07-07-2010, 06:59 PM | #1 |
Pebble Pounder Join Date: Sep 2008 Location: Red Deer,Alberta
| Carbon Fiber Question
Hey there crawlerino's! I have seen alot of progects using carbon fiber and wouldn't mind starting a couple myself. All the other progects i have seen involve carbon fiber plates(chassis, servo mounts and such) yet I have not seen the stuff threaded or tapped. So the question remains.... can carbon fiber be tapped or threaded?
07-07-2010, 07:35 PM | #2 |
Quarry Creeper Join Date: Oct 2008 Location: Oakley
Drilled and tapped, yes Threaded (like bar stock) don't know Chuck |
07-07-2010, 08:38 PM | #3 |
07-07-2010, 10:11 PM | #4 |
Quarry Creeper Join Date: Apr 2008 Location: Garden Grove
| The CF rod
You can tap the rod but it is not strong enough for any side loads. The stuff is stiff but it shatters and will split if it gets hit hard. It may work fine with a much larger dia. rod. Sheets can be drilled and tapped but it also needs reinforcement , like a panel nut or blind nut. Good luck.
07-09-2010, 03:36 PM | #5 |
thanks motorman. The rod won't be seeing any side load. It's for chassis reinforcement on my micro dt. I was thinking maybe I should put a clamp on the rod when I tap it just in case it wants to split. Anyway, thanks for the input guys!
07-09-2010, 05:02 PM | #6 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
I have seen people take arrow shafts, since they are hollow, and stick threaded rod in them. That way you get the "looks..." of CF but no worries about threads pulling out. CF seems sortof harsh sounding on taps |
07-10-2010, 11:35 PM | #7 |
Rock Crawler Join Date: Apr 2007 Location: Denverish
| CF links are generally made by gluing aluminum inserts into the rod. They're threaded for 8/32 all-thread. Running all thread through the entire tube would be really heavy.
07-11-2010, 09:22 AM | #8 |
Pebble Pounder Join Date: Dec 2008 Location: Alberta Canada
Any taping of carbon rod usually involves gluing a aluminum band (sleeve)around the outside diamater of the rod to prevent spliting.And after the rod is taped the threaded insert is glued into the rod.This proves to be very strong. |
07-16-2010, 08:24 PM | #9 |
Rock Crawler Join Date: Oct 2009 Location: SO CAL
I would just glue set screws into CF arrow rod/ tube.
07-16-2010, 08:39 PM | #10 |
Newbie Join Date: Nov 2009 Location: Huntsville
It depends on the type of CF tube. Arrow shaft is mostly spiral wrapped and is less likely to split. Most of the CF tubes at the LHS are unidirectional, meaning all the fibers run the length and are guarenteed to split.
