Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: tube materials
Old 10-23-2011, 05:53 PM   #1
Default tube materials
Im trying to build my own tuber but im having trouble finnding some 3/16 tube material ive tried my local auto stores for 3/16 brake line but i dont want to buy all the brass fittings and seems no one can point me in the right direction.
pls help
weeble163 is offline   Reply With Quote
Old 10-23-2011, 06:07 PM   #2
pls help
Buy all the brass fittings?!?!?!
You aren't planning on using couplings for all the connections are you?!?!
Either braze it or weld it.
ScaleReady is offline   Reply With Quote
Old 10-23-2011, 06:30 PM   #3
by the longest brake line they have and just toss the fittings, straight line is yer best friend over coiled line .........bob
bob1961 is offline   Reply With Quote
Old 10-23-2011, 07:53 PM   #4
Oliver Custom Knives
Yea , you cant really buy it without the fittings on the ends , just toss em. And learn to braize.
Buy the longest one's they have , its the best deal.
DwaneO is offline   Reply With Quote
Old 10-23-2011, 08:27 PM   #5
thanks for the help, and no i did not plan on using couplings i do plan on brazing it.
Old 10-24-2011, 07:10 AM   #6
No idea what I'm doing
I've always preferred this 1010 steel tubing over brakeline. It brazes together much easier and it's a bit stronger. It does cost a bit more:
MSC 1010 Steel Tubing
After some talks yesterday though, I want to try something else next
C*H*U*D is offline   Reply With Quote
Old 10-24-2011, 07:41 AM   #7
I wanna find something cheaper to braze with. Safety silv is getting a little expensive for me.
Onebdgti is offline   Reply With Quote
Old 10-24-2011, 08:51 AM   #8
It can be pricey. The more you use it and the better you get, the less expensive it seems since your mistakes become fewer.
I have a chassis about halfway done, and I built it entirely from this small kit I found at Ace Hardware. Still have some left, but it probably won't be enough to finish it completely. Still not bad though for a $17 investment. I actually like the flux in this kit better than the Harris stuff.
Old 10-24-2011, 08:52 AM   #9
Use 1/16th brass filler rod.You will need a different flux than what safety silv uses.
hotwheels000 is offline   Reply With Quote
Old 10-24-2011, 12:02 PM   #10
What kind of flux?
Old 10-29-2011, 03:03 PM   #11
pls help
u can buy brakeline by lenght without the ends from any parts house. usually its on a roll and they just cut it to lenght. did this a few times when i had to run a few long brake lines on my trucks, i dont like using unions.
optikalillushun is offline   Reply With Quote
Old 10-29-2011, 06:07 PM   #12
What kind of flux?
I dont have mine with me, but it is just a powdered flux that you dip the hot brass filler rod into.
You can also by the rod pre fluxed...I prefer the self dipped,better control of how much flux you are using.
Lowes or home depot sell the pre coated.Your local welding shop will be able to tell you the type of flux you need for brass filler rod.
Old 10-30-2011, 06:09 PM   #13
I find that ProBind Brass flux Works on EVERYTHING!
It has been very helpful to me!
rockpanda is offline   Reply With Quote
Old 10-31-2011, 05:01 PM   #14
I bought something like 25 feet of coiled, uncoated brakeline from Advance for around the $20-$30 mark if I remember right, have had it for over a year. Its pretty easy to get the roll straight and I havnt wasted much. Measuring right is key.
mtdriver is offline   Reply With Quote
Old 11-05-2011, 07:34 PM   #15
What kind of flux?
borax works its ant and roach killer.
86zuk is offline   Reply With Quote
Old 11-05-2011, 08:07 PM   #16
I use BCup-3 and it seem to work pretty well. I paid $40 for one pound of rods.
Here's a picture of a joint.
justinhinger is offline   Reply With Quote
Old 11-06-2011, 12:25 PM   #17
Why would you try anything else. That tubing sounds and is just what the doc ordered. No coatings No seams. As for Brazing/Soldering:
I use Harris Stay Brite. Why ? Because you can solder with it getting the same strength as brazing with out effecting the metallurgy of the tube. I know Stay Brite is expensive. But it will solder stainless steel also.
You dont use very much once you get the hang.
Evan
SlickRockSpider is offline   Reply With Quote
