![]() | #361 |
Newbie Join Date: Feb 2012 Location: Australia
Some very good info above! But, just to clear a few this up, MMAW (stick), GMAW (mig) and GTAW (tig) all use shielding gases, but MMAW gets its shielding gas by burning the electrode covering and converting it into a gas to shield the weld pool. Hence why they weld like crap when the coating comes off. GMAW and GTAW use gases direct from bottles to aid the welding process. There is also a difference between "flux cored" wires and "inner shielded" wires. A pure "wire feeder" machine will only support the use of inner shield wires and they weld like crap too, where as a proper GMAW machine will use both solid core and flux cored wires along with gas to produce the right weld. A GMAW machine will run innershielded wires too, just dont bother hooking the gas up. GTAW would be you best bet if you have a steady hand and some patience as they require very little in the way of grinding after welding, are very precise, so theres big big ugly weld on your rig. Theres also no spatter.......so no fires! And the best part is they are clean and quiet! Good for late night building without upsetting the neighbours / wife. Last edited by THE411; 10-12-2012 at 09:15 PM. |
![]() | #362 | |
Newbie Join Date: Aug 2012 Location: grande prairie
| ![]() Quote:
Also you should be safe about what gasses you are using and in what position some will be heavier than air and some lights and some can act like both! | |
![]() | #363 |
LOL! when i saw your SMAW. l was like wtf, i had never heard that before. Must be an american thing. lol As far as the gas goes, Argon is the gas of choice for tig welding for 99% of the users on here and will cover most steel types. And Argoshield 51 for mig welding of carbon steels, with stainless steel and aluminium requiring different gases. |
![]() | #364 |
Excellent info guys, answers a lot of my questions. Thank you. ![]() ![]() ![]() [I knew we had welders here, thus why I asked.] |
![]() | #365 | |
| ![]() Quote:
![]() If anyone here is trying to mig RC stuff i suggest not using oxygen in your gas as it will make the arc really hot and "wet" the edges more which on thin material causes it to melt through and gives a hole. | |
![]() | #366 |
Im actually a Welding Inspector.... ![]() |
![]() | #367 |
Quarry Creeper Join Date: Nov 2011 Location: Kentucky
I didn't have time to read all 19 pages and searching didn't turn up anything that I could use so Im asking. If this has been asked before feel free to link me back to it. Im having trouble making links from 8/32 all thread and 1/4" stainless steel tubing. They keep coming up slightly off from one another, so my question is = Can I use a tap and die set on solid stainless rod to thread a end down to 8/32"? That way I could put the bends in it via a home made tubing bender THEN cut and thread then ends at the lengths I want instead of bending them after cutting and mounting the REVO rod ends. Not sure how Im coming up different everytime, but I am. Thanks in advance. Don |
![]() | #368 | |
I wanna be Dave ![]() Join Date: Dec 2009 Location: San Francisco
| ![]() Quote:
On the other hand I have a much simpler solution for you. I use revo rod ends on one side and the longer Traxxas rod ends (Jato I believe) on the other. Make the links about 1/8" longer than you really want them and then trim the long rod ends to get to the right length and even them up. I also bent mine with the tubing long and trimmed it back with a dremel, worked quite well and they were just about perfectly even when I was done. | |
![]() | #369 | |
Rock Stacker Join Date: Feb 2012 Location: Longview
| ![]() Quote:
and mcmaster has 303 stainless in 5/32" for $6.44/6ft.. http://www.mcmaster.com/#standard-st...l-rods/=jrhjtl | |
![]() | #370 | |
| ![]() Quote:
![]() | #371 |
Rock Crawler Join Date: Apr 2009 Location: Pa
If you want stainless tube and plan to weld it go with with 304 or 316. You can weld 303 (have done it several times myself) but it craters easily and is not as strong at the weld joint. Free machining steels and stainless steels usually do not weld good. I bought some 304 tube from McMaster to build some sliders and bumpers with. Going to TIG them together.
![]() | #372 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
Anyone here watch any of the Keith Fenner videos on YouTube? He really walks through a lot of the processes he uses doing different jobs. Mostly old school machines and and knowledge mixed with some modern stuff.
![]() | #373 |
Quarry Creeper Join Date: Jul 2004 Location: Arkie-Saw
| ![]() Yup. Im a subscriber. Working my way back to the beginning. I watch his videos a couple times a week. Great guy.
![]() | #374 |
Quarry Creeper Join Date: Jan 2009 Location: Estonia
Same here. Mr Keith Fenner and also Mr Pete who is known in the videos as Tubalcain. They really know their stuff. |
![]() | #375 | |
| ![]() Quote:
![]() | #376 |
Suck it up! ![]() Join Date: Mar 2008 Location: Arkansas
So here's a helpful tip: if you leave your drawbar wrench laying on the belts while you are changing bits/collets, don't forget to remove it before switching the machine on. I did that very thing last night. Twice. ![]() On the first time, it sucked the wrench into the pulley and spit it out (thankfully) towards the wall. Knocked a bunch of crap off of the pegboard and the shelf above it. Had to dig the wrench out from behind some shelves. Didn't hurt the machine at all, but there is a nice black skid mark on the wrench. Chalked it up to a stupid mistake. Lesson learned. Or so I thought. On the second time, it sucked the wrench into the pulley again, only this time it spit it out over my head (just barely) and threw it into the garage door. Its a good thing I was stooped over when I flipped the switch, which, by the way, got snapped off as the wrench was going through the pulley (lucky it didn't get my hand too...). I found the broken end on the other side of the garage. Chalked it up to me being tired and a dumbass and made it my final tool change of the night. |
![]() | #377 | |
Rock Crawler ![]() Join Date: Apr 2008 Location: Albany
| ![]() Quote:
When I was in HS I was taking a machine tool class. I left the chuck key for the lathe in the three jaw. I did not turn it on but the teacher saw it and came right over and duct taped the chuck key to my hand for the rest of the class. lol I learned my lesson. 15 years of machine tool work and I still remember. ![]() Evan | |
![]() | #378 | ||
| ![]() Quote:
![]() ![]() ![]() Quote:
![]() Same for chuck keys in a drill press. ![]() I spent 20+ years working on production machines, I still have all my fingers & toes (although I have a few scars as well.) PS....duct taped key to hand.... ![]() ![]() ![]() ![]() | ||
![]() | #379 |
Quarry Creeper Join Date: Nov 2007 Location: Alberta canada
So, where does an IDIOT like myself start when thinking about buying a milling/drilling/lathe combo? I ran a lathe in highschool but basically remember nothing from it, other than don't leave the damn chuck key in the chuck lol. Kinda what I am looking for is a handbook designed for people like myself. I need to know simple things like terminology before I can start doing anything...
![]() | #380 |
Go to a college/city library and look for machining books. Most of the terminology and technique are old. So you should find some instruction there. The Machinery's hand book has everything you have ever wanted to know about machining. From simple lathe turning, cutting gears, and grinding tools. When looking most people say buy the biggest you can afford. Keep in mind that tooling is a very important part of your machine. Don't spend your self dry before buying tooling. Evan |
you Machinists can probly appreciate this... | STANG KILLA SS | Tools, and Procedures | 41 | 05-14-2011 12:59 AM |
Machinists..... | mrpink | Chit Chat | 1 | 08-30-2010 08:31 PM |
Question for the machinists out there... | scally6 | Chit Chat | 12 | 12-03-2009 08:25 PM |
Machinists...opinions? | JasonInAugusta | Tools, and Procedures | 5 | 07-23-2007 11:00 PM |
