06-26-2011, 10:02 AM | #1 |
Newbie Join Date: Mar 2011 Location: brazil,IN
| soldering and tubing
Im kind of new to this stuff. what type of solder do you usually use and what size tubing do you use for a rollcage.
06-26-2011, 12:15 PM | #2 |
Soldering? For structural stuff, you need a "hard solder" which is either silver solder or brazing rod. Neither of these can be done with a soldering gun/iron. Harris Safety Silv & flux is the easiest bet since a normal gas torch (used for sweat fitting copper pipe) can deal with it. Brazing requires a bit more heat. As to tubing 3/16th" steel brake line is a common size (use the uncoated stuff). |
