Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: .023 flux core wire?
Old 07-24-2009, 02:54 PM   #1
Default .023 flux core wire?
Does it exist? If so where are you getting it from? Local welding supply said they couldn't get it that small.
Thanks in advance.
2brokefor1:1 is offline   Reply With Quote
Old 07-24-2009, 03:00 PM   #2
dkf
Smallest I saw was .030" in flux core. Flux core sucks anyway. Your 100% better off using .023"-.025" solid wire and using the appropriate shielding gas. Weld quality and arc control is tons better.
dkf is offline   Reply With Quote
Old 07-24-2009, 04:26 PM   #3
Yeah, too bad my welder doest accept gas :(
Old 08-12-2009, 06:05 PM   #4
030 is the smallest flux core availabe. you can buy a seperate atachment to run gas instaed of buying a wole new mahcine. or maybe contact the manufa. for a update package
limpy88 is offline   Reply With Quote
Old 08-12-2009, 08:39 PM   #5
my whole truggy was flux core welded, how come it sucks so bad???:-(
ozpall is offline   Reply With Quote
Old 08-12-2009, 09:52 PM   #6
Hopefully you didn't use .030 flux core, because it would then most definitely suck ;)
Old 08-13-2009, 12:00 AM   #7
i didn't but even if i had, the truck takes a beating and still holds up, so what part of it sucks so bad? don't get me wrong, i can see the difference when welding with a 220 welder but the flux core still doable. i never welded any rc stuff so maybe rc stuff requires a better welder 185 or higher????
