| | #1 |
| Rock Stacker Join Date: Jul 2004 Location: anaheim ca
| i just got some brakeline to play with but i wanted to know the easyest (sp) way to fish mouth it. |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Jun 2004 Location: SW, Connecticut
| I use the corner of my grinder to fish mouth tube. Its not exact but its better than nothing. Another option would be to use a mill with a bit the same size as the tube. |
| | #3 |
| if you use a grinder it will make a v cut right? i do like the mill idea but i dont have one...what about a elec drill with a drill but same size.... |
| | #4 |
| 06 Super National Champ ![]() Join Date: Jun 2004 Location: Tennessee
| Jay (ROKTOY) has an excellent general how-to on his site. http://www.mindspring.com/~jayk6/rcs...ab/tubefab.htm OR... You could send them to Fishmaxx, let him slobber all over'm and send'm back to you. Either way should work, but I think Jay's way is a bit quicker and, most likely, a bit more sanitary. |
| | #5 | |
| TCS Team Manager ![]() Join Date: Feb 2004 Location: on a Big Rock
First Second I cut my lips doing mine Third I now use a dremel and the bench grinder edge | |
| | #6 |
| thanks jay's wright up helped allot and has solved fights betewn me and dad on what you can and can not do |
| | #7 |
| It dosn't need to be perfect. The solder fills in the gaps pretty good. You also need to take the fishmouth into consideration when you measure. I did some joints on my tube frame using half fishmouths as well. |
| | #8 |
| I wanna be Dave Join Date: Jun 2004 Location: Not where I'd like to live
| First off move this to the NEWB section, Then Buy a Dremel and a 1/4" sanding drum or appropiate size grinding drum. I use a bench grinder The corner works awesome. |
| | #9 | |
I wouldn't consider a question about construction of tubers a NEWB topic. | |
| | #10 | |
| | #11 |
| me to... |
| | #12 |
| Rock Stacker Join Date: Jun 2004 Location: East McKeesport
| Another way is to hold the line in a vise and use a round file. Because it's only brakeline, there's really no advantage to doing this on a mill, unless there are lots of pieces already cut, then a mill might be faster. |
| | #13 | |
| Dirt Addict ![]() Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Jay | |
| | #14 |
| I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| If you've got good drill bits, you can chuck the same size of whatever tube you are using into a drill press and push it against the bit. Not that great for the bit, but it doesn't use that part up there to cut much anyway |
| | #15 |
| Rock Crawler Join Date: Feb 2006 Location: glastonbury
| i use a properly dressed (ie: worn down) flap wheel on my 4.5 inch makita grinder works great and only takes a few seconds. |
| | #16 |
| Quarry Creeper Join Date: Nov 2005 Location: Costa Mesa
| | #17 | |
| AKA TOKEN ![]() Join Date: Dec 2005 Location: "Used" Mexico
| | #18 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| I found the mill to take waay too much time for the end result. I touch the edges to my grinder wheel. Not a perfect fishmouth, but it is better than a flat end. |
| | #19 |
| I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
| I use my drimil cut off wheel. I start with a "V" then, expanded it out to look like a "U". Then to make it nice I put it againts the proper size sanding wheel. Takes about 10 minutes to do both ends. but has a nice fit against the other parts with minimal gaps. |
| | #20 |
| Quarry Creeper Join Date: Sep 2005 Location: Minneapolis
| I use the fine stone on my bench grinder. After you build a few chassis and fish mouth a bunch of tube, you'll find that the corner rounds off and becomes perfect for fish mouthing. Mine come out perfect every time now. I fishmouth one side, test fit, mark to the center to the connecting tube, cut, then mouth it. Done. 45 seconds tops. |
| Thread Tools | |
| Display Modes | |
