10-02-2011, 08:47 AM | #1 |
Pebble Pounder Join Date: Mar 2009 Location: Regina, Saskatchewan
| drilling square holes |
10-02-2011, 10:51 AM | #2 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Ive seen that before. Sure is cheaper than buying a square broach |
10-02-2011, 03:35 PM | #3 | |
Quarry Creeper Join Date: Oct 2011 Location: Detroit
| Quote: | |
10-02-2011, 06:34 PM | #4 |
Newbie Join Date: Jul 2011 Location: San Diego
It's gotta be on a weird end mill that has a spindle that moved around in time with the bit. I've used 3-flute end mill bits and they still make round holes. If you've got one of these end mills then you probably have a wire EDM. It'd be much more accurate and you can get a hole that is probably a bit more square. |
10-04-2011, 09:53 AM | #5 |
Newbie Join Date: Sep 2011 Location: Metro D
Not as pretty, but I have used a file to achieve a squared hole. |
10-04-2011, 10:02 AM | #6 |
I did a bit of research and it turns out this is not so new. A patent was issued for the design a hundred years ago, but this outfit is finally making a bit that works. Even though the hole is not perfectly square, it's VERY close. It looks like there are several sizes either available or planned. I could see a few different applications for something like this, though. |
10-04-2011, 10:49 AM | #7 |
Agreed that the spindle is wiggling around within certain parameters, its not just the tool. The slides before the vid show the toolpath as well. |
10-04-2011, 04:32 PM | #8 |
RCC Addict Join Date: Mar 2010 Location: Auburn, MI
Interesting. I am guessing there is an attachment that gives the tool the path, at that speed, to make the holes square. That means it will have a very finite range and I bet is VERY expensive. Still cool to watch.. Oh, BTW, go watch the old episodes of the new yankee work shop, Norm has been making square holes for a long time with one of these. Found this too... square hole drilling on a drill press - YouTube How to Drill a Square Hole - YouTube |
10-04-2011, 04:43 PM | #9 |
Norm is a badass, his fingers say he's been doing woodwork since long before I started watching him as a teenager.
10-04-2011, 04:52 PM | #10 |
I was making squares with circles when I was five using my Spirograph!
10-04-2011, 06:53 PM | #11 |
RCC Addict Join Date: Jul 2008 Location: San Diego
10-04-2011, 07:23 PM | #12 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
This was definitely good info thanks for sharing |
10-04-2011, 11:28 PM | #13 |
10-05-2011, 12:44 AM | #14 |
Quarry Creeper Join Date: Feb 2006 Location: Muskegon
I've been a machinist for year's, and have been seeing this for year's lol, it's just simultaneous X-Y axis movement, with a 15 degree corner. There is stil a round corner, and it's realistically simpler for the Hobbyist to use a broach in a press, or even a vice, or a file as was mentioned. But it is cool to watch. I program and set-up up 4-5 axis machines all the time, and when a big linear is running full bore in five axis's, it'll make you step back a bit lol. |
