11-13-2011, 07:44 PM | #21 |
RCC Addict Join Date: Jun 2007 Location: San Antonio, Tx
I used to work at a cable bulding place we would make wire harnesses for everthing from dash cams in cop cars to large harnesses for trains and everthing in between. I crimped alot durring my daily builds and these type of crimpers are awesome I must have crimped 1k pins +? aday. I watched the vid and have never seen it done his way. I and everyone inworked with put the pin in the tool then inserted then inserted the wire ( after having some copper showing) and just crimped, it's alot faster than his method. Side note, we also had a crimping machine that was awesome it was 6' tall and 3' wide and deep and you could crimp a lit of wires in a short time.
02-17-2012, 09:46 AM | #22 |
| Re: Best $21 ever spent. Servo Connector Crimping Pilers
For what ever reason the ones I make never have the holding power of the factory plugs. Mine are always a little loose unlike the factory ones that you have to pull pretty hard on to remove. I've tried all of ServoCities pins I also have their crimper. Any ideas?
02-17-2012, 09:57 AM | #23 | |
| Re: Best $21 ever spent. Servo Connector Crimping Pilers Quote:
So, it looks like a U shape.....I first put the bottom side of the U down in the female part of the tool, and crimp. Then, I turn it over and crimp again (which will smash the tops of the U into the wire). I also go along and make sure that the length of the connector is crimped properly (just dont go too far toward the end of the connector as it will snap off those little tabs). I have never had a connector that I made loosen up on me... | |
02-17-2012, 10:42 AM | #24 |
Pebble Pounder Join Date: Mar 2010 Location: PHX
When I started crimping, I worried about cutting the wire. I found that I have to squeeze the hell out of it to cut the wire. I have not had one come apart since finding this out. Try a tester out to gauge how hard you need to squeeze.
02-17-2012, 12:38 PM | #25 | |
The crimper has three different sized jaws, I've been using the smallest one. The female pins all fit snuggly on the any male pin before their crimped and you have to pull reasonably hard to pull it out. After crimping the female pin they get loose on the male pin. I'll try the center set of jaws I'm thinking the small set might be distorting the pin at full compression. I'll let you guys know how that turns out. | |
02-17-2012, 12:47 PM | #26 |
Oh....then I'd do what that guy does......I dont use a fancy one like that. Just a cheap version.
02-17-2012, 12:57 PM | #27 |
I've been doing it like the video but the female is opening up and the fit is sloppy. It's to bad they look OEM factory but they loose the grip on those males after crimping. It's something I'm doing wrong I'll keep working on figuring it out. I'll even re-watch the video again my ADD might have gotten in the way. Last edited by Stormin2u; 02-17-2012 at 12:59 PM. |
02-17-2012, 04:19 PM | #28 |
Got every thing working. I needed to change how much wire I stripped in preparation for the female pin, I was getting a little insulation in the striped wire wing area.
02-21-2012, 04:06 PM | #29 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
I have been using those crimpers for years on 1/12 scale RC cars. Not a lot of room on those smal race cars and every oz. counts.
02-21-2012, 04:12 PM | #30 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
| Re: Best $21 ever spent. Servo Connector Crimping Pilers |
