04-16-2012, 06:06 PM | #1 |
Quarry Creeper Join Date: Sep 2009 Location: Detroit
| Dont want to spend more than you need to on some mysterious gear lube?
Then do what I did, figure out what the application needs and go from there. I dont have a good feeling paying $15 for a syringe of a mysterious "gel" that claims to be the best when I know it came in another container to begin with and isnt anything but EP lube that's been around for a long time. The blue VP grease is a joke and after looking at what you get in the form of "gel" or "jelly", I remembered what I use to build engines with. http://cmdlubeoil.com/extreme_pressure_lubricants.html And for a price comparison: Livernois CMD Anti-Scoring Extreme Pressure Lube #3 - Livernois Motorsports It's a little bigger than a tube of tooth paste. Much more reasonably priced and enough to build quite a few engines, put all over your RC car gears and whatever else needs the good stuff! I've been using it for a few weeks and just like the "best" stuff out there, it stays on the surface you put it on and doesnt sling off much at all. |
04-16-2012, 06:27 PM | #2 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
| Re: Dont want to spend more than you need to on some mysterious gear lube?
I didnt spend no more then 3 bucks on the lube on my scaler an comp. Marine grease at walmart 2.99 3pack!
04-16-2012, 08:05 PM | #3 |
This isnt your standard wheel bearing grease, marine grease or anything else you can get at wally world. But, since you didnt click any of the links, I'll put it here: "CMD anti-scoring lubricants are not ordinary lubricants. They are compounded of highly refined petroleum products containing no lead, graphite or minerals. They will not corrode the finest surfaces nor will they mulsify with cooling liquids. But these facts are not the most remarkable feature of CMD lubricants. The truly outstanding property of CMD is its ability to withstand extreme pressures! The thousands of firms who have used CMD have discovered that commonly used lubricants will provide a lubricating film at pressures of 500, 1000, 5000 and even 10,000 psi. By contrast, CMD EXTREME PRESSURE lubricants are regularly used from 40,000 to 50,000 psi." |
04-16-2012, 08:13 PM | #4 |
But i did read the links. everyone has their opinions
04-16-2012, 08:47 PM | #5 |
I use spit.
04-16-2012, 08:57 PM | #6 |
I wanna be Dave Join Date: Jan 2008 Location: Arat Alabama
| Re: Dont want to spend more than you need to on some mysterious gear lube? |
04-17-2012, 09:30 AM | #7 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i have been using red and tacky valvoline wheel bearing grease with good results........bob .... |
04-17-2012, 12:54 PM | #8 |
Mobile crimson works awesome for me and does not sling either. Super hard to get off once applied.
04-18-2012, 12:22 PM | #9 |
04-18-2012, 08:19 PM | #10 |
Newbie Join Date: Nov 2010 Location: Canada
+1 for the Valvoline Red and Tacky, great stuff |
Dont want to spend more than you need to on some mysterious gear lube? - Similar Threads | ||||
Help, I lost a screw and nut out of my front diff. Dont want to spend $30 on part kit | nexgen91 | Axial SCX-10 | 3 | 03-21-2011 05:23 PM |
axle gear lube, what do you use? | tombs | Redcat Crawlers | 2 | 04-14-2010 02:59 PM |
gear lube | gearstripper | Newbie General | 19 | 01-28-2010 01:20 PM |
Gear Lube!!! | JeeperoManiako | General Crawlers | 3 | 04-14-2006 12:32 AM |
Gear Lube? | PastryLikeDood | General Crawlers | 3 | 03-30-2005 06:25 PM |
