04-22-2012, 09:04 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Near my tools
| Tubing fish mouth
What is the best way to fish mouth tubing? I have 4mm tubing.. Tyo |
04-22-2012, 09:34 PM | #2 |
Pebble Pounder Join Date: Feb 2012 Location: De Leon
| Re: Tubing fish mouth
rat tail would be your best bet,more precise then a dremel, and everyone likes a nice tight fit joint rather then a sloppy loose one ;)
04-22-2012, 09:52 PM | #3 |
Rock Crawler Join Date: Mar 2011 Location: sebastopol
Rat tail file,or chainsaw file,pretty much the same thing.Come in all sizes. |
04-22-2012, 10:26 PM | #4 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
Bench grinder.
04-23-2012, 11:22 AM | #5 |
REST IN ALOHA CHIP Join Date: Nov 2005 Location: *
| Re: Tubing fish mouth |
04-23-2012, 12:06 PM | #6 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
as said bench grinder then clean it up with 3/16" chain saw file ........bob .... |
04-23-2012, 03:28 PM | #7 |
Moderator Join Date: Jan 2004 Location: chicago
i notch with a dremel cutoff wheel and then finish the fishmouth with a 3/16" dremel chainsaw sharpening bit. its a little bit costly but fast and pretty accurate... |
04-23-2012, 03:47 PM | #8 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
I just use a triangle file to put a small groove in the center then a rat tail to make the notch. It really doesn't take long at all once you get the hang of it. Just put the tube in vice with very little sticking out so it doesn't get a bunch of flex.
04-23-2012, 04:27 PM | #9 |
Newbie Join Date: Feb 2012 Location: gallatin
hand grinder with a flap disc is the best method. this is my opinion from building dirt late model chassis when a end mill is not available.
04-23-2012, 04:47 PM | #10 |
04-24-2012, 05:05 PM | #11 |
How long did you guys fish mouth with rat tail file? I have tried 10 minutes one fish mouth
04-24-2012, 06:12 PM | #12 |
shouldnt take but a few minutes,thats thin wall stuff and should notch like butter.
04-24-2012, 07:51 PM | #13 |
RCC Addict Join Date: Jan 2007 Location: caldwell,idaho
04-24-2012, 09:38 PM | #14 | |
| Re: Tubing fish mouth Quote:
I just put a dot with a marker on either side to indicate the direction I want it to go and line those up in the vise so I have a reference line when filing. The triangle file and grinder do the same thing. But my grinder isn't right by my bench and it takes forever to get up to speed so I use the file. | |
04-25-2012, 08:45 AM | #15 | |
05-03-2012, 10:26 AM | #16 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
i just use a chainsaw file. even with thicker walled stuff i can get a nice fishmouth in a couple minutes. |
05-03-2012, 09:47 PM | #17 | ||
And does the chainsaw file a triangle one? | ||
05-03-2012, 10:16 PM | #18 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Thanks for the picture mjderstine....I had no idea what this was about You learn something new every day....love this hobby |
05-04-2012, 06:41 AM | #19 |
05-04-2012, 08:27 AM | #20 | |
i use 3/16, as that is the dia of the tube i use. and yes there is also 1/4. the constant diameter is the best part since you never had to tweak it a lot. a rat tail file is a bit tapered towards the point, so you joint could be much less precise. i dont start the mouth with a triangle file. just the chainsaw file. wear a leather glove on the hand that is holding the piece that is being filed too. it creates a lot of heat when you file these fish mouths, and you can even start to feel it through the leather glove. guys will also use a vise to hold the piece. but i feel like i have more control with it in my hand (that's what she said ) ah and since the chainsaw file is designed to sharpen, it will create VERY sharp edges, so be careful, you can easily slice your fingers with the fish mouth. | |
Tubing fish mouth - Similar Threads | ||||
how do i fish mouth a brakeline | Rokclod3Krawler | Tools, and Procedures | 33 | 03-18-2010 07:49 PM |
not a good taste in my mouth | smokediver | Chit Chat | 15 | 03-10-2010 04:59 AM |
Easy way to fish-mouth brake line? | aerangis | Tools, and Procedures | 5 | 06-20-2007 03:07 PM |
