07-21-2006, 05:39 AM | #21 | ||
RCC Addict Join Date: Jul 2004 Location: The other Crawler State
see above. and yes your right, the biggest mistake most people make is buying too big of a machine for the duty cycle, that's what I meant buy "duty cycle is over rated" and also most people use too big of a wire size also with a mix gas. Welding supply stores will sell you anything you want just to get the sale if you are not in the trade. | ||
07-21-2006, 07:42 AM | #22 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
I use .30 wire for most all unless I doing spot welds for body work etc then I step down in size
07-21-2006, 08:22 AM | #23 | |
for railing we use the .023, it welds nice and leaves no spatter hardly at all. too big of wire will hurt the penetration factor on a weld, with too big of wire you cover to fast after the initial burn into the steel which will not put down a good quality weld. but you already probably all ready knew that, sounds like you know your stuff too. not too many times I have seen that on the net. and usually I don't reply to argue the fact. | |
07-21-2006, 08:51 AM | #24 | |
07-21-2006, 03:15 PM | #25 |
Newbie Join Date: Jan 2006 Location: So_Cal
EXACTLY bulzeye! all i need is something little till i want to spend like 3 or 400 dollars just a little something to get the job done, if they didnt work diecent they wouldnt be selling welders!
07-21-2006, 10:22 PM | #26 |
Pebble Pounder Join Date: Jul 2006 Location: Out of my mind!!
im w/ traxx and bulzeye. I dont have 2 much money to spend on tools, only do occasional welding, and im cheap lol, so the $100 century welder was just right for my needs. To avoid any disagreements, I say to each their own. happy crawling, every1
07-22-2006, 12:56 AM | #27 |
and EXACTLY to you jason! i will only do occasional welding untill i get good.
09-18-2006, 12:05 AM | #28 |
Quarry Creeper Join Date: Jan 2006 Location: Henderson
IN MY OPINION....why buy a cheap machine until you "get good"?It's going to be hard for you to "get good" with a half *** excuse for a welder.As someone mentioned,welders are not a category to go cheap....ever heard the saying "you get what you pay for"?I have a Hobart Handler 140 that I use mainly for welding in patch panels and other bodywork and it works great,and will weld 1/4".If you are going to buy a welder,buy a good one.When was the last time that you went into a welding shop and saw a Clarke or Harbor Freight welder sitting there?I personally can't recommend a Lincoln MIG (because i haven't used one),but I can say that Miller and Hobart machines are very hard to beat.But like I said this is MY OPINION,if you want to start out with a cheapy,go ahead and when you "get good",check out a Miller Shopmaster...the price will make you **** yourself.Just my $.02.
09-18-2006, 12:08 AM | #29 | |
