06-09-2012, 12:46 PM | #1 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| cnc machining
Does anyone have any programs they would share for me to run and make some parts? I am taking some classes and thought it would be interesting to make some parts that I will use instead of just weird shapes and engravings to get used to loading programs and setting offsets.
06-09-2012, 12:54 PM | #2 |
| Re: cnc machining
Here is a free CAD program I was told is decent. Have not used it. I did download it a week or so ago. Got a phone call two days ago from the company asking if I had any questions about it. Not bad for customer service. Free 2D: Siemens PLM Software |
11-14-2012, 12:32 PM | #3 |
| Re: cnc machining
Here is a fun program for cutting out disk that fit vanquish hubs and uses 6 stays to separate. These are 2.5" tall disk cut and plunged with an 1/8" end mill. % O04567 G17 G20 G40 G80 G90 G94 (BEADLOCK RINGS 3.25" x 3.25" STOCK) M00 G54 (BOTTOM LEFT) M06 T1 (1/8 EMILL) M03 S3000 G43 G00 G54 X1.625 Y1.625 Z1. H01 G01 Z-0.3 F20. G91 X0.1735 G03 I-0.1735 G01 X-0.1 Z0.1 G90 G00 G54 X1.625 Y1.625 Z1. G00 G55 X0. Y0. Z1. G01 Z0.1 F20. G81 X0.3415 Y0 Z-0.3 R0.1 X0.1708 Y0.2957 X-0.1708 X-0.3415 Y0. X-0.1708 Y-0.2957 X0.1708 X1.0313 Y0. X0.5156 Y0.8931 X-0.5156 X-1.0313 Y0. X-0.5156 Y-0.8931 X0.5156 G80 G90 G00 G54 X2.9375 Y1.625 Z1. G01 Z-0.3 F20. G03 I-1.3125 G91 G01 X0.01 Z0.1 G28 M30 % Last edited by josh6575; 11-14-2012 at 04:41 PM. Reason: oops bad speeling |
11-14-2012, 01:59 PM | #4 |
| Re: cnc machining
Are you just looking for G-code? Or software programs?
11-14-2012, 04:40 PM | #5 |
| Re: cnc machining
Just wanting to share g-code programs.
11-14-2012, 07:35 PM | #6 |
| Re: cnc machining
Write your own! What is the purpose of going to school for machining to run other peoples code?
11-14-2012, 08:55 PM | #7 |
I wanna be Dave Join Date: Dec 2007 Location: Not here
| Re: cnc machining
I think what he wants is to see the process of a part from someone else. How the part is setup, Fixture/Tooling Soft jaws, mill, lathe. Material round bar of flat stk. Alum. Steel, plastic delrin Tool selection Endmills 2flt 3 flt. 4 flt., drills, taps, carbide, HSS. Feeds And speeds Fixture offsets called up in the programs. Sub Programs. G code M code This is all helpful to someone getting started. You can give the same part to several different people to prog. and they will have a some what different approach. Pm me I will help you out. |
11-15-2012, 04:37 PM | #8 |
| Re: cnc machining |
11-15-2012, 04:43 PM | #9 | |
| Re: cnc machining
Thank you sir, I am interest in figuring out how others hold the small parts. I have made some bead lock disk, chassis, and some other projects. I had a hard time with thin carbon fiber. It started warping and trying to jump off of the parellels as I milled it. Check out my thread in the bully section to see what I have done so far. Quote:
11-17-2012, 10:03 AM | #10 |
Rock Stacker Join Date: Feb 2012 Location: Longview
| Re: cnc machining |
11-20-2012, 08:15 PM | #11 |
Rock Crawler Join Date: Oct 2011 Location: smithville
| Re: cnc machining
I know this is really noobish but I have taken a liking to cnc machining in my shop class at high school. Anyway why do you still use g code which takes so much longer to use when you could just use a cad program then transfer it over to a cam program?
11-21-2012, 01:48 PM | #12 |
| Re: cnc machining The CAM program exports G-code which is what your controller uses to talk to the machine. It's still G-code though.
11-21-2012, 02:28 PM | #13 |
| Re: cnc machining
^ I knew that I just thought people were still manually typing g code for the program.
11-21-2012, 09:40 PM | #14 | |
| Re: cnc machining Quote:
Will writing G-code ever be taken over entirely by post processors? Maybe, but those running those CAM packages may never know what is really going on. You say you are in High School and interested in CNC machining. Learn G-codes, and when you are out of school looking for a job, blow the doors off of your interviewer by actually knowing what you are talking about. | |
11-22-2012, 07:17 AM | #15 | |
| Re: CNC machining Quote:
Also, knowing G-code makes it easier to do minor tweaks direct in the code. I haven't used G-code in years, but could pick it up again fairly quickly. No, I was never an expert. | |
11-26-2012, 04:08 PM | #16 | |
Here's a video of a part I programmed awhile back. It was a prototype part, so its far from optimized (mostly I just let the software do its thing) Consider that the software decided how to break up all of the Z-levels, is staying in rapid mode on plunges, etc. The second tool (while FAR from optimal) even has some 3D rapid moves, which would be incredibly dangerous to program by hand. YouTube Just something to consider. The robots are taking over. | |
12-06-2012, 10:46 AM | #17 | |
Quarry Creeper Join Date: Jan 2009 Location: Estonia
This is how I do my Beadlock rings. I take a square sheet of stock, a little larger than the ring it self. Drill the holes according to the program(measured from the center or from either corner) Then put a squared up block in the vice, and repeat the holes but with accurate placement so you can repeat the process later. Then bolt down the Beadlock and cut your contours. There are many ways to do things. Let your fantasy guide you. | |
cnc machining - Similar Threads | ||||
machining derlin????? | jthellfire911 | General Scale Talk | 2 | 07-29-2010 11:04 AM |
machining software | Wicked_Jester | Tools, and Procedures | 6 | 03-29-2009 04:18 PM |
CNC Machining | Mike-63 | Tools, and Procedures | 12 | 03-21-2005 06:45 AM |
