03-07-2011, 03:53 PM | #1 |
Newbie Join Date: Jan 2011 Location: dayton
| brazing ??????????????s
new to brazing. im buildin a scale truggy custom chassis an tube work . ive done it 1:1 but i gotta hang of brazing an im goin thru oxygen like crazy , oh... i have the home depot map-gas oxy torch kit,and flux coated rod ,so any pointers, ive used 2 bottles of oxygen to 1/8th map gas
03-07-2011, 06:51 PM | #2 |
Do a search in "tools and procedures" for brazing. You will find tons of results. You really should switch to a silver solder product, the most popular around here is Harris safety silv 45 or 56. It melts at a lower temperature than the traditional brazing rods you are working with and is very easy to work with. It is much more expensive but it will last you a long time and is completely worth the money. When you pick that up grab some of their white flux.
03-07-2011, 07:49 PM | #3 | |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
03-08-2011, 07:04 PM | #4 |
| thanks guys for the info. i have access to a oxy/accetyline torch. would that be good to use my brazing rod with. and where can i get safety silv... local hardware or online
03-08-2011, 07:11 PM | #5 | |
Safety Silv is available at a local welding supply store. It will be around $25 for a 1 oz roll, but it will go a long ways. | |
03-08-2011, 11:39 PM | #6 |
Rock Crawler Join Date: Dec 2005 Location: West Omaha
Oxy/acetylene is to hot. But if you have access to it use the oxy bottle with the mapp gas to make it hotter, or like was said just use safty silv like everyone else. You can also get away with using oxy/propane.
03-09-2011, 06:03 PM | #7 |
03-10-2011, 12:41 AM | #8 |
Well too hot wasn't really what I meant. It is hotter so easier to screw up if you don't have experience is what I meant. It will work though sure. It is kind of a waste for tube chassis though isn't it?
03-10-2011, 11:38 AM | #9 | |
And what's kind of a waste for a tube chassis? | |
03-10-2011, 01:30 PM | #10 |
RCC Addict Join Date: Oct 2007 Location: gervais
alright looking over this thread and on another thread about brazing, someone said that saftey silv is used for only brass... but aren't most of you using that stuff for brake line? and thats steel? if you want to explain, you can but if you don't feel like it just say yes or no lol |
03-10-2011, 01:35 PM | #11 | |
03-10-2011, 01:44 PM | #12 |
so 3/16 steel brake line is fine with the saftey silv.... oh good lol, so many different threads on bazing and not one has all the facts so looking at one to another you start getting a little confused..... so it's plenty strong then? how do you do your set up? just wondering since you are like awesome at it |
03-10-2011, 03:34 PM | #13 |
It's amazingly strong. In fact, I've never broken a joint in tubing. I have broken off a tab, but it doesn't happen very often. I just use a standard size torch set up with a 00 brazing tip, nothing special. Just takes alot of practice....plus I've been fabricating metal of some sort for 25 years. |
03-10-2011, 07:17 PM | #14 |
Newbie Join Date: Nov 2010 Location: Ashley
actually i went from safty silv to brazing rod and like it better but I'm used to working with it also so that may make a difference but war pig maybe you could answer something for me when I was using the safty silv most of my joints were pretty week i'm thinking it was because i wasn't getting the joint hot enough...anyway as far as the oxy use i agree with war pig oxy/act would probably be best but i'm also using oxy/mapp waht i did as far as usage was to get a refillable oxy tank as was suggested
03-10-2011, 09:38 PM | #15 |
Just ignore me, listen to war pig he knows what he is talking about.lol Most of what I am saying has been from my experience.
03-10-2011, 09:55 PM | #16 | |
Debunking old stereotypes Join Date: Feb 2006 Location: 1st and Amistad
You're doing something wrong, when I braze a joint with safty silv, I can bend the tube before the joint will give, like Warpig, I've never had a joint break. | |
03-11-2011, 01:06 AM | #17 | ||
From the pictures I have seen on here a lot of people are using way too much silver solder, I try to use as little as possible. The easiest way to use less silver solder is to use less flux. Usually I line the joint up horizontal and then add flux on the top half of the joint, just a skim coat. Then when I heat it it flows down around the joint and turns clear and its time to add the silver solder, just a small dab then check the backside to make sure it went all the way around. If it didnt and there is extra on top you can just reheat the joint and it should flow out and fill the gap. If not, add a little more flux, flip it and fill in the gap. This stuff is expensive, why use more than you need!!! | ||
03-11-2011, 07:37 AM | #18 | |
03-11-2011, 07:40 AM | #19 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i did a sample 90 degree joint with the bird/fish mouth and tore the tube apart with the joint not even cracked anywhere took me bout 20 minutes with two sets of vise grips too ........bob .... |
03-12-2011, 11:35 PM | #20 |
Thanks for the tips guys all noted I've got 2 oz. of safety silv so i'm not going to give up on it just got excited to get my first build done and went with what I knew how to use planning a full tuber next so i'll give the solder another shot and btw I'm using the white flux and i think you're right warpig i fish mothed the joints but intentionally left a small gap so i think that is what I may have been doing wrong
