08-10-2013, 09:31 AM | #401 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
| Re: Machinists Corner |
08-10-2013, 07:37 PM | #402 | |
| Re: Machinists Corner Quote:
Concerning the centering of parts...I need to come up with some sort of vice that I can clamp stuff into and then center it all on the table. I've brainstormed a few things, just need to come up with material to do it. | |
08-10-2013, 08:00 PM | #403 | |
I used to just put an offset dial indicator (can't remember the actual name) in the mill and spin it in the table center hole. That got the table centered. Once a part is close to clamped up, use the same indicator to center it on the table before final clamping. Ahhh....found something similar..... WESTWARD Test Indicator, 1 1/2 In Dia, 0.06In - Dial Indicators - 4KY12|4KY12 - Grainger Industrial Supply Last edited by Charlie-III; 08-10-2013 at 08:03 PM. | |
08-10-2013, 08:03 PM | #404 | |
08-19-2013, 06:11 PM | #405 |
Newbie Join Date: Jul 2013 Location: Salem
I found this and I am wondering if it would be worth buying? Wilton 3 Axis Tilting Vise — 2in. Jaw Width, Model# TLT/SP-50 | Drill Press Vises| Northern Tool + Equipment at the moment I do not have a mini mill an was thinking this might help with my drill press. |
08-19-2013, 06:21 PM | #406 |
they have a 3", 4", 5" & 6" also just not sure which size would be best for the rc hobby. I am thinking 5" but just trying to get a little feed back if possible. thanks
08-19-2013, 06:57 PM | #407 |
What are looking to do? $300 is quite a bit to spend if you can't really use it to it's potential.
08-19-2013, 07:15 PM | #408 |
MFDesigns Join Date: Feb 2009 Location: ValleHOE
08-19-2013, 09:44 PM | #409 | |
Rock Crawler Join Date: Oct 2012 Location: Casper
09-23-2013, 10:40 PM | #410 | |
Rock Stacker Join Date: Sep 2012 Location: San Diego
If you get proficient on your mill you can make one. Making tooling for my mills and lathe is one of the most rewarding things I use them for. With a mill the possibilities are endless. Just google bench top mill projects and you will be amazed at what people do with minimum tooling. Paulzox | |
09-25-2013, 07:39 PM | #411 |
I wanna be Dave Join Date: Sep 2009 Location: n. palm beach
09-25-2013, 07:57 PM | #412 |
Pebble Pounder Join Date: Oct 2007 Location: Barnesville
Have any of you guys ever tried out the 6 in 1 machines ??? I'm guessing at the cost they are very limited to what they can do ? I'm looking for a metal lathe to get started but don't have a ton to sink into one been watching craigslist but nothing yet sent from old rotary phone using tapatalk |
09-25-2013, 08:39 PM | #413 | |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
Which version did you get? I run bobcad at my shop and its a great program. We've been using it for a while now and the newer versions (24 or 25) are far better than the older stuff. The new interface with solidworks is awesome and we run it with the 4th axis programming and it works flawlessly so far! The training vids are decent but you can find a lot more useful info on YouTube ESP if your just starting with it. Check out their page on there you won't regret it. --Dan | |
10-13-2013, 10:43 PM | #414 |
Quarry Creeper Join Date: Nov 2007 Location: Alberta canada
So I haven't been around much, I bought my mill and lathe last december. The mill has hardly been touched, very limited knowledge with it and just not a lot of time for projects. The lathe has seen a bit more use, nothing crazy just making tools and bearing installers for working on my quad ect ect. I did just order some acetal to play with, nice and soft just to get my bearings on the mill, and play a bit more on the lathe. My question is, once I have an endmill in the mill, what is the easy way to get it out? I know to loosen the nut/bolt on top and give it a few taps with the hammer but once I get the collet loose the endmill is still jammed in there. Even once the collet is out of the damn mill it seems to be a fight lol. Edit: I see this thread has moved a lot since...Well, last december! Haha, hopefully we can change that... Last edited by Slowkrawl; 10-13-2013 at 10:54 PM. |
10-14-2013, 12:19 AM | #415 |
Loosen the drawbar, tap it so there is no tension on it, then twist and pull the end mill out. Be careful that you don't cut yourself. Make sure the end mills and collets (inside and out) are kept with a very light film of oil or wd40. This will keep rust away and make them easier to work with. |
10-14-2013, 12:23 AM | #416 |
Drawbar...That's the term I was looking for but couldn't remember. You guys and your fancy projects, and here I am just trying to remember all the lingo LOL. Will do on the oiling, I'll have to give it another go tomorrow maybe. It's been a couple months since I used it last and I recall the endmill causing a few curse words trying to get it out. Also, how would one go about centering the tailstock to the chuck on the lathe? I haven't touched the tailstock since I bought it and I assume it's not dead on..I want to be able to drill holes and such. |
10-14-2013, 11:37 AM | #417 | |
There is usually some sort of alignment pin or set screw that keeps the collet from spinning, that is usually adjustable that can make the collet too tight, and if the coolet has been crushed at all it will be tight on the EM. And as for the tailstock, if you have a center that fits the headstock taper slide it in and then put a live or dead center in the tailstock, slide the tailstock towards the chuck / headstock and align the two centers. Quote:
10-14-2013, 06:04 PM | #418 |
I will have to pick up some centers, any advantage to live vs. dead? And I will have to pull the chuck right off if I am following you correctly right? My mill doesn't have a lock or brake I guess was my main problem while trying to change endmills it is kind of a gamble to get the collet unthreaded. I can take pics if it would make more sense. |
10-14-2013, 06:15 PM | #419 |
There used to be a set screw in the collet holder itself, but A: It wouldn't touch the collet to adjust how deep it went in the holder anyways, and B: you'd have to pull the holder right out of the mill every time you wanted to change collets. Or am I an idiot for thinking you can change endmills with the holder still in the machine?
10-14-2013, 06:31 PM | #420 |
Are you putting the endmill in a collet or in a solid endmill holder? They are two different things...
Machinists Corner - Similar Threads | ||||
you Machinists can probly appreciate this... | STANG KILLA SS | Tools, and Procedures | 41 | 05-14-2011 12:59 AM |
Machinists..... | mrpink | Chit Chat | 1 | 08-30-2010 08:31 PM |
Question for the machinists out there... | scally6 | Chit Chat | 12 | 12-03-2009 08:25 PM |
Machinists...opinions? | JasonInAugusta | Tools, and Procedures | 5 | 07-23-2007 11:00 PM |
