06-19-2011, 07:11 PM | #1 |
Rock Stacker Join Date: Mar 2011 Location: coos bay, Oregon
| Cutting aluminum?
What's everyone use for cutting thicker (1/8-3/16") aluminum? I've tried scroll saws, hand saws and hack saws, but they all seem to not work very well. Any suggestions? Thanks guys!
06-19-2011, 07:16 PM | #2 |
| you should be able to cut those thicknesses with each tool that you listed, what is the tooth count on the blades that you are using? ( TPI is what it's called) and you need to use a SLOW speed if using a power tool, something in the neighborhood of 300-500 RPMs max, otherwise all you end up doing is making heat and dulling the blade.
06-19-2011, 08:05 PM | #3 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
I use a hack saw and coping saw depending on cut. Then file to tolerance. A good file goes a long way with aluminum if cutting by hand.
06-19-2011, 08:32 PM | #4 |
Quarry Creeper Join Date: Apr 2005 Location: Malaysia
I have good luck with a hacksaw. You want... 1. A decently new blade (still straight and sharpish) 2. Some thin oil on the blade 3. At least 3 teeth across the thickness of the piece (so at least 24 tpi for 1/8") |
06-19-2011, 08:35 PM | #5 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
I use a band saw with a 14 to 18 tpi blade. If I'm cutting alot of aluminum, I run a bar of soap into the blade for a few seconds...........it keeps the teeth from loading up with aluminum. Plus it smells spring fresh!
06-19-2011, 09:11 PM | #6 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
straight cuts or even angled cuts off a straight side i use my dewalt 12" miter saw i use for wood....makes a very nice clean cut in alum up to 1" x 7/8" bar stock, just need to go slow to where i get alum dust and no big chips....i have cut stuff from 1/16" thick to 1" thick with no problems .......bob .... |
06-19-2011, 09:53 PM | #7 |
06-19-2011, 11:51 PM | #8 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
| I love "charcoal lighter fluid." Any old brand works, get the cheapest you can. 2-3 drops/side of the blade goes a LONG way to making aluminum cut easy and not leave that nasty "rough" finish behind from the blade sticking. Just obviously be careful using it because after a lot of cutting fumes can form and... you go just a wee bit nuts Other than that, they hit up all the good points. Can't stress enough on sharp blades... |
06-20-2011, 08:03 AM | #9 | |
Newbie Join Date: Jun 2011 Location: earth
I use 1mm thick cutoff wheels and a 5" angle grinder, works great on 8mm thick aluminium. Quote:
