Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Torch setup.
Old 03-06-2013, 02:50 PM   #21
Default Re: Torch setup.
Originally Posted by Drail View Post
this is all i use Drail
Is that a refillable butane torch? I saw some of these and was wondering if it'd do the work brazing 3/16 brake lines?
french_connection is offline   Reply With Quote
Old 03-07-2013, 01:04 PM   #22
I run the same Smith as JRH. I use Oxy Mapp since it burns cleaner and I use mine indoors.
cherokee95 is offline   Reply With Quote
Old 03-07-2013, 11:38 PM   #23
i run the bernzomatic 2 tank setup with hose like the OP does... i love it.. i've even used it for other projects besides rc like i had a lawnmower hub that i needed to get off of a 3/4" solid shaft and the propane torch wouldnt get it hot enough so i used the bernzo and it worked awesome... i dont use it that much so its pretty cheap for me, i've had it just over a year and gone through like 2 oxygen tanks.
AX10wannabe is offline   Reply With Quote
Old 03-10-2013, 09:50 AM   #24
I run this setup my pops bought me.... My dads welding distributor said to not spend the money on the smith torch as you pay more simply for the name... He recommended the Gentec setup as its of the same quality. I have personally not used the smith torch so I cannot confirm for sure but I will say I love my Gentec torch.
This is the oxy/acty setup but you can buy the oxy/prop setup also. This is the cheaper alternative to the smith mini torch.
SOL-226.00 - Gentec Small Torch Kits with Regulators, Oxy/Acetylene
Fowlboy is offline   Reply With Quote
Old 06-27-2013, 09:21 AM   #25
Would this be ok to use with 3/16 brake line and the silver solder? Just wanting to know if it will work ok.
using this head
Bernzomatic Self Igniting Basic Torch Head-334496 at The Home Depot
and this tank
Bernzomatic 14.1 oz. Map-Pro Cylinder-332477 at The Home Depot
Thanks and where is the cheapest place to buy silver solder?
Also which one of these will work to braze the brake line?
Search Results for*silver solder*at The Home Depot
scoggdog13 is offline   Reply With Quote
Old 06-27-2013, 10:15 AM   #26
Torch and tank r a great starter setup... Pretty much what I started with... As for silver solder your best bet would be a welding or plumbing supply place... Make sure u get a good flux as well. I'd recommend Safety silv by Harris
Rockridge is offline   Reply With Quote
Old 06-27-2013, 10:19 AM   #27
R any of the solders good In the last link that says search results
Old 06-27-2013, 11:22 AM   #28
Would it be really hard to build a tube cage with a wire welder?
Old 06-27-2013, 12:33 PM   #29
As for the solders I'm not sure... I went straight for the silver solder 45 and safety silv flux and that's pretty much all I've used. As for the mig welder, I do have one of those too but prefer the silver solder.... I find there is too much clean-up of the joint with the mig. That being said there are guys that mig and guys that Tig as well. I would think if your gonna weld, Tig would be the way to go... No clean up of the joint after.
Old 06-27-2013, 12:52 PM   #30
is 1 ounce of solder enough or would I need more for an entire tube cage.
Old 06-27-2013, 02:04 PM   #31
You shouldn't need anywhere near an ounce for a single chassis.
Calderwood is offline   Reply With Quote
Old 06-27-2013, 02:54 PM   #32
It should be more than enough.. The more complicated/ joints the chassis has the more you will use. A southern buggy is gonna use more than a simple Truggy. Also when you first start out you will Probably burn up more than normal... A bit of a learning curve if you will. It just takes a little practice and patience.
Old 06-28-2013, 08:58 AM   #33
When you first start brazing remember that adding more solder than just what you need to wet the joint just fills the tube. It doesn't make it stronger.
Old 07-12-2013, 02:28 PM   #34
I thought about just doing this im broke and those jewlery torches are grip! I have a snap on torch I use at work im going to see if it will get hot enough
jeffunone is offline   Reply With Quote
Old 05-13-2022, 01:25 AM   #35
using this head
and this tank
Hello, i also confront similar problem as you, help............
bunjuewang is offline   Reply With Quote
Old 05-13-2022, 04:31 AM   #36
Slow is the new Fast
smog's Avatar
Yes, you can silver solder steel brake line with that torch. Just be sure to take any coating off of the surface. Always need clean the surfaces you are soldering
smog is offline   Reply With Quote
Old 09-26-2022, 12:28 PM   #37
I have the mini oxy torch I use propane and oxy. I use brass rod and flux, I’m too cheave to use silver solder.
I am experimenting with aluminum brazing but don’t have it down pat yet.
MasterShake44 is offline   Reply With Quote
Torch setup. - Similar Threads
Oxy/Propane Torch setup/buildup dps50 Tools, and Procedures 6 01-20-2011 07:05 PM
Torch ? JSN Tools, and Procedures 1 05-20-2010 10:33 AM
Brazing,Micro-torch or Normal size torch? xyzoose Tools, and Procedures 4 03-04-2010 09:47 PM
Has anyone seen this torch??? RockCrawlingKid Tools, and Procedures 5 01-07-2010 03:30 AM
New Torch rlem00 Tools, and Procedures 2 12-31-2008 01:55 PM
