, PA
You can make a press brake that will bend about anything, very easily and cheap. All you need is a small hydraulic "bottle jack type" shop/bearing press. Then all you need to do is make or buy a small bottom v-block and top v-punch. I've made all sorts of homemade dies/punches over the years for our shop press, I usually just make them out of angle iron. You also may be able to buy some used short sections of v-block dies and top v-punches at your local fab shop or at an equipment auction for a few bucks. We use our homemade press brake for 1:1 size fabrication and with the dies I have for our press i can bend anything from 28gauge sheet metal to 1" thick steel plate Ours is a 50 ton press but the same thing can be done with a MUCH SMALLER press for RC scale stuff Sorry no pics right now, but here is a link to the type/style of press i am talking about: http://www.nationalwholesaletools.co...shoppress.aspx |
02-13-2009, 07:59 AM | #14 |
I'm curious about how thick that 3 in 1 tool can bend as well. I'm going to stop by Toybuilder's place this weekend with some 1/8th aluminum to try it out. I'll take some pictures. Another one I stumbled on this morning is this one.....it says it can do 1/8th inch thick steel or aluminum at 6" wide: http://www.lowbucktools.com/platebrake.html |
02-13-2009, 08:38 AM | #15 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
The HF and Micro-mark units come with dies, are these for bending a radius?
02-13-2009, 05:22 PM | #16 |
I saw another promising mini press brake in the northern supply catalog today, only to read the fine print and find out it can only bend 40 gauge, which is about 1mm thick. Maybe I need to find a supplier/manufacturer of the small size dies and rig up something that would replace the jaws in my vice and turn that into a mini press brake. |
02-18-2009, 09:49 PM | #17 | |
02-19-2009, 09:17 AM | #18 | |
http://www.amazon.com/Grizzly-H3243-.../dp/B0000DD4UU | |
02-19-2009, 12:03 PM | #19 | |
02-19-2009, 03:24 PM | #20 |
| Wow, nice looking bend for a vice tool and 1/8" material.
