Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Machinists Corner
Old 06-12-2012, 07:40 AM   #181
Yashua
CREEPERBOB's Avatar
Default Re: Machinists Corner
I would try to stay away from a rolling table for the mill , I need to put 2 more diagonal braces on my mill table, at certain RPM's it want's to wobble or sway back and forth.
Originally Posted by Duuuuuuuude View Post
Yeah I know...I think I asked that question out of desperation when I already knew the answer. Looks like I'm going to have to put tables on wheels...
CREEPERBOB is offline   Reply With Quote
Old 06-12-2012, 11:03 AM   #182
Suck it up!
Duuuuuuuude's Avatar
The mill has its own stand, I'm going to put wheels on the tables I have now. Maybe. I'll wait to do anything drastic until I've actually got the thing. It may sit up high enough to slide the tables under each end of it. Don't want it to get too cramped though.
I think I've just got a serious case of TMS.
Duuuuuuuude is offline   Reply With Quote
Old 06-12-2012, 12:05 PM   #183
Yashua
CREEPERBOB's Avatar
I have the same problem, TMS , peg board helps a bunch for alot of the tooling and I bought a couple 3 tier metal shelves, The kind that slide over round tubing and have plastic insets to set height of each shelf, to sit at each end of my mill table, that way I can sit things off to either side witout walking away from the machine.
Old 06-12-2012, 04:28 PM   #184
Originally Posted by foratm View Post
Yes sir a fadal vmc 3016
Sent from my MB855 using Xparent Blue Tapatalk 2
We have a 3016 in our shop as well. I thought that looked like a Fadal pullstud.
4VRYNG is offline   Reply With Quote
Old 06-12-2012, 07:12 PM   #185
Suck it up!
I bought pegboard on the way home tonight, but its going to be a PITA because I've got a light switch, outlet, breaker box, and window to frame around.
Instead, I could slide my workbench down to the opposite end of the wall. That would give me tons of wall space around the mill and waaaaay less hassle to get it hung. But my god, is there a bunch of crap on/around/under/over that bench that is going to have to be relocated.
Old 06-12-2012, 07:22 PM   #186
Yashua
CREEPERBOB's Avatar
Looks like you could move that bench with the scroll saw and drill press and slide it right in there. Easy to run an outlet from that breaker panel.
I actually built a VERY sturdy wood workbench and it sits smack in the middle of my shop, that way I have a vise mounted on one corner and have room for my scroll saw, belt/disc sander and 4 sides to work from with a full shelf underneath.
I actually took a tablet and while I was waiting for my machine to arrive I probally drew 50 floor plans .
I see a model railroad layout started there, I used to be consumed by HO, had to get rid of it all, sure do miss them though.
Old 06-12-2012, 07:26 PM   #187
Suck it up!
I still need to be able to get a vehicle in the garage if I need to, so no big work benches out in the middle of the floor, though that would otherwise be ideal.
The two tables you mentioned have already been pulled out and turned sideways. The mill should fit between, but I'm not going to place any bets on it.
I still think moving the big bench all the way to the left would be ideal. I might try it tonight. I installed a new outlet there the other nite. Since I was knocking holes in wall I went ahead and doubled up on the plugs, and that would really be more beneficial over the bench then it would be behind the mill.
Old 06-12-2012, 07:33 PM   #188
Yashua
CREEPERBOB's Avatar
Good luck Chris, I know it's a bitch, cause you want the space to be permanent, and you've got some moving to do .
The pegboard is a big plus, I have quite a bit of my tooling on that and the rest on the 2 small 3 tier shelfs.
Old 06-12-2012, 07:38 PM   #189
Yashua
CREEPERBOB's Avatar
What's that hiding behind that flouresent?
Old 06-12-2012, 08:08 PM   #190
Suck it up!
A POS Colt Airsoft. If shooting close range on a curve is your thing, that's the one to get.
Old 06-12-2012, 08:13 PM   #191
Suck it up!
Got the bench moved and the back wall cut down to clear the breaker box. I think its going to be better. Somewhat less wallspace, but I can go higher up without worrying about the garage door track. Time to put up some pegboard.
Old 06-14-2012, 09:00 AM   #192
Yashua
CREEPERBOB's Avatar
How did it go?
Is this the Big day?
Old 06-14-2012, 09:13 AM   #193
Suck it up!
How did it go?
The battle continues. I've been pushing pretty hard this week, both at work and at home, so I dropped my pace considerably last night. Its coming along though. The mill arrives tomorrow evening after work.
Old 06-14-2012, 09:30 AM   #194
Yashua
CREEPERBOB's Avatar
That's the way to start a weekend . And have a friend handy, you'll need a extra set of hands.
Have your camera ready.
Old 06-14-2012, 09:19 PM   #195
Suck it up!
Loaded up and ready for delivery!
My gawd that thing is heavy, and the table it sits on isn't much better.
Got a box full of collets, endmills of various sizes/shaped/flutes, a drill chuck, and another box full of plastic scrap for me to practice on.
Should be at the house tomorrow evening. Can't wait!
Old 06-15-2012, 08:02 AM   #196
Yashua
CREEPERBOB's Avatar
Yeah buddy , today get a gallon of WD-40 and some scotch brite pads, and little wire brushes and some disposable gloves ready for it's bath.
Old 06-15-2012, 08:12 PM   #197
Suck it up!
Old 06-15-2012, 10:37 PM   #198
Yashua
CREEPERBOB's Avatar
Yahoo, lets see some chips .
Old 06-15-2012, 10:43 PM   #199
Suck it up!
He stayed long enough to run through a few things with me and take a chunk out of some delrin, then I pulled the endmill and collet out, unplugged it, and made myself swear that I wouldn't touch it until the garage was cleaned up. I then went in the house and had something to eat.
About an hour later I was out there goofing around with it.
Old 06-15-2012, 10:43 PM   #200
That's a perfect size machine for a home shop! Nice find.
War Pig is offline   Reply With Quote
Machinists Corner - Similar Threads
you Machinists can probly appreciate this... STANG KILLA SS Tools, and Procedures 41 05-14-2011 12:59 AM
Machinists..... mrpink Chit Chat 1 08-30-2010 08:31 PM
Question for the machinists out there... scally6 Chit Chat 12 12-03-2009 08:25 PM
Machinists...opinions? JasonInAugusta Tools, and Procedures 5 07-23-2007 11:00 PM
