06-17-2012, 10:21 AM | #1 |
Pebble Pounder Join Date: Dec 2008 Location: vidor
| Glue
What kinda glues are yal using when building plastic interiors and bodies and what not
06-18-2012, 01:49 AM | #2 |
Quarry Creeper Join Date: Jul 2011 Location: olympia
| Re: Glue
plastic weld... i use plastruct, tenax (sp?) is another i think
06-18-2012, 03:02 PM | #3 |
| Re: Glue
Cool thanks!!!!!!
06-20-2012, 06:55 PM | #4 |
RCC Addict Join Date: Jan 2011 Location: somewhere near Los Angeles...or a city looking thingy.
| Re: Glue
I just used model glue when I built my truggy cages for my micro crawler and after it dries in a day or two it's pretty strong. But you have to let it dry completely, it's a little soft the first couple of hours.
06-21-2012, 12:58 AM | #5 |
I wanna be Dave Join Date: Nov 2008 Location: Chillin in Utardia
| Re: Glue
Tenax FTW |
06-21-2012, 06:21 AM | #6 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: Glue Trick from an old static modeler: Thinly drop on a few tacks of superglue, let dry then use Model Cement. Same bond and not the same problem of long periods of holding parts waiting for initial bond when using Model Cement.
06-21-2012, 10:16 AM | #7 |
| Re: Glue
Cool! I used to do static models for many years but I'd use different types of glue and it being static it wasn't as important for it to be as strong as glueing plastic for an rc car so I wasn't sure what type of glue would hold up to the abuse with a crawler
06-21-2012, 07:50 PM | #8 |
| Re: Glue
Oh, so that's why it got soft. I just gobbed a bunch on, at least it's strong. I didn't really care how long it took to dry I just wanted to get it done.
06-22-2012, 08:53 AM | #9 |
MODERATOR Join Date: Oct 2010 Location: RC Land
| Re: Glue
Depends what you are doing.... Gluing is fine for static models "Testors plastic model cement" and or "super glue" will be fine for gluing static models ___ You NEED to bond things for RC use Either with "Weld-On 45" or "Polycarbonate Cement SC-325" will do well for bonding lexan Products like "Tenax 7R" or "Plastruct Plasticweld" or other similar CA products work well for bonding styrene . |
06-22-2012, 10:41 AM | #10 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
| Re: Glue
i use tenax7 for bonding the styrene.. then go back over it with some bob smith ca glue.. |
Glue - Similar Threads | ||||
What do you guys use to glue tires other than CA glue? | country_crawler | Tires and Wheels | 38 | 03-17-2015 11:10 PM |
To glue or not to glue...rear tires | Snipervision | Losi Mini-Rock Crawler | 3 | 12-24-2010 11:01 AM |
Memory Foams To Glue or not to Glue? | Rig Rocker | Tires and Wheels | 1 | 09-30-2009 10:45 PM |
CA glue? | swamp_rat | Tires and Wheels | 4 | 05-30-2007 11:43 AM |
What Glue to use?? | tjb | General Crawlers | 3 | 04-28-2006 04:32 PM |
