12-28-2010, 11:14 PM | #1 |
Newbie Join Date: Dec 2010 Location: folsom
| cutting sheet metal accuratley
ok so im new to the whole metalworking thing. i have been trying to cut some sheet metal with not even tin snips haha something close to them but besides angle grinder what do you guys use to cut sheetmetal?
12-28-2010, 11:17 PM | #2 |
srry if this is in wrong place
12-28-2010, 11:20 PM | #3 |
Quarry Creeper Join Date: May 2008 Location: Hartsville, SC
Don't really know how thick you are talking. I normally use a Bandsaw at work. If its thin enough I will use a pair of tin snips and do some cleaning up with a rotary tool.
12-28-2010, 11:21 PM | #4 |
Quarry Creeper Join Date: Jul 2009 Location: covina, ca
well this is most definitely the wrong place! sheet metal depending on thickness my fav tool is a grinder with a cut off wheel! what are you trying to make? having the wrong tool will make a simple job impossible. |
12-28-2010, 11:30 PM | #5 |
ok thanks i will be sure to find the right spot next time before i post but i am trying to make a flatbed for a roll cage i built and this stuff is pretty thin
12-28-2010, 11:43 PM | #6 |
Quarry Creeper Join Date: Dec 2008 Location: Hawthorne, CA
For sheet metal I use this shears. http://cgi.ebay.com/WISS-METAL-SHEAR...item3f05612271 Hope this helps. Most harware stores sell them for about 15 dollars. |
12-29-2010, 12:50 AM | #7 |
i will be sure to pick some of those up but how should i get the bends out when i cut?
12-29-2010, 07:12 AM | #8 |
Yeah, with tin snips, the metal in going to curl. I just use a hammer and a solid surface to straighten it out.
12-29-2010, 07:17 AM | #9 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
I like to use a cut off wheel myself, I think you get a better edge. Now my question is how do you guys get a nice clean bend with a sharp edge? Thanks
12-29-2010, 07:33 AM | #10 |
Rock Crawler Join Date: Feb 2007 Location: Peoria, Arizona
With relatively thin aluminum I often score the metal with an exacto knife (with the tip broken off) several times and then bend the metal along the line I just scored. The metal will bend more easily on that line and you can then bend it back and forth till it breaks on the scored line.
12-29-2010, 04:23 PM | #11 |
12-29-2010, 04:42 PM | #12 |
RCC Addict Join Date: Mar 2009 Location: hawaii
I like to use a shear to cut metal and a break to make nice clean sharp bends |
12-29-2010, 05:36 PM | #13 |
Quarry Creeper Join Date: Sep 2010 Location: Big hands, Little tools.......GRRRRR
I must have gotten lucky. My snips are a bit on the large side, but the metal does not warp at all. Another tip is to make your piece out of card stock or a cut up file folder, tune it how you want it to look, and then transfer it to the metal sheet. Mounting holes are much easier to locate correctly this way too. |
12-29-2010, 06:22 PM | #14 | ||
RCC Addict Join Date: Jun 2008 Location: In the woods
you guys must do vinyl siding or roofing work.lol or have before. | ||
12-30-2010, 08:37 AM | #15 |
I wanna be Dave Join Date: Jun 2007 Location: Canada, eh.
Metal brake to bend metal parts. Depending on how accurate the cut needs to be, I'll either use my Dremel with cut off bit (to cut the metal) and sanding band (to clean it up), or I'll draw up the part and send it to my laser cutter !
12-31-2010, 12:58 PM | #16 |
RCC Addict Join Date: Feb 2006 Location: Medford, Oregon
Here's mine. Specs say it will shear up to 1/2" bar and 1/4" sheet. I'd have to bolt it to something a lot heavier to do that. I've personally cut 16 awg, and I have to hold the tool stand down with the other hand. Use it with 20 awg all the time. Slices right through with almost no deformation to the metal. Works great. A little overkill for the average hobbyist though. |
01-01-2011, 03:03 PM | #17 |
Quarry Creeper Join Date: Feb 2010 Location: Duluth
This is what I use for large cuts I use the band saw for small stuff and the dremal or the scroll saw for intricate stuff |
01-02-2011, 06:36 AM | #18 |
Newbie Join Date: Dec 2010 Location: on the border
i use nice razor knife ,, i dont have those kinda tools for that ,, i like the sheet cutter wish i had one good luck
