01-22-2014, 10:56 AM | #201 |
| Re: Eyeball Engineering
Really slick chamfer jig there! I just found the wonders of deburring tools, yehaw!
01-22-2014, 11:14 AM | #202 |
| Re: Eyeball Engineering Just the cheap 5050 led strips from ebay. I noticed the other day that the current setup is starting to die...they've lost their zenon color and are fading into a dim, warm white color. I'll be replacing them shortly with some bright white, and most likely scale it down some while I'm at it. Its better than nothing, but just barely. The next iteration will use a dremel tool. |
01-22-2014, 12:10 PM | #203 |
| Re: Eyeball Engineering |
01-22-2014, 12:26 PM | #204 |
Yep. I ordered a tumbler and some media a couple days ago. Id still like to come up with ai easy way to put a nice finished edge on stuff though.
01-22-2014, 12:39 PM | #205 |
I wanna be Dave Join Date: Oct 2004 Location: QC-AZ
CNC? |
01-22-2014, 02:12 PM | #206 |
01-22-2014, 05:19 PM | #207 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
01-25-2014, 11:05 AM | #208 |
Been doing some tool shopping. New 4" vice. Worlds better than my old one. Monster Jaws aluminum jaws. Corner rounding end mills. Got a wiggler to try out. Tumbler showed up, but the media is still MIA. Last edited by Duuuuuuuude; 01-25-2014 at 11:09 AM. |
01-25-2014, 11:35 AM | #209 |
Now you are getting addicted to tooling up I just picked up a set of indexed carbide insert bits for the mini lathe. I had only tried the carbide tipped tools, and hated them because of the zero rake. For less than $5 an insert with three points I couldn't turn it down! (no pun intended) |
01-25-2014, 12:10 PM | #210 |
I'm not an addict, I'm an enthusiast. Most of this stuff is things that I've been needing but hadn't had the money for. The only thing I got for funsies is the wiggler. |
01-25-2014, 12:31 PM | #211 | |
| Re: Eyeball Engineering Quote:
Using a Wiggler - YouTube I know how it goes... January is an expensive month for me oh well unless its a consumable item once you got it your set | |
01-25-2014, 02:31 PM | #212 |
Yashua Join Date: Sep 2010 Location: Learn the parable of the fig tree
That vise is a great bang for your buck, that middle hole on the movable jaw allows you to lock the jaws firmly with a wedge action. Like to know what you think of the corner radius set. |
01-25-2014, 04:38 PM | #213 |
Wiggler FTW ! They are about as 'old school' as it gets, yet they still work perfectly. I'm not seeing the connection between the piece of angle that your were chamfering and the finished part. Could you elaborate for those of us that are a bit on the 'slow' side? |
01-25-2014, 05:04 PM | #214 |
Nice. It's always satisfying to get some of the tools you have wanted/needed for awhile but were holding off from buying.
01-25-2014, 05:37 PM | #215 |
| Re: Eyeball Engineering Behind that piece of angle is either an endmill or deburring bit. The cutting surface of either protrudes (very slightly) into the angle, so that the tool makes contact with the very edge of the part and nips the sharp edge off.
01-27-2014, 10:59 AM | #216 |
| Re: Eyeball Engineering I got that much from the pic! I didn't see the connection between the piece in the vise and the finished parts. I thought maybe you used the big piece of angel as an extrusion of sorts, then cut out the individual posts. I just can't see how the posts could come from that shape. I addition to being slow, I'm not a great communicator ! |
01-27-2014, 11:31 AM | #217 | |
01-27-2014, 06:13 PM | #218 |
I think I get it now. I guess I've been using one of these things for too long to realize there could be better ways of deburring. |
01-27-2014, 06:31 PM | #219 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
I used to use Shaviv debuting tools everyday and it got old real quick. The corner endmill set is the shiznit for making nice clean burr free edges, you can use them for multiple different purposes. Once you get some more scratch built up take a look at harveytool they make some great stuff for are sizing needs. I use a lot of their end mills and engraving bits. They cut brought aluminum and acetal like its warm butter. --Dan Side note where did you pickup the tumbler and what brand is it? |
01-27-2014, 06:46 PM | #220 |
| Re: Eyeball Engineering those are nice. On the machines at work we tend to use a ball mill or a chamfering tool to do the trick I still love my 3-bladed de-burring knife and some tiny files. They kick butt |
Eyeball Engineering - Similar Threads | ||||
rocksmith engineering | D-Ride | Newbie General | 14 | 05-19-2012 11:40 PM |
Engineering Question | BJoe | Chit Chat | 14 | 03-04-2008 01:15 PM |
