03-22-2011, 04:10 PM | #1 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
| Drilling thru steel question
So I have been trying to use a dremel to drill thru some steel plate with little results. I dont mind buying effective tools but do to space restrains a drill press is not an option. No I dont have a actual drill, I have just been relying on my trusty dremel for everything....lol. I have tried several bits and nothing. Now I am getting into brazing and being able to drill precise holes needs to be an option, so I thought I would ask you guys what to buy. Thanks |
03-22-2011, 04:12 PM | #2 |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
do you have enough space on a bench to put a mini drill press? if u do or r not sure look some up ive seen some that r a good size for what it sounds like ur doing. not really sure on the prices though.
03-22-2011, 04:17 PM | #3 |
Pebble Pounder Join Date: Mar 2010 Location: Bend
| get sharper bits
sounds like you need to sharpen your bits, I use my dremal all the time drilling steal and have no problems.
03-22-2011, 06:43 PM | #4 |
Rock Stacker Join Date: Dec 2009 Location: Clemson
Dremels are designed for high speed, low torque. That is the exact opposite of what you need for drilling steel. It would be best to pick up a regular hand drill. Corded drills are pretty darn cheap and pack plenty of power. Some have a small separate attachment that turns them into a basic press, which may be perfect for what you are doing. Otherwise with the Dremel, sharp bits and plenty of cutting fluid. If the bit is not digging and becomes too hot to touch, it has softened and is now trash. |
03-22-2011, 07:06 PM | #5 |
Thats the problem I was running in to with even new bits, lots of heat and not grabbing. Looks like its time to just get a nice cordless. I had one but some how it got lost in our last move.
03-24-2011, 01:36 AM | #6 |
Quarry Creeper Join Date: Apr 2005 Location: Malaysia
Definitely get a drill. Low speed and make sure you press down on it, but keep it straight. Cutting fluid or some light oil will help a lot too. High speed builds up heat and hardens the steel. Use a new drill bit if possible. Cobalt bits work a bit better than regular HSS.
03-24-2011, 02:23 AM | #7 |
Quarry Creeper Join Date: Jun 2009 Location: Minnesota
I vote Desktop drill press as well. Takes up the same amount of table space as a 12 pack of beer, and is alot easier and precise than a hand drill.
03-24-2011, 10:48 AM | #8 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
unless you have varible dremel they are too fast....get a plain ol 3/8" or 1/2" corded drill from wally world black n decker ........bob .... |
03-25-2011, 01:16 AM | #9 |
Rock Stacker Join Date: Feb 2011 Location: FrayedEdgeofSanity
Another vote for the mini drill press... along with a cradle type drill press vise and a good center punch. Failure to hold a drill completely straight is what messes up drill bits.
03-25-2011, 02:08 AM | #10 |
Rock Stacker Join Date: Jun 2010 Location: Folsom & Pomona
drill press vote here too. I wouldn't get a cordless drill. corded is the way to go. I recommend Dewalt for a little more cash but it'll last a long time. Mine's goin on about 11+ years now and still kicks ass
03-25-2011, 11:24 PM | #11 |
| I found my Dewalt corded drill in a dumpster. The chuck was a solid mass of rust. I dangled it by the cord (yeah I know) in a cup of WD40 for a few days then cleaned it up. Still good 15 years later.
