03-03-2011, 02:44 PM | #1 |
Rock Stacker Join Date: Jan 2009 Location: kalamazoo
| work surface
what do you guys weld and braze on? i am looking into mapp and silver soldering/brazing and i have messed up one of my tables with propane and my mig so now i have a hell of a time keeping pieces straight (although it wouldnt be so bad if i cleaned my table off ).
03-03-2011, 05:04 PM | #2 | |
03-03-2011, 05:54 PM | #3 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i use a piece of alum plate that is 3/8" thick, braze don't stick to it like a steel surface will if you get flux/braze on it....i've stuck stuff to steel plate work suface ........bob .... |
03-03-2011, 11:40 PM | #4 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
I used an old full tower steel computer case. I took off one side and screwed it down to the top to make a table. Then the open case was used to hold my torch, solder, and flux when not in use.
03-04-2011, 09:07 PM | #5 |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
I use a piece of granite I got a while back when I was a grave digger. Any place that sells grave stones or granite counter tops will have broken or chipped pieces of granite laying around that you can get cheep if not free.
03-07-2011, 06:21 PM | #6 |
Quarry Creeper Join Date: Mar 2007 Location: Sneads Ferry
I use a 12x24 peice of 1/4" thick aluminum set ontop of two bricks....that ontop of whatever table I'm using at the time.
03-07-2011, 08:03 PM | #7 | |
terrible idea for brasing...trust me i know... when the mapp gas hits it its starts exploding. litterally. flaming hot peices start shooting off like pop corn. i was watching how its made, and they actually talked about thats exactly how they make granite if you want a rough or matte finish, they would hit it with a flame. | |
03-09-2011, 11:34 AM | #8 | |
Pebble Pounder Join Date: Feb 2006 Location: Dallas, Ga
We do a lot of work in the shop with an Ox/Ac torch. I always cringe when I see a new guy taking the torch to a part on the concrete floor. Big pieces will start shooting out when it gets hot enough. Steve | |
03-13-2011, 11:50 AM | #9 | |
03-13-2011, 11:08 PM | #10 | |
Rock Stacker Join Date: Feb 2011 Location: FrayedEdgeofSanity
