Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: silver soldering question
Old 02-21-2012, 06:29 PM   #1
Default silver soldering question
I was wondering what would be better, I'm working on a custom internal cage for my hpi bronc and was wondering if i should make mounts and bolt a custom cage to my scx10 frame, or if jointing it right to the frame would be better, i can understand working on it might be easier if the cage is removable, but working space isnt much of a concern to me, and i dont plan on changing the body to a different one. To me I would rather just joint it to the frame, any other suggestions? thanks
sliceofnoob is offline   Reply With Quote
Old 02-22-2012, 06:46 AM   #2
Default Re: silver soldering question
It is going to be stronger welded to the frame, but if you think you are going to change bodies a bolt on cage is your best bet. I would say most of the cages on here are permanent attached, but I have seen a few bolt on's as well. I brazed mine on because I knew it was going to stay that way.
punkfan is offline   Reply With Quote
Old 02-22-2012, 11:45 AM   #3
I myself want to do a bolt on cage on the back of my SCX just for the simple fact if I did want to change the body. What my plan was, was to put a flat flange on the end of the tube where it makes contact with the frame and have bolts on either side of the tube. Ive seen the bolt ons here and most have a flange with one bolt on one side of the tube. I figured having a bolt on both sides would be stronger, and really I think a brazing weld would break before a stainless bolt. Its really your preference and your plan in the future for that chassis, like you said you dont plan on changing so weld away.
offroad1911 is offline   Reply With Quote
Old 02-22-2012, 11:16 PM   #4
ok well im planning on welding it to the frame, has anybody used this before? it looks much more convienent but i havent seen anybody using it, only the separate flux Harris Products Group Safety-Silv 56 1/16 X 18 Flux Coated Mini Sticks (3-Pack) 56F318MPOP at The Home Depot
i also have to get my hand on one of those 3rd hand tools they look very handy.
Old 02-22-2012, 11:52 PM   #5
I've used the flux coated rod but I prefer the brush on paste and non coated silver solder. With the paste you can get it in between the parts so the solder flows a little better.
War Pig is offline   Reply With Quote
Old 02-23-2012, 05:13 AM   #6
DEFFINATELY HANDY!!! im on my 3rd one ive used it soo much. accadentally brazed or melted the other 2 while brazing or welding lol
heavychevy is offline   Reply With Quote
Old 02-23-2012, 07:49 PM   #7
Haha im hoping i can make one last awhile, i only have 2 scx10's right now with only 1 plan for a cage for now
Old 02-24-2012, 10:43 AM   #8
You should pick up a pack of 4 small welder magnets. They are small triangles with a 90, 45, 30 angles. Best 20 I ever spent when it comes to brazing. I also prefer the brush on flux and rolled safety silver. I tried the coated stuff, but it never gave me as clean a joint as the other. If you take your time and create tight joints you don't need much silver.
Old 02-24-2012, 10:14 PM   #9
ok good to know thanks for the tip!
Old 04-07-2012, 01:42 PM   #10
Not sure if I should start a new post or add to this one. My question is Lenox Premium Silver Lead Free Solder the same as Harris Stay-Brite kit?
Solder - Solder, Flux & Flux Removers | MSCDirect.com
snydercj7 is offline   Reply With Quote
Old 04-07-2012, 03:59 PM   #11
Decent question, I've tried a few of the "lead free silver solders" and have had poor results.
I have yet to try the harris, thus don't have a good comparison.
Charlie-III is offline   Reply With Quote
Old 04-07-2012, 05:51 PM   #12
Moderator
badhoopty's Avatar
i would advise the harris brush on flux with the harris safetysilv.
with the brush on flux you can control exactly where the harris will flow and like war pig said get the flux good and deep so the silver solder flows deep inside the joints. the harris brush on flux will liquify to a wet/clear state right before you should hit the joint with the rod and flow the solder, which is nice.
its remarkably easy to braze with just a mapp torch and the harris stuff once you get familiar with how hot to get things and get the feel of how the solder flows with the heat.
badhoopty is offline   Reply With Quote
Old 04-07-2012, 07:46 PM   #13
Good info thank you. Now.... Where do you guys buy your Harris Safetysilv?
Old 04-07-2012, 08:27 PM   #14
Ebay usually has kits with the silver solder and the correct flux. The only other place I know of would be welding supply places either online or there may be one close to you.
SMR 510RR is offline   Reply With Quote
Old 04-07-2012, 09:40 PM   #15
Moderator
badhoopty's Avatar
ebay or local welding place. i get mine from a local airgas welding shop.
The Harris Products Group - Distributor Locator
Old 04-07-2012, 09:52 PM   #16
Also decent price online with home depot. Safety-Silv 45 2-Piece Brazing Kit-45KPOP at The Home Depot
cherokee95 is offline   Reply With Quote
Old 04-08-2012, 12:05 AM   #17
shelljeep's Avatar
How small are they? Got a link?
I need something adjustable that I can use as a jig. Magnets would work well as long as they are strong but small enough to be out if the way.
shelljeep is offline   Reply With Quote
Old 04-08-2012, 07:06 AM   #18
I bought a kit from the local hobby shop but just seemed like a very little amount of solder. My Home depot did not carry so I can order. I will have to check out ebay. There is a local welding supply all of 8 miles away I will also check out. Thanks for all the input.
Old 04-08-2012, 09:40 PM   #19
you can get the two pack of these at Northern Tool for about $13
Strong Handİ Tools
Old 04-09-2012, 12:13 AM   #20
shelljeep's Avatar
That's super cool. Those look perfect for this stuff.
Thanks!
silver soldering question - Similar Threads
Old school Johnson silver can question. Meatbag Electronics 3 10-01-2011 08:22 AM
silver soldering vs brazing 93 FORD BRONCO Tools, and Procedures 51 10-08-2010 07:49 AM
help on brazing and silver soldering wk nut Tools, and Procedures 0 07-16-2008 08:03 PM
Silver Solder Question. EHeye Tools, and Procedures 1 04-25-2008 08:41 PM
