01-20-2011, 02:23 PM | #1 |
| whats heavier? steel, brass or copper
given same size material of course. whats heaviest to lightest? if i knew how to read a periodic table i could probly figure this out |
01-20-2011, 04:36 PM | #2 |
copper is heaviest, then brass, then steel. Not a huge difference. ~15%
01-20-2011, 10:41 PM | #3 |
Rock Stacker Join Date: Nov 2010 Location: Russia
hope this help http://en.wikipedia.org/wiki/Density |
01-21-2011, 03:37 AM | #4 |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
Tungsten is anoher option but need some carefull thinking. Get small balls and cast them into resin to the desired shape required. |
01-22-2011, 11:00 AM | #5 | |
steel 7850kg/cu.m brass 8400 - 8700kg/cu.m Last edited by constantmotion; 01-22-2011 at 11:51 AM. | |
01-22-2011, 11:40 AM | #6 |
RCC Addict Join Date: Jun 2005 Location: Prosser
01-22-2011, 11:51 AM | #7 |
01-22-2011, 03:42 PM | #8 |
Quarry Creeper Join Date: May 2009 Location: Under Communist Occupation
If you can find steel, and brass on the periodic table, you are a wizard! |
01-22-2011, 03:59 PM | #9 |
01-22-2011, 08:28 PM | #10 | |
Rock Crawler Join Date: Sep 2006 Location: Lititz
Yes, machinable tungsten alloys, like mallory metal, have a density around 17,000 kilogram/cubic meter. This material is used to balance crankshafts. Last edited by chevellian; 01-29-2011 at 05:01 PM. | |
01-26-2011, 06:41 AM | #11 |
| Actually you can get Tungsten rod stock and cut short lengths. Strap them to an axle for weight (or cast them in resin/lead to a shape in a mold). The resin or lead is what gets machined to do the mounting.
01-26-2011, 10:05 AM | #12 |
Quarry Creeper Join Date: Jun 2008 Location: Hell
01-26-2011, 10:49 AM | #13 | |
Rock Crawler Join Date: Jul 2009 Location: greeley
Isnt' copper heavier than iron? Out of all elements of Brass isn't the majority Copper? If I was betting I would bet on Brass! If you dont have a scale. I would download a periodic table. then Google Brass and Steel. You could get a pretty educated guess of the densities. | |
01-26-2011, 10:55 AM | #14 |
[QUOTE=Manning;2873835]copper is heaviest, then brass, then steel. Not a huge difference. ~15%[/QU The question is WHICH ONE IS HEAVIER. Not its not enough to worry about. Heh Heh Heh |
01-26-2011, 10:58 AM | #15 |
01-27-2011, 11:35 PM | #16 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
Here is a source for tungsten. It is not cheap, but it is already cut into specific weights. They also make a tungsten putty. They carry this at our local Hobby Lobby. http://pinecar.woodlandscenics.com/s...ungstenWeights |
02-02-2011, 01:50 PM | #17 |
Quarry Creeper Join Date: Oct 2007 Location: Sheboygan
Just out of curiosity, where does lead fit in as far as weight is concerned?
02-02-2011, 03:19 PM | #18 |
See if you can get the heaviest and most dense. Depleted uranium. Just don't scratch it or make any dust particles. Should bemable to pick it up at a military surplus store. ROR
02-02-2011, 04:04 PM | #19 |
02-11-2011, 04:59 PM | #20 | |
Quarry Creeper Join Date: Feb 2011 Location: Badger State
Gold has two of those attributes as well, but you wouldn't want to use it..... | |
