03-05-2010, 10:42 AM | #61 |
Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
With the right blade you can cut anything, I can cut right thru 1/4 steel no problem, the water cutting feature on the proxxon makes as world of difference, it helps keep the blade cool, clears the chips,keeps material cool for easy handling and since it helps clear the chips cuts about 15% quicker then if I dont use the coolant. One thing the prooxn has is constant speed to a point as the blade starts to bog down the motor will adjust and pick up the rpm to match the setting. |
03-05-2010, 12:08 PM | #62 |
I wanna be Dave Join Date: Aug 2008 Location: Austin, TX, USA
Joat, I think Proxxon should pay you a commission. You may have single-handedly sold me on their bandsaw. ;) So tell me this.... For the money I would spend on a Proxxon I could get a used floor standing commercial grade saw. My biggest concerns with that are (1) floor space and (2) the likelihood that the larger saw may require blades that are also large and not allow tight cutting radii. So basically, if the Proxxon can cut 1/4" steel and occasionally cut 3/8" steel, then I think I may be sold on it. You seem to think this would be no problem, particularly with the cooling setup, right? Oh, do you have any pics of your cooling setup on your Proxxon? I'd like to see it. Thanks again, Tommy |
03-05-2010, 12:20 PM | #63 |
I just read a review on Amazon for the Proxxon and it doesn't have a fence. Is this true? That could make long, straight cuts a challenge for sure.
03-05-2010, 01:02 PM | #64 | |
Last as for commision ,you would think so yeah, but I just really hate people wasting time and money, the proxxon is a very very good saw and though the price is high , it's well worth it, you may want to check this link for a more real person perspective. http://www.thms.tedatum.com/ and on the upper left theres workshop, scroll till you see proxxon micro bandsaw mbs/e | |
03-05-2010, 01:05 PM | #65 |
| Yeah that was one suckazz thing,I asked proxxon if any of the fences they have for the other tools would fit, they told me to buy one and find out?and that they did not have one made specific for the bandsaw, I did make a fence, actually 2, the first one was soso, the second was much better, just scrap material and a 1/4 handle, I will get some pics up tonite if I have time.
03-05-2010, 08:51 PM | #66 |
RCC Addict Join Date: Jan 2007 Location: San Jose
| Porta band saw
What you guys think about this. works both for scale stuff and full size if you are into this. I build full size so this would work great. buy the portable saw. http://www.labsafety.com/Milwaukee-V...19/?CID=9PP001 buy a table for it. http://www.pirate4x4.com/forum/showt...ortaband+table |
03-05-2010, 08:53 PM | #67 |
| how well did either cut? i know most of these are for would only, due to motor not being strong enough to cut or ending up stalling out. ???
03-05-2010, 08:57 PM | #68 | |
Mine cuts fine. I've got a couple blades for wood/plastic and another for metal. I don't have any need to cut anything heavier than 1/8" aluminum, so I can't tell you how it does on the heavy stuff. | |
03-05-2010, 09:44 PM | #69 | |
03-06-2010, 01:17 AM | #70 | |
03-06-2010, 01:30 AM | #71 | |
Oh and on that setup , since the blade is in a certain orientation you cant do long cuts past the throat, even if you made a fence, you would need to constantly trim the material off to keep it from hitting the bandsaw, at that point I would just use my 5x6 or my proxxon. Jet 5x6 or a harborfreight 4x6 under $250 Kinda large but it is portable - on wheels No tables the stock tables are totally use less way to much flex No fence , can make one but need to redo the table first 1/4 stainless plate is the best aluminum is too soft Variable tooth bi metal blades readly aval -popular size Can do hydralic downfeed conversions Can do wet cutting conversions Last edited by Joat; 03-06-2010 at 01:38 AM. | |
03-06-2010, 01:47 AM | #72 |
Rock Stacker Join Date: Oct 2009 Location: Arlington
The milwakie porta band is awesome. It cuts fkn everything. Only problem is that its limited to like a 5 inch cut or something. I used it with my iron casting buddies to make our Iron Church: That lil porta band cut everything from rusty plate steel to uber old cast and wrout Iron. See the old wagon wheels the porta band cut through a square 4x4 inch forged iron axle that joined a couple of em toghether. Key is to keep a block of wax with you and cool the part if it gets hot. Heres another photo for good mesure: |
03-06-2010, 02:13 AM | #73 | |
03-06-2010, 09:50 AM | #74 |
03-06-2010, 03:57 PM | #75 | |
diy silicone blade wiper metal insert, plastic one was not up to my taste quick change cover handles top and lower, you can also see the fence I made,and the extension I made for the inside of the table Coolant setup pump, this pump is more then strong enough, I have it dailed back to keep the coolant from going all over the place Another view of the table, with fence,extension and metal insert | |
03-06-2010, 04:44 PM | #76 |
great info! I thought the porta band would be great idea since I would be doing scale and 1:1 too. changing table and moving around with porta band seems cumbersome though. My main concern, and please comment...., is the width of blade on portaband (1.2") or blade on prox to cut contours or corners without constant trimming......., thought? I am still wondering what to buy, even though I found cheap high quality 6230 milwaulkee porta band for 120. |
03-06-2010, 07:03 PM | #77 |
03-06-2010, 08:50 PM | #78 | |
But I have had to do constant trimming but, with the proxxon it really is effort less, I 'll try to find some material and try to do so distance cuts and see how long it takes for a given distance,but I wont be able to do that for awhile, I gotta find scrap material first, I know when I cut .040 stainless it was like cutting nothing, no bog nothing just pushed the material thru like a hot knife thru butter, that was 18" of stainless,was actual faster on the proxxon then the jet 5x6 just because of the coolant,both saws run a bimetal 14/18 varitooth blade. | |
03-06-2010, 08:54 PM | #79 |
You may want to look at the stout X band, it's cordless, but nicad , has a table option, but the throat is kinda small and I dont know about blades http://www.youtube.com/watch?v=hYpbESyqAPo http://www.stouttool.com/ |
03-07-2010, 01:21 PM | #80 |
Joat, Thanks again for all the info. and helpful pics! My only concern with the Proxxon at this point is the fact that the center block near the blade is recessed for some unknown reason and will require a block like you made if small pieces are to be cut. It will also need a fence of some sort. Not really a huge deal, but for that kind of coin, I would expect these features...at least as options. I realize this isn't a band saw question, but it's related. Last night I picked up a combo disc/belt sander from Lowe's. It's a Porter Cable unit with an 8" disc and 4" wide belt. Looks like a decent unit and got better reviews than the cheaper Skil unit ($180 vs. $115). Here's a pic: Any have any experience with it or a comparable unit? I plan on mainly using it for finishing work after cutting steel and aluminum bits. |
