06-12-2011, 11:13 AM | #1 |
Pebble Pounder Join Date: Feb 2008 Location: Bala Cynwyd
| Scale tube bending radius
I tried asking this question on a site I thought was geared more toward scale stuff and got a bunch of lame answers. What radius are you using for the bends in your tube work? 1:10 scaler truck, looking for things like stingers, roll cages. I know it should look like the 1:1 stuff but I don't have one of those to go out and measure. |
06-12-2011, 11:35 AM | #2 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
look at my tube bender thread and what i use and the size of the inside radius.... my tube bender........... i'm not sure how scale the radius is on what i use, but i'm in the process of making a new bender to make smaller radius's in my tube work....i need to make a new one as i sold the one in that thread.........bob .... |
06-12-2011, 05:17 PM | #3 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
I prefer a 1" radius. I think it fits most things nicely. Here's a pic of my latest chassis all built with roughly a 1" radius. So you get an idea. Last edited by rckjeep; 06-13-2011 at 10:58 AM. |
06-12-2011, 07:12 PM | #4 |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
I rarely use the same radius twice if not making parts that need to match side to side and Ive never measured a radius. Building tubework is supposed to be fun not rocket science. Make your bends so they flow nicely within the design and with the body lines and call it good. |
06-12-2011, 07:34 PM | #5 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
My answer was not lame. Stop over thinking it. Just bend the tube however much you want. Should be simple for an engineer. If you want to get silly with it, print out a picture of what you are copying to use as a template and bend your tube accordingly. |
06-13-2011, 06:47 AM | #6 |
| First I tried painting the tubes blue,then red, but once the red and blue mixed, the whole mess melted into a purple metallic glop. The only thing I could do was put it into the 3D prototyping scanner's vat along with a picture of what I wanted to build and then, presto. I just wanted a simple answer, or even a picture, so I can compare the diameter of the shock hoop to the diameter of the wheel and figure it out. I'm an Engineer not an artist, I want the cage to be strong enuf to be run over by a truck or survive a fall off a big ass hill. 99% of the time this is just for fun, but there are some very real and cool engineering problems to be worked out, these are real vehicles they're just smaller. I know this isn't rocket science.... It's mechanical engineering Tell me to paint the tube blue and it bends itself, but then tell me that you use a 1/2" radius, that's cool. Last edited by HaSharetz; 06-13-2011 at 07:40 AM. |
06-13-2011, 07:45 AM | #7 | |
06-13-2011, 08:03 AM | #8 | |
As for your question, 1:1's I've seen use 1.5" or 1.75" tube and 6.5" and 5.5" dies for bending. Since you're the engineer, I'll let you do the math to match the diameter tubing you are using to the scale you are building to...if you are off by a few fractions of an inch, nobody is going to notice. | |
06-13-2011, 11:12 AM | #9 | |
click here | |
06-14-2011, 03:48 AM | #10 |
Dude, That was an (is an) awesome tuber. Thanks for the great answers/links/help |
06-14-2011, 05:01 PM | #11 |
06-15-2011, 03:36 PM | #12 |
Rock Crawler Join Date: Oct 2009 Location: San Diego
If youre talking about actual tubes - as in hallow/not solid... the tighter you can get the bend w/o collapsing the tube the more scale it will look. Im speaking in terms of doing 90 degree bend or there abouts. Obviously your bends wont be all 90's on a rig but that is the ultimate test in a bender. Solid rods are infinitely easier to bend though arent worth using to build with cuz of the weight gain. But you can get a solid to a 90 degree bend with no inner radius, literally a break. |
06-17-2011, 04:04 AM | #13 |
Quarry Creeper Join Date: Mar 2007 Location: Sneads Ferry
To be completely scale about it, I usually try to copy cages built out of 1.5" tube. In scale, you're talking 1/8" solid...that's not really as easy as it sounds, so lets go up to brake line. 3/16" brake line to represent 1.5" tube. My JD2 bender uses these dies.... https://www.jd2.com/p-44-m3-round-die-sets.aspx ......and you can get dies for 1.5" tube anywhere from 4.5"-7.5" line radius, so in scale again, we're looking for a bender that can do .5"-.75" radius. I'm lazy and figure that a 5/8" radius is good enough being between .5 and .75". So for that, I'm using this... |
06-17-2011, 08:29 AM | #14 |
06-17-2011, 10:04 AM | #15 |
06-17-2011, 05:27 PM | #16 |
Now that I think of it my bender isn't 1" its closer to 1/2" radius. It'll only do 90* bends but it works for most parts. THe shock hoops in the pic above are 1" wide in the center of the tube. In 1:1 I usually buy the smallest radius die I can, as I prefer the tighter radius. |
06-27-2011, 06:08 PM | #17 | |
Newbie Join Date: Mar 2011 Location: socal
06-27-2011, 09:31 PM | #18 |
06-27-2011, 11:03 PM | #19 |
RCC Addict Join Date: Jun 2009 Location: Salmon Arm BC
i made these ^using this... its a solid rod bender that i made. ^made this using just a regular bench vise, a little heat and a hammer. ^made this bumper using a bench vise made the bumper and the bottom of the chassis before i built the rod bender so if i had the bender i could have done a nicer job... i use 1/4" solid rod from Canadian Tire. |
