06-16-2011, 10:44 AM | #1 |
Quarry Creeper Join Date: Jun 2008 Location: anchorage
| Tube notchers
Has anyone come up with some kind of notching jig for tube. I have an idea but was looking for any other ideas that are out there.
06-16-2011, 10:59 AM | #2 |
With the size of the tube, I do it by hand with a dremel or a chainsaw file of the proper size. There are just so many joints in a tuber, it seems to take longer using a jig because of how easy and fast each fishmouthing is without it.
06-16-2011, 02:06 PM | #3 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
Bench grinder......10 seconds per joint.
06-16-2011, 02:11 PM | #4 |
Chainsaw file. Thought about making a fixture for it awhile back, but it's so easy to hold the tube between the thumb and index finger that I never bothered.
06-16-2011, 02:54 PM | #5 |
06-16-2011, 07:36 PM | #6 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i use a dremel with a router attachment mounted to a 3/4" pine board through a 1/2" hole....then a hardened carbide cutter in 3/16" dia through said hole with a block of wood up against it so that my notch is centered on my tube i'm using....turn dremel on and bout 5/10 seconds it's done....if i need it angled i use the 1/4" sanding drums then by hand.........bob .... |
06-16-2011, 07:56 PM | #7 |
N.E.R.C.C Uncle Blinky Join Date: Dec 2008 Location: RUKDNME...
06-17-2011, 08:09 PM | #8 |
RCC Addict Join Date: Jun 2008 Location: In the woods
06-17-2011, 09:00 PM | #9 |
RCC Addict Join Date: Feb 2005 Location: Minnesota
06-18-2011, 02:01 PM | #10 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
3/16 chainsaw file ftw !!!! ( i copy the pros ) i sometimes just use the shop floor to deburr it real quick like. |
06-18-2011, 08:34 PM | #11 |
06-19-2011, 01:03 AM | #12 |
Thanks for all the replies fellas. Sorry I couldn't reply sooner. All of the input helps. I have been doing all my notchs by hand with no problems, Since it is faster by hand I will just keep doing the same thing.
06-19-2011, 02:58 AM | #13 |
09-20-2011, 10:31 PM | #14 |
Quarry Creeper Join Date: Jun 2011 Location: panama city
| getr done
imprvise son improvise . that is the the key to all roadblocks in r/c baby improvise in a flash |
09-21-2011, 01:11 AM | #15 |
i just use the corner on my bench grinder stone to get a rough shape then use 3/16" chainsaw file to make it a perfect fit.........bob .... |
09-21-2011, 03:50 AM | #16 |
RCC Addict Join Date: Dec 2010 Location: middle,tn
dremel with chainsaw stone either the pink or the orange depends on the size tubing...same as file just faster...and i hate using a hand tool when i can use a power tool.. |
09-21-2011, 09:42 AM | #17 | |
Also, I like the Old World Craftsman feel of doing it by hand...makes me feel like a blacksmith or something | |
09-21-2011, 05:43 PM | #18 |
Actually the chainsaw sharpener stone holds up pretty well as long as you don't just dig it in.. Let the stone do the work and it'll last for a while... The kit is only like 5$ at Walmart J-bird |
