04-27-2011, 02:57 PM | #1 |
Newbie Join Date: Apr 2011 Location: bremerton
| required/recommended tools to have...maybe made a sticky?
i know I'm new here, so i probably shouldn't be the one to start this thread, but I'll do it anyways in hopes that it helps other new people like myself find the right tools the first time...and save the oldtimers the headache of having to answer with "search". soooo...without further adu.... what all do you have in you tool box? what are the best tools you've bought for working on your rc rig? what are some tools that you've made because it was either better or cheaper than what's on the market? if you have certain tools that you absolutely can't live without...which ones are they? in my searching i've found this kit recommended a lot (and I've already ordered one): http://www.dynamiterc.com/Products/D...ProdID=DYN2833 i've also found this website to be very helpfull with it's selection: http://www.rpphobby.com/category_s/402.htm here's a set of hex's i've read recommended a couple places: http://www.hobbyking.com/hobbyking/s...dProduct=11048 i know some tools, especially custom ones, will be vehicle specific so if that's the case it'd be nice to know what vehicle it's for. |
04-27-2011, 03:43 PM | #2 |
Y-Town Crawlers Join Date: Oct 2005 Location: Not Hesperia
Hey Chris, good to see you made it over here. A good set of Hex drivers will take care of most stuff. I have one of the Dynamite sets you posted, and the handle eventually drove me crazy. The locking collar on mine wouldn't hold a bit firmly, so they were always popping out. After that, I would recommend a good set of nut drivers or sockets. 4.5mm, 5mm, 5.5mm, 1/4", 7mm, and 8mm are the most common ones you will use on a 1/10th scale rig. Everything else I use is pretty common in most tool boxes... needle nose pliers, x-acto knife, curved lexan scissors. |
04-27-2011, 04:12 PM | #3 | ||
04-27-2011, 04:17 PM | #4 | |
http://www.axialracing.com/details.php?Id=3605 You can find cheaper sets, but with any tools, quality isn't cheap Lexan cutting scissors like these make it a lot easier to trim bodies and cut out fender wells. http://www.axialracing.com/ftp/ax200..._scissors.html | |
04-28-2011, 09:02 PM | #5 |
Newbie Join Date: Mar 2011 Location: west palm beach baby
i just clicked the link for the nut drivers, and i think i just crapped alittle, holy expensive, i thought i just walked on the snap-on truck for a second, true about tools, snap on's moto ''quality is priceless''
04-28-2011, 09:11 PM | #6 |
04-28-2011, 09:29 PM | #7 |
Quarry Creeper Join Date: Dec 2009 Location: St. Augustine
surprised nobody's mentioned it yet, but a dremel is a very handy tool to have. other than that nut drivers, allen wrenches, pliers etc. etc. also, a third hand tool comes in handy when you're soldering on deans plugs. last thing is a mat, not really requiered but nice to have; I'm using a cow mat and I'll never go back to using towels again.
05-01-2011, 01:01 AM | #8 |
Rock Stacker Join Date: Apr 2011 Location: Upper Peninsula, MI
I agree with CHUD, Bondhus makes great stuff. I use their hex drivers, L-hexes, and T-handles. A few other things that every RC'er should have: Digital caliper - I use a cheap-o Ebay one. Works good enough for my needs. If I did machining or used it for my job I would consider buying a better quality unit. IR thermometer - I have a larger gun-type one, but just the other day picked up a tiny one from Radioshack, only $20 and it's supposed to be waterproof, although water-resistant is probably more realistic. Takes up much less space in the toolbox and easier to bring with in the field. Digital multimeter - Good for monitoring battery packs, and troubleshooting electrical problems. |
05-01-2011, 05:16 PM | #9 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
In addition to the tools already suggested...a soldering iron and solder is pretty much a mandatory tool, I think. It's also incredibly useful to have a drill, some good bits, and a drill bushing from JeepinDoug if you make your own links. Link Drill Bushing |
05-02-2011, 05:16 PM | #10 | ||
| Quote: Quote:
05-02-2011, 06:58 PM | #11 | |
Rock Stacker Join Date: Dec 2009 Location: Clemson
Tool selection is quite relative, but there are a few basics I wouldn't want to do without. Pliers (2+ pair), screwdriver set, hex key set, and a hacksaw at minimum. The "extra" tools I use the most are the dremel, drill press, bench grinder, die grinder w/ cut off disk, well secured vise, oxyfuel torch, MIG welder, tap and die set, good drill bits, jig saw, and my 60 year old Craftsman 109 lathe (which is useless for anything harder than aluminum). I still wouldn't mind a band saw and milling attachment for the lathe.. | |
05-05-2011, 04:00 PM | #12 |
any good recomendations for different boxes? got a metal 3 drawer craftsman but it's a heavy SOB. was thinking bout using a plastic fishing tackle box because my guess is that most of the spare parts are small enough to fit, plus they already have all the seperation built into them. like I said, i'd like to eventually see this turn into a sticky with all the necessities for someone who was new to the sport. |
05-09-2011, 02:16 AM | #13 |
Rock Stacker Join Date: Apr 2008 Location: Fairbanks
Plastic fishing tackle box's are what I have used since 1988. You can't find a better "tool box" for this hobby IMHO
