07-22-2012, 10:12 AM | #1 |
Pebble Pounder Join Date: May 2011 Location: Chilliwack, B.C.
| Welding Brake-Line
I've welded a few bumpers together out of 3/16" brake-line, and for some reason it gets too hot too quickly and will melt if I do much more than a tack at a time. I've got my MIG(wire fed) welder's wire speed turned all the way down, and the heat turned down as far as it'll go and still weld smooth. Here's a few examples: I see roll cages like MG200 makes, and the welds are so smooth. How do you do that? Is it brazed and not welded? Is it something more solid than brake-line? TIG welded? Do you use a finer feed? Or what? Last edited by R/C Bashist; 07-22-2012 at 10:29 AM. |
07-22-2012, 11:47 AM | #2 |
| Re: Welding Brake-Line
You cant do much more than tack around the whole tube with a mig, a tig is a better option but even that is a pain on tubing. You can try running a higher wire speed to run a cooler puddle but I doubt you will get more than a tack at a time without burning through. I switched to solid rod for most of my stuff because it is cheaper and easier to work with. |
07-22-2012, 11:53 AM | #3 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
Brazing works best on brake tubing.
07-22-2012, 11:55 AM | #4 | |
Quarry Creeper Join Date: Jan 2012 Location: Mooresville, NC
Sent from my DROID X2 | |
07-22-2012, 12:13 PM | #5 |
Rock Stacker Join Date: Jul 2008 Location: tulsa
IS your mig gas or gas less? It looks like it's gas less and your using flux wire. Which burns hotter than just solid wire and gas. If you can switch your mig over to gas and use a solid wire that might help you with your heat settings.
07-22-2012, 12:23 PM | #6 |
Pebble Pounder Join Date: Sep 2011 Location: Albuquerque
Dont put the welding lead so close. Have the wire come out some. Worked for me.
07-22-2012, 02:14 PM | #7 |
| Re: Welding Brake-Line I'm quite sure it's gas, it's got a big tank on the back that says "Argon" on it.
07-22-2012, 02:37 PM | #8 |
| Re: Welding Brake-Line |
07-22-2012, 03:05 PM | #9 |
RCC Addict Join Date: Mar 2010 Location: Yelm
What type of welder?
07-22-2012, 04:41 PM | #10 |
Rock Crawler Join Date: Mar 2011 Location: USA
I read some where about Wire size ,The smaller wire is what they used ,,I dont know ,,I have both,and braze brake line tubing,,,,KMS,,,,, |
07-22-2012, 04:49 PM | #11 |
Newbie Join Date: May 2012 Location: Gaylord
I made some bumpers for my rig out of break line also and i soldered then together using silver solder and a small torch. worked out pretty well i think. i didnt get a chance to take picks.
07-22-2012, 09:59 PM | #12 |
07-22-2012, 10:28 PM | #13 | |
| Re: Welding Brake-Line Quote:
I go with a MIG because it's what's sitting in my shop. I'd like to try brazing sometime, and do a strength test compared to MIG. | |
07-22-2012, 10:31 PM | #14 |
| Re: Welding Brake-Line Silver solder is plenty strong. If it weren't we'd all be using something else. That is the nice thing about RCC...we tend to use what works, not what looks pretty or gets all the hype.
07-22-2012, 10:36 PM | #15 |
| Re: Welding Brake-Line But silver solder does look pretty and it does get all the hype...for good reason |
07-23-2012, 03:02 PM | #16 |
Quarry Creeper Join Date: Jul 2004 Location: Arkie-Saw
Braze it right and the tube rips before the joint does, well, anything!
07-23-2012, 03:10 PM | #17 |
Rock Crawler Join Date: Sep 2008 Location: Delta B.C.
09-24-2012, 08:08 AM | #18 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
A friend of mine uses uncoated brake line, silver soldier, and a MAPP gas torch for brazing. It is really, really, really strong, and seems to be easy to work with.
09-24-2012, 08:13 AM | #19 |
That friend I mentioned made a video about brazing: Keystone RC Enthusiasts Forums • Search |
09-24-2012, 09:50 AM | #20 |
| Re: Welding Brake-Line some of us use silicon bronze filler rod, it works pretty good. My issue w/ the saftey-sil is, although it's 45% silver ( very strong metal) it's still 55% lead ( not so strong )
Welding Brake-Line - Similar Threads | ||||
brake line | oscodawave | Newbie General | 15 | 10-09-2010 11:58 PM |
Brake line! | warfile | Tools, and Procedures | 34 | 08-26-2009 03:48 AM |
Mig welding Brake line | Ryan33 | Tools, and Procedures | 11 | 02-07-2009 11:09 PM |
brake line ? | nodnarb81 | Tools, and Procedures | 2 | 01-30-2008 10:47 AM |
welding brake line | skrewdriver | Tools, and Procedures | 9 | 04-25-2006 01:48 PM |
