06-14-2012, 11:27 PM | #1 |
Rock Crawler Join Date: Nov 2008 Location: missoula
| Rod bender
Where can i get a good rod bender prob 3/16 to 5/16?
06-15-2012, 06:11 AM | #2 |
Come and take them!® Join Date: Oct 2011 Location: Rolling Hill's of Maryland™
| Re: Rod bender
This works well. Versatile. Inexpensive.
06-15-2012, 07:06 AM | #3 |
Pebble Pounder Join Date: Feb 2012 Location: De Leon
| Re: Rod bender
Make one. There are various threads here on homemade tube benders, which will work the same with rod that small.
06-15-2012, 08:13 AM | #4 |
| Re: Rod bender
Hunter can you do 1/4 inch on that?
06-15-2012, 10:49 AM | #5 |
| Re: Rod bender This is 2 tools here. The hex nut is for bending wire (yellow card). I have bent links and other items with the coil winder (white box). So yes, it can be used on 1/4" stock. Last edited by Hunter711; 06-15-2012 at 10:53 AM. |
06-15-2012, 12:49 PM | #6 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
| Re: Rod bender
bending solid rod is way easier then tube where you don't need a mandrel type dia to keep tube from spreading outwards in a tight bend like tube....i have my bender i made so i can just remove the main bolt i bend tube around, then replace it with different sizes of 1/4" thick steel stock in different diameters for the radius i need in solid rod ........bob .... |
Rod bender - Similar Threads | ||||
2-56 rod and mini t rod ends + few other questions | seven | Losi Micro-Rock Crawler | 11 | 03-14-2016 08:33 PM |
my solid rod bender | AX10wannabe | Tools, and Procedures | 8 | 05-02-2011 10:13 AM |
rod/tubing bender | inkmunky | Tools, and Procedures | 14 | 03-04-2009 07:20 PM |
Drilling Holes into Delrin rod for rod ends | FDAapproved | Losi Mini-Rock Crawler | 10 | 02-13-2009 03:44 PM |
