08-31-2012, 05:10 PM | #321 | |
| Re: Machinists Corner Quote:
I wouldn't say it took balls to make that, though I get what you're saying. To me it kind of comes down to risk assessment. What am I going to be out if I screw it up? In this case, not much. The first step is always the hardest. Thank you sir. I think it'll do well, and I'm already planning on doing the other nut too. | |
09-02-2012, 01:47 AM | #322 |
Quarry Creeper Join Date: Jan 2009 Location: Estonia
Just out of curiosity, how much did you end up paying for the mill? I want one, but the locals here only deal with industrial grade heavy machinery. And I doubt online stores are willing to ship it. |
09-02-2012, 09:45 AM | #323 | |
I bet that if you poke around a bit you might find something locally. | |
09-02-2012, 11:54 AM | #324 |
Rock Stacker Join Date: Feb 2012 Location: Longview
| Re: Machinists Corner Sieg seems to ship directly from their factory in china to people in the US.. bet they'd do the same to someone in estonia.. or you might even give grizzly a shot
09-02-2012, 12:36 PM | #325 |
Ok, will take a look there. Thanks
09-07-2012, 03:56 AM | #326 |
I was wondering today. What accessories should a lathe owner/user own? I have dial indicators 0.01mm and 0.005mm accuracy along with a magnetic base. Quickchange toolpost. Some HSS material for grinding tools, some carbide cutters. Drilling chuck for the tailstock along with drills and endmills both HSS and carbide. 3-jawed chuck(w. internal and external jaws), micrometers 0-25mm, 25-50mm, internal snapping gauges. Standard and digital calipers. Oh and a few dead centers and one live center for the taikstock. I know I should get a independent 4-jawed chuck, but what else should I need. A faceplate maybe? |
09-07-2012, 11:13 AM | #327 |
Rock Crawler Join Date: Oct 2007 Location: south of France
hi guyz I just want to say I back to school (I'm 34) just for learning milling on a CNC |
09-16-2012, 12:31 AM | #328 |
Quarry Creeper Join Date: Nov 2009 Location: Central Arkansas
I'm glad this thread exists! I started back to school this fall in machining and I'm sure I'll have questions in the future. The program I'm in covers metallurgy, hand mills/lathes, 3d modeling (solid works), tool pathing (mastercam), writing g-code, and CNC mills/turning centers. I hope to learn as much as I can in school and continue to learn as I enter the field of machining.
09-16-2012, 01:32 AM | #329 | |
Other than that, a knurling tool, threading tools (ID and OD), I think you have most of the major stuff. | |
09-17-2012, 08:32 AM | #330 |
I have a lathe that seems to be chinese origin. I believe it doesn't have a drawbar. Usually I do hobby stuff, but sometimes I have to rebuild some gardenmachinery. Like wheels and motor parts and such. Things wont go above 10'' usually. So far I haven't don threading so I might hold on those things. But where to get a good knurling tool? |
09-19-2012, 11:10 AM | #331 | |
Most of the schools around here seem to think its necessary that you learn all forms of metalworking, which means they mass-produce piss poor machinists/blacksmiths/welders. If you're spending the time to learn solidworks, I think its worthwhile to learn one of the integrated CAM packages. | |
09-19-2012, 11:52 AM | #332 | |
I have had good luck with purchases from shars, a quick search for knurling returns a bunch of options. shars.com This one is cool, does a bunch of different patterns, cant say how well it works though. Should be fine for hobby stuff. shars.com - Swivel Knurling Tool Holder You will have to verify that the ones built into a holder will fit your toolpost (I am assuming that you have a QC toolpost already, if not that is your next investment). | |
09-19-2012, 01:21 PM | #333 |
Yeah, I bought the multifix QC toolpost. I like the multipurpose knurling tool. Have to look whether they ship worldwide. Thanks for the info. |
09-19-2012, 05:42 PM | #334 |
Rock Crawler Join Date: Apr 2009 Location: Pa
I much prefer pinch knurling tools (scissor type) especially on manual lathes. The cheaper push type knurlers put a lot of unnecessary force on the lathe as well as the workpiece. On really large diameter you do not have much choice though.
09-19-2012, 06:31 PM | #335 |
| Re: Machinists Corner Didnt realize you were not in the US, I am sure there are some machine tool distributors in your area that could help you track down whatever you need. There may be a european distributor similar to shars, everyone knows the swiss take machining seriously so cant be too hard to get something closer than the US.
09-20-2012, 10:14 PM | #336 |
Newbie Join Date: Jul 2012 Location: Vista
You might mention SHARP cutting edges/tools
09-21-2012, 05:53 AM | #337 |
Pebble Pounder Join Date: Apr 2012 Location: Brisbane, Australia
hi guys im not sure if im in the right area for this question...... but i have a xr10 with axial cnc light weight gears. im trying to drill out the existing holes to around 3mm for weight saving. what sort of drill bit should i be using, i have snapped two standard drill bits so far. Thanks Steve |
09-21-2012, 06:00 AM | #338 | |
I've got a STUBBY! Join Date: Apr 2011 Location: Newcastle Australia
I drilled mine out with a carbide tip drill bit. It was like a hot knife through butter Quote:
09-21-2012, 06:05 AM | #339 |
| Re: Machinists Corner |
09-21-2012, 06:52 AM | #340 |
That's where I got mine from
Machinists Corner - Similar Threads | ||||
you Machinists can probly appreciate this... | STANG KILLA SS | Tools, and Procedures | 41 | 05-14-2011 12:59 AM |
Machinists..... | mrpink | Chit Chat | 1 | 08-30-2010 08:31 PM |
Question for the machinists out there... | scally6 | Chit Chat | 12 | 12-03-2009 08:25 PM |
Machinists...opinions? | JasonInAugusta | Tools, and Procedures | 5 | 07-23-2007 11:00 PM |
