Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Hex set for power drill ?
Old 12-29-2011, 08:48 PM   #1
Default Hex set for power drill ?
I just bought a Ryobi TEK 4 power drill today. It's 4v and 1/4 drive.
Where can I buy some power hex bits for this ? I tried Home Depot, Sears. Loews etc and no luck . Would appreciate and info. Thanks
scrofcheck is offline   Reply With Quote
Old 12-29-2011, 10:15 PM   #2
Default Re: Hex set for power drill ?
My LHS sells some EDS brand "power bits", I don't recall if they were stricly srewdriver bits or if they were in fact hex bits. I guess I need to check into them next time I'm there.
Devil Inc is offline   Reply With Quote
Old 12-30-2011, 09:21 AM   #3
Thanks for the reply. I'll have to check my LHS. I don't recall seeing them but then again I wasn't looking for them at the time.
Old 12-30-2011, 09:25 AM   #4
I bought these from my LHS.
OFNA part#10824
helhedded is offline   Reply With Quote
Old 12-30-2011, 09:32 AM   #5
That's exactly what I'm looking for. Thanks
Old 01-09-2012, 08:13 PM   #6
How thin are the walls on the nut drivers? Everything I've found so far is just too big and I can't get to some of the nuts without taking a ton of stuff apart.
turdferguson is offline   Reply With Quote
Old 01-10-2012, 07:37 AM   #7
I can break out the calipers and give you exact ODs if you remind me. I won't be home until later tonight. Just shoot me a PM and I'll hook you up.
Old 01-10-2012, 10:16 AM   #8
I don't think that's necessary just wondering if they are thinner than what a standard hardware store cheapo nut driver if you've ever used those before. Some of them are just flat huge I guess to make up for the garbage metal they're made out of.
Old 01-10-2012, 10:41 AM   #9
Without any specifics I can't tell you. There are a ton of "standard cheapo nut drivers" and I'm sure that they are all different to a degree.
Old 01-11-2012, 10:19 AM   #10
For $30 I just bought them if the walls are to thick I can always turn them down. Now I can take the wraith apart without making my fingers raw from a standard hex wrench.
Old 01-12-2012, 01:09 PM   #11
These are WELL worth the cash. I have the associated set, and I am pretty pleased with them thus far
Team Associated Factory Team 1/4” Drive Power Tool Tip Set (5) [ASC1674] | Tools - A Main Hobbies
ev0l is offline   Reply With Quote
Old 01-16-2012, 05:51 PM   #12
HAM
Although this may not help, I have a 1/4' bosch impact and I use a 1/4' hex to 1/4' square adapter that i got a from a Dewalt 1/4' set (maybe $18 at the big orange box) so if you already have 1/4 square driven hex bit, that should work. Btw it also came with 1/4' hex to 3/8' sq, and 1/4' hex to 1/2' sq so it was pretty versatile .
HAM is offline   Reply With Quote
Old 01-17-2012, 10:05 PM   #13
i would guess they are as they are designed for r/c's ...i know what you snap-on driver barly squeezes in to loosen wheel nuts.
i have had my ofna's for 5 years they are tough, although i don't use them all the time. i like to dismantle using the power tooll, and hexes. For first time builds and assembly i like hex drivers to get the feel of tighten.
* although if you have a long 20+mm screw i use the power tool to run it in.
navyeoseabee is offline   Reply With Quote
Old 01-18-2012, 02:32 AM   #14
I have the Ofna's in the pic above, they are GREAT.
OD for the nutdrivers are:
4.5mm=7.00mm
5.5mm=7.90mm
7mm=9.45mm
OfnaJoe is offline   Reply With Quote
Old 01-18-2012, 01:18 PM   #15
I also have a Ofna set. My hands get bad after a while (carpel) so turned to a Black and Decker driver. After 4 years the battery is starting to go, so think it's time for a new one....
y2kgtp is offline   Reply With Quote
Old 01-19-2012, 12:14 PM   #16
Integy has a ton of sets, Allen only and with nut drivers. I have an Allen only set I purchased for $25. They work great!
Tbone25 is offline   Reply With Quote
Old 01-19-2012, 01:57 PM   #17
SuperShafty.com
this is awesome. american made. have hada set for years and love it. just make sure you get the hex set, comes with everything SAE and METRIC up to .25" ven a little ratchet which is awesome
Chapman 7331 27 PC Mini Ratchet Screwdriver Bit Set
if you have the money you can't beat these, ahve some of of these in the common sizes as well, they are milled to such tight tolerances you can take out bolts other wrenches strip.
MIP Hex Tools
mjderstine is offline   Reply With Quote
Hex set for power drill ? - Similar Threads
recommendation on power driver hex tip set? iamsuperbleeder Tools, and Procedures 10 10-11-2011 07:39 AM
Hex Drill bits Lemonlegs28 Tools, and Procedures 11 01-03-2011 11:08 PM
Hammer Drill Power Krawlin General Crawlers 29 08-01-2007 10:44 AM
hex drill bit Thorsteenster Tools, and Procedures 24 07-03-2007 05:05 PM
using a power drill motor? VTEC Electronics 6 02-13-2005 04:41 PM
