03-22-2011, 01:39 PM | #1 |
Rock Stacker Join Date: Nov 2008 Location: Linwood
| Which Bender To Get?
Looking for some direction. Which one of the two benders below will work the best for 3/16 rod, 3/16 tubing and 5/32 rod. Thanks. http://www.mcmaster.com/#2460a16/=bjovl1 http://www3.towerhobbies.com/cgi-bin...&I=LXGFW4&P=SM I am leaning toward the McMaster bender. The smallest die is 1/2" so doe sthat mean I can bend a 1/2" radius? Last edited by MNROKCRAWLR; 03-22-2011 at 06:54 PM. |
03-22-2011, 01:52 PM | #2 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
THESE 2 LINKS ARE FOR THE BENDER & DRILLING JIG I USE FOR ALL MR ROD AND TUBING WORK, I MAKE LINKS , STEERING LINKAGES ETC. K&S METALS PART#326 FOR THE BENDER AND THE DRILLING JIG IS EAST END MACHING PART #FIX-001 http://ksmetals.com/accessories.html http://eastendmachining.com/lidrjig.html HOPE THIS HELPS |
03-22-2011, 02:13 PM | #3 |
Rock Stacker Join Date: Sep 2009 Location: griffith nwi
| http://www.amazon.com/Ridgid-36117-L.../dp/B001D1ITLC i use that bad boy never failed me what i like best if you find take up and how much pipe it uses for all bends your can make perfect bends so the car isnt lobsided |
03-22-2011, 02:20 PM | #4 |
Nothing better than the original! |
03-22-2011, 06:50 PM | #5 |
| I think that "bender" might be too expensive with relocation costs and such.... Last edited by MNROKCRAWLR; 03-22-2011 at 10:32 PM. |
03-25-2011, 09:19 PM | #6 | |
Quarry Creeper Join Date: Mar 2007 Location: Sneads Ferry
03-25-2011, 11:20 PM | #7 | |
Rock Stacker Join Date: Feb 2011 Location: FrayedEdgeofSanity
* in HVAC work, haven't begun my tuber yet. | |
03-31-2011, 07:36 PM | #8 |
| What diameter are the bend radius of the three grooved bender? All the ones I have ever used have fairly large diameters and it'd be pretty huge bends for RC work.
03-31-2011, 08:35 PM | #9 |
Quarry Creeper Join Date: Aug 2009 Location: another state of mind..?
use i vise for rod only for tube make one your self |
04-01-2011, 10:08 PM | #10 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
04-01-2011, 11:33 PM | #11 |
Quarry Creeper Join Date: Jun 2010 Location: NTXRCC
| http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 I got this at home depot for $12 in the plumbing section |
04-02-2011, 09:46 AM | #12 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i made a tight radius tube bender with mandrel type dies so tube don't get kinked from junk i had around the house.... i'm going to make a build thread on it so people can look it up under my profile under threads i started easier ........bob .... |
04-04-2011, 07:09 AM | #13 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
| The K&S Mighty Wire Bender & Coiler Best bender Ive found so far bends around 1/4" radius built around 350 chassis with this unit & still going The DmG |
04-04-2011, 07:05 PM | #14 |
RCC Addict Join Date: Feb 2006 Location: Medford, Oregon
What he said^^^^^ I have a modded version of the K&S mighty wire bender & coiler. I've used it to build literally hundreds of bumpers sliders etc... I also us the mini wire bender for some small stuff. |
04-06-2011, 04:10 PM | #15 |
Nobody Join Date: Sep 2008 Location: Maine
04-15-2011, 09:30 AM | #16 |
I wanna be Dave Join Date: Nov 2008 Location: Too old to care
Were can you get the k&s at .
04-15-2011, 10:37 AM | #17 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
04-15-2011, 11:52 AM | #18 |
I just got my k&s in the mail. Is it made for solid stock only? I put a piece of brake line in it and it flattened it right out. Solid 1/4 alum bent nicely. @tw!ll, do you have pics of your mods? Also, is the hole in the end of the bar drilled perfectly perpendicular? |
04-16-2011, 07:16 AM | #19 |
Rock Stacker Join Date: Aug 2010 Location: MI
They do have a tube bender kit. It looks like a wire mesh sleeve that goes over the tube before you bend it.
04-16-2011, 09:45 AM | #20 |
Rock Crawler Join Date: Oct 2009 Location: Washington State
If you fill the tube with sand or salt, it will help prevent kinks. Here's a link to the tube bender add-on: http://www.hobbylinc.com/htm/k+s/k+s321.htm |
