Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Removing ThreadLock
Old 08-31-2010, 10:35 AM   #1
Default Removing ThreadLock
Is there an easy way to remove threadlock from screws and nuts? I don't mean get the screw out of the nut - get the gunked up threadlock off the parts after they are apart.
rctoyguy is offline   Reply With Quote
Old 08-31-2010, 11:21 AM   #2
I wouldn't worry about getting it out of the nut as much. Personally I leave it in there because it still works a little when it's gunked up like that. As for getting buildup or excess off a bolt, try using a wire brush. If you're intent on getting it out of the nut and it's big enough, maybe a pipe cleaner and some solvent? It'd be hard to do with some of the smaller hardware we tend to use on crawlers though.
HomerJ is offline   Reply With Quote
Old 08-31-2010, 11:30 AM   #3
I just thread the bolt all the way into the nut. This removes all the dried up stuff.
kennyj is offline   Reply With Quote
Old 08-31-2010, 11:47 AM   #4
heat usually melts it away... Either a heat gun or use yer soldering iron
dickwart is offline   Reply With Quote
Old 08-31-2010, 12:26 PM   #5
Heat it up and hit it with a wire brush.
Flip is offline   Reply With Quote
Old 08-31-2010, 09:56 PM   #6
Thanks for the tips... I didn't know if there was some trick like ammonia, wd40, motor spray, whatever that might soak it off.
Old 09-01-2010, 10:48 AM   #7
Try acetone, a lot of those thread lockers are esther based.
Old 09-01-2010, 03:52 PM   #8
X2 on acetone, I believe you can find small containers of this at your local auto parts store near the fiberglass products (resin & catalyst). You could also try brake Kleen, this also has acetone in it.
a sand blasting cabinet would be a quick & easy way to remove this, I have a media blaster here at work so that is how i do it!
BFGcrawler418 is offline   Reply With Quote
Old 09-02-2010, 10:45 PM   #9
Fingernail polish remover is Acetone with some fragrance added. Otherwise the hardware store has it in the paint department.
Old 09-04-2010, 10:24 AM   #10
A TORCH
calikingcrawler is offline   Reply With Quote
Old 09-04-2010, 11:27 AM   #11
i use a torch lighter
jackal20 is offline   Reply With Quote
Old 09-04-2010, 05:01 PM   #12
I've used motor spray/elec contact cleaner before on blue thread lock.
Softens it up and it just falls off when you wipe your fingers over the thread, or run a bolt all the way through a nut.
WIDELOAD is offline   Reply With Quote
Old 09-05-2010, 03:26 AM   #13
I use acetone and it cleans it up good and can be used for a lot of other things as well.
rustykaos is offline   Reply With Quote
Old 10-11-2010, 11:55 PM   #14
Easiest way is to use a tap and die set. Cleans up the threads nicely.
Slowkrawl is offline   Reply With Quote
Old 10-12-2010, 08:31 PM   #15
automotive brake clean and a rag
Gimp is offline   Reply With Quote
Old 10-22-2010, 05:06 PM   #16
Yep that's what I use to clean my threads.
Shadow Fox is offline   Reply With Quote
