08-31-2011, 11:03 PM | #1 |
| binder screws vs standard screws for plastic
Just curious as to what you guys have found to work better for plastic duties. Binder or the standard .5 pitch m3's. Or is this a non issue? Searched to no avail. |
09-02-2011, 08:27 AM | #2 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
I don't see how self tapping screws aren't ideal for the kinds of plastics we see in our crawlers. In my limited experience 3mm x .5 have already stripped more holes than 3mm self tapping screws. Just don't shorten screw lengths once you've installed in a particular hole.
09-02-2011, 08:33 AM | #3 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
When you say binder, I assume you mean fine thread vs course thread. If not, forget the following. I prefer fine thread for plastic. With that said, I just started trying brass inserts. Just drill out the hole to 5/32" and hammer the insert in. Tighten up and you are good to go. I used this for a stripped Axial trans case. Saved me from replacing the case and holds much better. Wes |
09-02-2011, 09:12 AM | #4 |
Yep basically the course vs fine. I've actually haven't had too much bad luck with either, just that the binder(coarse) screw occasionally backs out even with an insert and some ca glue. And the standard .5 pitch threaded (fine) will occasionally just rip out. All of this is depending on application of course. Good idea with the inserts |
09-02-2011, 01:05 PM | #5 |
Inserts not my idea, just passing along. Been around mechanical stuff all my life and never head the word binder. Learn something new everyday. Wes |
09-02-2011, 02:02 PM | #6 |
| Eh just a part name by manufacturer. They use button head in place of pan head sometimes too. Not sure of the difference
09-02-2011, 02:18 PM | #7 |
09-02-2011, 02:27 PM | #8 |
09-23-2011, 09:21 AM | #9 |
The other thing to keep in mind is thread engagement. In hard materials (like steel) use at least 1 screw/bolt diameter engagement. In soft materials (brass, plastics) use at least 2 screw/bolt diameters engagement. Thread pitch is not much of a factor in engagement minimums. |
10-03-2019, 01:20 PM | #10 | |
Rock Stacker Join Date: Aug 2019 Location: Youngstown, OH
| Re: binder screws vs standard screws for plastic Quote:
Moral of the story? keep all your threaded holes clean from debris and don't over tighten them and they'll last a long time no matter the type. | |
