![]() | #41 |
I wanna be Dave ![]() Join Date: Dec 2009 Location: San Francisco
| ![]() Im sure if you spent enough time on google you could find something. For my purposes McMaster has decent information on the strength of different materials.
![]() | #42 | |
I wanna be Dave Join Date: May 2006 Location: akron
| ![]() Quote:
Guide to Buying Alloy Steel Online | Online Metals Guide to Selecting Metals for Your Project Last edited by sloppy; 03-15-2012 at 06:40 PM. | |
![]() | #43 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
One thing no one really mentioned but I think is handy is i'd much rather have 2, 4" vises than 1, 6" vise on my machine. Strictly because the 2, 4" vises fit easier onto a tiny machine table and let you hold longer work easier than the 6"... Mind you that's for a tiny machine that can't handle 2 massive vises on it for supporting work ![]() And "soft jaws"... what would I do without them. Primarily they are aluminum, sometimes steel... but they are crazy handy for cutting fixtures or for that accidental moment when end mill kisses vise ![]() ![]() |
![]() | #44 | ||
Quarry Creeper Join Date: Nov 2011 Location: Kentucky
| ![]() Quote:
![]() | #45 |
Newbie Join Date: Feb 2012 Location: Sacramento
So much good info!!!!
![]() | #46 | |
| ![]() Quote:
You have to be careful with aluminum jaws though, if your part is small enough they will start pushing into the jaw if enough clamping pressure is applied (assuming your part is harder than the aluminum jaw). I used to cut a lot of custom fixtures in aluminum jaws, the real problem is that the top of the jaw will push more than the bottom and then your part will start lifting and not sitting flat in the fixture, if you dont stay on top of it they will be way off before you realize what happened. We eventually started cutting our own soft jaws out of 7075 rather than buying the 6061 jaws and that helped a lot. One trick I liked to use if I was going to remove and use the custom cut jaws again was to mill 2 or more slots in the Y axis to use for alignment. I would run a pair of .25" slots one on each side of the jaw and then use gauge pins to align the jaws before locking them down. The next step above soft jaws is to cut a custom fixture that you can just clamp in the vise using Mitee-bits to lock the parts down. That was very handy when running a second op on a bunch of small parts at once, you can pull the fixture out and load it then put it against a stop and run it. Of course you can make 2 fixtures and load one while the program is running to save some extra time. Last edited by SMR 510RR; 03-15-2012 at 09:59 PM. | |
![]() | #47 |
![]() | #48 |
Rock Stacker Join Date: Feb 2012 Location: Longview
Those glacern videos are done on the same mori-seiki duracenters I use for prototype work ![]() as for the materials question, I dont believe there is a more thorough resource than matweb.com. It may be overkill, and theres a good chance you'll find comparisons on mcmaster easier to follow. Realize that heat treatment plays a significant role in how strong one material is compared to another, so be sure you're comparing apples to apples. Also, as a general rule, when a materials hardness increases, its machinibility decreases. I typically stick to 6" vises, but for hobby size machines, a double-acting Chick 4", or two, is hard to beat. Check ebay, they pop up once in awhile. I recently discovered the glory of reverse vises, and dream of changing all of mine over. ![]() oh the years of backstrain I could've avoided. ![]() ![]() |
![]() | #49 | |
| ![]() Quote:
![]() | #50 | |
| ![]() Quote:
![]() One good tip when making fixtures is to store them with a piece of wood, few sheets of cardboard... between them and DO NOT DROP THEM... heck I still have some old rim making fixtures from a while ago ![]() ![]() | |
![]() | #51 | |
Yashua ![]() Join Date: Sep 2010 Location: Learn the parable of the fig tree
| ![]() Quote:
![]() ![]() After much reading and calculating I think I have it figured out. For the gear I want to cut I need a 14 pitch #2 cutter for my 5.131 PD gear with 72 teeth. I will also have to buy an R8 arbor to fit it, I'm guessing it will also work for slitting saws etc. as well. | |
![]() | #52 | |
I joined the Band! Join Date: Feb 2012 Location: bay area
| ![]() Quote:
![]() | #53 |
![]() | #54 |
sweet! did you get a 4 jaw chuck for it yet? That's one of my next purchases for my 44142. I wonder if the spindle indexing ring and bolt circle are compatible between your smithy and my harbor freight. as of right now I have seen some people make adapter plates for the 44142 to run a 6" 4 jaw but I don't think there is an off the shelf unit that will just bolt up. Also the 5c hex collet block mentioned seems like a good purchase for converting my 3 jaw to a collet chuck. I had been tempted to fabricate some kind of drawbar system for an r8, but I like the simplicity of the hex collet block ![]() |
![]() | #55 | |
| ![]() Quote:
I have a D1-4 mount on my spindle, but was suprised that all 4 chucks, (1-4" 3 jaw, 2 6" 4 jaw and 1 6" 3 jaw) that fit my Logan lathe will all thread onto my dividing head. I have already got the 4" one cleaned up like new , ready for that. | |
![]() | #56 | |
| ![]() Quote:
![]() | #57 | |
Rock Crawler ![]() Join Date: Apr 2008 Location: Albany
| ![]() Quote:
They way I use collets is in a collet chuck. The idea with collets is you dont have to do the hole job in one set up. You can remove and replace the collect or work piece with out loosing much concentricity with the spindle. If you remove the collet block from a three jaw there goes the set up. Most parts you dont have to worry or mess around with. The other great thing about collets is production. They repeat very well. A collet block (4 sided or 6 sided) great for putting flats on a round part. Or making a custom bolt head. I just put the block in my vice and go to town. Peace my friend and have fun. Evan | |
![]() | #58 |
Here is a pick of the Logan I'm rebuilding. It looks exactly like this pic from the manual for it. ![]() |
![]() | #59 |
Now I understand...... have fun. i love rebuilding machine tools/equipment. Evan |
![]() | #60 | |
| ![]() Quote:
![]() Of course with the correct blank you can just turn/mill the gear to the specs needed for your project. Im thinking about getting a couple sticks of gear wire to make transfer case gears out of. The going price on the finished gears seams to be $7-10 and a 1' length of the rod is ~$20 and I could make quite a few out of that. Now I just need to figure out a good way to hold the gear in my new rotary table to finish it up, 5c collets would probably be the best bet but I dont have any so I have to do some thinking. I am thinking that I may just cut a little fixture or pair of soft jaws to hold it so I can drill the center hole since that is the only real crucial operation I need to do. | |
you Machinists can probly appreciate this... | STANG KILLA SS | Tools, and Procedures | 41 | 05-14-2011 12:59 AM |
Machinists..... | mrpink | Chit Chat | 1 | 08-30-2010 08:31 PM |
Question for the machinists out there... | scally6 | Chit Chat | 12 | 12-03-2009 08:25 PM |
Machinists...opinions? | JasonInAugusta | Tools, and Procedures | 5 | 07-23-2007 11:00 PM |
