12-08-2011, 08:07 PM | #61 |
Quarry Creeper Join Date: Oct 2011 Location: Georgetown, On
| ill be sure to update if i have a revo fail. i like the idea of the thread engagement on the jato's. testing and time will tell!
12-09-2011, 05:05 AM | #62 |
Rock Crawler Join Date: Jan 2008 Location: Essex, UK
12-09-2011, 05:54 AM | #63 |
3 or 4mm. i dont remember, it was a truck i was running with. it was his steering link too lol.
12-09-2011, 06:27 AM | #64 |
Wouldnt advise this method then?
12-09-2011, 12:36 PM | #65 |
| well since it sheered clean off, the link couldnt be fixed easily. i think instead of tapping it, use a die and thread the rod. this give you one piece into the revo/jato end, and alot lees chance of breaking. i know ill be making a backup set of links for my crawlers in case something does in fact break. Vanquish does the threaded rod into revo ends technique. at about $2 a link, its 5X cheaper then anything else. you can also make them any shape, size length or color. i bought VP wraith upper links, its the last set ill ever buy. Making them is SOO easy its sad. vp= $75 shipped for 4 links home made = $10 for 4 links AT MOST. so i can make 30 links for the same price. now yes im using steel instead of titanium, but are you going to pay another $65 for that? dont get me wrong, they make great stuff. ill be running their chubs and knuckles, but thats because i cant make them with the tools i have. |
12-17-2011, 11:06 PM | #66 |
Rock Crawler Join Date: Dec 2009 Location: Redding
Made some links and steering arms for my Wraith today. Used the 8/32 thread with 1/4" tube as a sleeve. I used Jato ends for the suspension links and Revo ends for my steering links. Very stout. Can't see having to replace these anytime soon.
12-18-2011, 10:12 AM | #67 | |
Rock Crawler Join Date: Apr 2008 Location: Albany
| Re: How To: Make your own links Quote:
I have not used that big of a link, but I do the same thing and use set screws. Just like Axial. I have never seen a set screw break. Evan | |
12-18-2011, 10:30 AM | #68 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
What are the best ways to thread Titanium rod? Is there a special lube or does the die need to be made of a certain material?
12-19-2011, 04:44 PM | #69 |
Bump.
12-19-2011, 05:10 PM | #70 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
Good looking links OntarioCrawler. I was wondering what brands of dies you guys are using? Seems there are a lot of different ones but some seem to cheap to be any good. Bump on the info for making Ti links too... |
12-19-2011, 06:15 PM | #71 |
| Re: How To: Make your own links im using mastercraft ones. its a cheap set, but im only cutting steel. i polosh the links with a wire wheel on my drill press.
12-22-2011, 09:46 AM | #72 |
| Re: How To: Make your own links Thanks for the info. What about threading 1/4 rod to 4mm for some heavy duty links? Would you need to turn down the rod to be able to use the die? I've used taps but never a die so sorry if it's a stupid question.
12-22-2011, 09:57 AM | #73 | |
Yes there is a maximum O.D. for each tap to be able to start the threading process. I still would like to know what type of tap is used on Titanium? | |
12-22-2011, 10:11 AM | #74 | |
threading titanium rod | |
12-22-2011, 01:20 PM | #75 |
Rock Stacker Join Date: Nov 2011 Location: Arkansas
I just bought some 8/32" all thread and 1/4" steel tube and these rod ends: Traxxas Jato Rod Ends (12) with hollow balls (12) #5525*-*Miscellaneous*-*-Suspension*-*The Crawlers Store LLC The rods arent pre-threaded.. how will I need to thread these plastic rod ends for the all thread? Thanks! |
12-22-2011, 04:19 PM | #76 | |
12-22-2011, 06:35 PM | #77 |
Thanks! Any suggestions on what to cut the all thread with besides dermal.. anyone know if bolt cutters would work?
12-22-2011, 08:26 PM | #78 | |
i use a angle grinder with a cut off wheel in my vise. | |
12-23-2011, 01:04 AM | #79 |
bolt cutters did the job.. not the prettiest but it threaded and works. |
12-23-2011, 03:15 PM | #80 | |
Rock Crawler Join Date: Nov 2009 Location: Commiskey
Always made my own and never had one fail. 8/32 all thred and 1/4 brake like with REVO ends. I dont tap my ends tho, at lest not with a tap. I run a 8/32 screw down threw them then the all thred slides in snug. When you tap a hole your removeing material and never thought that was a good idea with a plastic hole. I also cut all thred with a roto tool and clean up my cuts so theres clean threds there from the start. If the end's boogerd from the start it's a PITA to get started in the rod ends and then I wouldn't trust the threds once that boogerd end got to the bottom of the hole. | |
