Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: 15* endmill/custom ground milling tools
Old 05-11-2012, 07:44 AM   #1
~THE SCALE SHOP~
Question 15* endmill/custom ground milling tools
kind of a two part question i guess.
1. does a 15 degree endmill exist? if so where?
2. if not where can i get a custom one ground?
STANG KILLA SS is offline   Reply With Quote
Old 05-11-2012, 08:35 AM   #2
Got Worms?
Default Re: 15* endmill/custom ground milling tools
Wen i was looking for an end mill that had a 45* cutting edge but still had a small flat on the bottom for facing, i couldn't find much of anything, and custom grinding is on the expensive side. We had a neat little grinding machine (no idea what its real name is), but it was designed to hold round stock and had a belt driven motor to rotate the part while grinding. Anyways, i just set the motor to 45 with the grinding wheel and ground a end mill down to what i needed. It seemed to cut fine, but it at most had 30 minutes of run time on it.
What do you need it for?...why couldn't you mount the piece at an off camber angle or get a vice that tilted up?
losikid is offline   Reply With Quote
Old 05-11-2012, 08:55 AM   #3
Mr Stang here you go
first one is carbine second link is hhs
CONICAL TOOL 15 DEGREE CARBIDE TAPERED END MILL INDEX, Quality Endmill Manufacturing
Conical Tool 15 Degree HSS Tapered End Mills, Quality Endmill Manufacturing
Evan
SlickRockSpider is offline   Reply With Quote
Old 05-11-2012, 09:08 AM   #4
~THE SCALE SHOP~
for my application a small flat in the center is fine. probly even prefered.
its a radial cut so the angled material/soft jaws wouldnt work.
i had one made before and it wasnt that bad. it was a 13 degree i just cant remember where i got it...
Old 06-28-2012, 03:30 PM   #5
~THE SCALE SHOP~
Exclamation Re: 15* endmill/custom ground milling tools
ok i contacted that company, and they said the 15 degrees is measured from the tool centerline. so that would make one LONG very pointy endmill.
not what im needing. he said technically what would need would be a 75 degree endmill, but that most companies dont make over a 45 degree end mill.
so does anyone know of a 75 degree endmill?(or if this degree name is even correct) or a company that can custom make one?
or a better way to do it? here is what im trying to cut.
for size reference the OD of the rod is ~2.2"
Old 06-28-2012, 03:49 PM   #6
I joined the Band!
easier on a lathe , no special tools...
tom@vp is offline   Reply With Quote
Old 06-28-2012, 04:20 PM   #7
Y-Town Crawlers
Del Monte's Avatar
You want a 75* included angle endmill. Give a good grind shop that and a tip size and they should be able to set one up pretty easily.
If you cant find anyone locally, i have a contact for a good grinder here who could have something for you pretty quickly.
Del Monte is offline   Reply With Quote
Old 06-29-2012, 11:12 AM   #8
I have a few things at work I mill with a similar profile. When we need to have one cut we either special order a end mill or send an old dull and chipped one out to be reground for it.
You can also look at TMCO I think they have an indexable tool that will give you a similar profile.
xjman is offline   Reply With Quote
Old 06-29-2012, 12:08 PM   #9
~THE SCALE SHOP~
where do you special order them from? link?
Old 06-29-2012, 12:22 PM   #10
I joined the Band!
I must be missing something..
Old 06-29-2012, 12:53 PM   #11
Y-Town Crawlers
Del Monte's Avatar
Is there a reason the part couldnt be made in a lathe? That does sound easier
Old 06-29-2012, 01:39 PM   #12
~THE SCALE SHOP~
yeah there will be a TON of CNC work done on the HAAS not shown. trying to prevent machine swap and time lost per part just for one surface. cause i have 150 of them to do.
Old 06-29-2012, 02:14 PM   #13
Y-Town Crawlers
Del Monte's Avatar
Thats what i figured, but i was curious. Work is slow today
Old 06-29-2012, 02:31 PM   #14
Do you have access to a 5 axis turning center? The best of both worlds.
BigSki is offline   Reply With Quote
Old 06-29-2012, 06:05 PM   #15
We have a kenemetal rep we order through. They are kenemetal end mills so I assume that's where he gets them.
I work for a big corporation so they may be shelling out massive money for them.
Sent from my Galaxy Nexus using Tapatalk 2
Old 06-29-2012, 07:25 PM   #16
Ty
Give these a try, Harvey make good tools.
Harvey Tool - Carbide Chamfer Cutters - Chamfer Cutters
Never mind I don't think they will be big enough.
Ty is offline   Reply With Quote
Old 07-01-2012, 11:01 PM   #17
I believe you'd want a 15* chamfer, or a 75* endmill. I've seen plenty of adjustable inserted chamfer mills, but I cant think of any that dont require clearance on either the bottom or the edge of the chamfer. Its very possible that you'll want to have something ground, but virtually anyone with a darex endmill grinder could do it.. shouldnt be too expensive.
rlockwood is offline   Reply With Quote
Old 07-05-2012, 07:47 AM   #18
~THE SCALE SHOP~
ok lathe crew....
i need to cut a .11" wide x .20" deep groove in the center of the flat outer ring of this thing. whats the best tool for the job?
(and a link where to buy would be greatly appreciated )
Old 07-05-2012, 08:07 AM   #19
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
I would make a modified hole saw for such a narrow pocket. The cutting edge will have to be curved or very thin otherwise. Your machinist not into making tooling, or are you doing the work yourself?
JohnRobHolmes is offline   Reply With Quote
Old 07-05-2012, 08:49 AM   #20
~THE SCALE SHOP~
<---learning the business, trying to do it myself.
do you have a pic or link to what im looking for. i tried googling it but not knowing what one looks like makes it a bit tough to sift threw the links
i assume your not talking about an oldschool hole saw for a hand drill?
15* endmill/custom ground milling tools - Similar Threads
Custom Ground carbide inserts losikid Tools, and Procedures 7 08-31-2011 02:34 AM
Custom tubing fabrication materials tools and procedures Tatau Newbie General 2 06-16-2009 01:22 PM
milling, fly cutter tools? brendan h Tools, and Procedures 15 12-19-2008 06:24 AM
Tools Give Away: Jp Custom Rc's run2jeepn Paint and Body 120 05-14-2007 05:31 PM
