08-14-2011, 07:59 PM | #1 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
| rob_b's Little Lathe Rebuild
Well I finally broke down and bought a mini-lathe. It's been a long time coming but for the past couple years every time I had the money I would end up building a new r/c car. Briefly entertained buying a used machine but in the end I prefer tinkering with new stuff. There are a million places to pick these machines up but I decided on the Grizzly 7x12. What I like about Grizzly is that they stock all of the parts if something needs replaced. They come slopped with a heavy coating of grease so the first thing you have to do is disassemble the machine and give it a thorough cleaning. Some people see this as a bad thing but really its not, you get to see how everything works and in my case make some modifications. Here is the cute little bastard broken down and cleaned up. On the main unit I have already cleaned up the gearbox and adjusted all of the gear mesh'es (the gears came set with zero backlash and were literally all jammed together). Not sure if I just got lucky or not but the OD of the spindle has approx .0001" runout and the ID taper has about .0003". I have not indicated the chuck yet. While it was torn down for cleaning I am lapping all of the sliding surfaces to improve the overall quality of the machine and reduce chatter. Lapping is a process where you use an abrasive compound to wear two surfaces against each other to remove the high points and increase contact area. Here you can see some of the parts broken down, cleaned and lapped. It's hard to show but in the large flat area you can see the rotary machining marks vs. the long straight "grain" of the angled area that has been lapped. So as of now the compound and cross slide have been lapped and are offering a very smooth motion. Next up is lapping the main ways. First though you have to set the height of the carriage strips. It is recommended to set the strips to a .040" clearance with the carriage, test fit and reduce the clearance between carriage and the ways to .001". Here I have a .010" and .030" feeler gauge pre-setting the height of the saddle strips. Installed the carriage on the ways and set-up my new best friend, the .0005" Test Indicator. First I zero'ed the dial. Then pushed down on the carriage to see how much it moved. On this side it was just shy of .012" so I need to reduce the strip clearance by .011". Now zero the other side. Press down and the dial reads .013" meaning I need to reduce clearance on that side by .012" to get to my .001". So I guess, I was slightly off setting the height of the strip or something else is up. I'm not sure yet. Just for reference a human hair is roughly .001" in width. Maybe more tomorrow night, I am really enjoying this so far Last edited by rob_b; 08-26-2011 at 07:04 AM. |
08-14-2011, 08:07 PM | #2 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
I did all of the same stuff to Chump's lathe when I got it home. Yeah right! |
08-14-2011, 08:11 PM | #3 |
Wouldn't expect any less from you King Travis |
08-14-2011, 08:15 PM | #4 |
08-14-2011, 08:25 PM | #5 |
DOOH!!! Join Date: Feb 2007 Location: AZ
Sweet, once you get it all dialed in you can come over and do mine... |
08-14-2011, 09:06 PM | #6 |
Quarry Creeper Join Date: Jun 2008 Location: Mesa
The Goal has shown itself once again |
08-14-2011, 09:23 PM | #7 |
What lathe do you have John and more importantly does your garage have a/c? True story Kolby, I'm a believer |
08-14-2011, 11:09 PM | #8 |
Cool thread rob! I have one of these sitting in the corner not getting used because I just dont want to mess with it. I will be keeping an eye on this thread for some more good tips. |
08-14-2011, 11:17 PM | #9 |
Oliver Custom Knives Join Date: Dec 2007 Location: Bloomfield NM , not something stupid
Holly Cow , looks like you spent more on measuring devices than you did on the lathe....... .0005".....really???? WOW OK , hurry up and make something already. Send me a link to the 4 jaw you want too. |
08-14-2011, 11:40 PM | #10 | |
I think the .0005 indicator he has is pretty standard...we had like 15 of them, which is pretty good considering we only had 10 edge finders | |
08-14-2011, 11:42 PM | #11 |
I wanna be Dave Join Date: May 2006 Location: akron
Getting the saddle set right is the worst part on these things..
08-15-2011, 07:55 AM | #12 |
Thanks Erik, it's been a fun project so far. Dwane, losikid is correct, it's a standard test indicator .030" travel with .0005" divisions. The really preceice ones have .008" travel with .0001" divisions. I ended up buying three cheaper indicator's because the best ones would have exceeded the cost of the lathe itself. As it stands I have roughly the same value wrapped up in tooling just to get started. Trust me, I want to make some parts NOW but it will be worth it to get the little guy tuned in. Yeah, setting those strips will take a bit of patience since none of the screws are very accessible while it's mounted. |
08-15-2011, 09:33 AM | #13 | |
and NO!!! I'm freaking DYING out there this time of year BTW, http://littlemachineshop.com/product...ory=1963256898 Worth every penny.. | |
08-15-2011, 09:51 AM | #14 | |
08-15-2011, 10:01 AM | #15 |
Sounds like you can make two of the covers we were talking about then It's to keep the swarf out of the carriage gears. Yep that's the QCTP I bought too... If it is a total failure I'll probably get this setup. Wish I would have seen it before I ordered Last edited by rob_b; 08-15-2011 at 10:04 AM. |
08-15-2011, 12:19 PM | #16 |
Make anything yet |
08-15-2011, 12:41 PM | #17 | |
08-15-2011, 12:44 PM | #18 |
08-15-2011, 02:32 PM | #19 |
The title of this thread makes it sound like a fairy tale. Especially if you say your name as it looks..............Robbie Last edited by travis c.; 08-15-2011 at 02:34 PM. |
08-15-2011, 02:35 PM | #20 |
Are you the hookah smoking caterpillar?
