02-28-2010, 02:28 AM | #41 | |
RCC Addict Join Date: Jan 2007 Location: San Jose
02-28-2010, 04:15 AM | #42 | |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
I havent tried to see what is the smallest radius I can cut,I know I can do a 2" circle, but scrolls can do the width of a blade Last edited by Joat; 02-28-2010 at 01:16 PM. | |
02-28-2010, 07:05 AM | #43 |
Newbie Join Date: Feb 2010 Location: mine run
I agree with joat it in what you need |
03-01-2010, 03:04 PM | #44 | |
03-01-2010, 04:24 PM | #45 |
| I think you should be fine, you may need to do some hand clean up, but should be able to do fine with a bandsaw for the most part, scroll saws are just not designed for agressive work
03-02-2010, 01:33 AM | #46 |
| okay. that is good to know. I was starting to think about the width of the blade and thinkin band saw might not work. I guess i am going to pull the trigger on one on craigslist.
03-03-2010, 01:44 AM | #47 |
Pebble Pounder Join Date: Aug 2009 Location: Glenwood Springs
buying the band saw tomorrow. cant find metal cutting blades for the scroll saw anywhere. Works great on the Delrin and wood, but im sure it sucks on metal.
03-03-2010, 10:40 PM | #48 |
band saw is so easy to use and very smooth. highly recommended!
03-04-2010, 01:44 AM | #49 |
you guys think this will work out fine? ryobi from depot? http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 |
03-04-2010, 06:51 AM | #50 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
With my experience with Ryobi stuff, I wouldn't trust it to cut a straight line to save my life. I'm planning on holding out/saving up for one of those Proxxon saws. I just need more room in my garage first!! |
03-04-2010, 07:32 AM | #51 | |
Do it! | |
03-05-2010, 02:29 AM | #52 |
03-05-2010, 07:06 AM | #53 |
03-05-2010, 07:13 AM | #54 |
03-05-2010, 08:02 AM | #55 |
Rock Crawler Join Date: Jan 2006 Location: Vacaville, CA
i cut 1/4 aluminum with mine. just takes time and some burnt fingers i would stay away from trying to cut any steel, i could see that taking forever. |
03-05-2010, 09:12 AM | #56 |
Quarry Creeper Join Date: Feb 2010 Location: Farmington
| Also if your military or prior military you get a discount at any Lowes store in the country. You just have to remember to ask for it. It's like 15 or 20% off. If your not military just find an old salt dog that would be willing to buy it for you.
03-05-2010, 09:18 AM | #57 |
03-05-2010, 09:36 AM | #58 |
Hmm... That's my concern. I would imagine it would cut 16 gauge sheet steel reasonably well and that'd be great for the bulk of my RC projects, but I'd like it to handle the occasional 1:1 project, too, and that would require cutting 1/4" steel usually. Were you cutting dry or did you use any wax or cutting fluid? |
03-05-2010, 09:43 AM | #59 | |
1/4" you'll be fine with. I don't use any wax or cutting fluid. Like I said I found if I heat the metal with a propane torch then cut on it it works just fine, and goes a little quicker. I guess I could try some cutting fluid this weekend on one of my projects and let you know if it's any better. Quote:
03-05-2010, 10:26 AM | #60 |
Thanks! I appreciate the info... I've been searching local ads and was wondering if anyone is familiar with Jet or Kity brand band saws? They appear to sell for some pretty decent money so I am assuming they may be high end, but I've never heard of either. I'm mainly concerned about parts/blade availability. The ones I'm looking at are 12" and 14". Thanks, Tommy |
