08-26-2012, 11:05 PM | #1 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
| Soldering Temps?
So I just got a new soldering station and I'm wondering what temps to set for different applications. Motor wires, servo wires, esc work, ect.
08-27-2012, 12:25 AM | #2 |
| Re: Soldering Temps?
Which station? If it doesn't heat what you need to solder in 1-2 seconds then you need to crank up the heat. I don't do any set temp stuff, just go by the way the solder melts |
08-27-2012, 12:22 PM | #3 |
I got a Hakko fx888 and thanks for the input, sounds logical to me
09-06-2012, 02:48 AM | #4 |
Newbie Join Date: Feb 2011 Location: Adrian
Most everything I solder gets done between 825-850. I will change tips more than the temperature. I like to use a fatter tip for heavier wire on things like battery connectors and motor leads. The bigger tip helps hold heat better when you start soldering. That way you can get in and get out quickly without holding the heat on too long and heating up the entire assembly.
09-06-2012, 04:26 AM | #5 |
Newbie Join Date: Nov 2011 Location: earth
I have a Hakko fx888 as well, 800 f for deans connectors. 60/40 solder, use flux.
09-06-2012, 08:58 PM | #6 |
Quarry Creeper Join Date: Dec 2010 Location: Phelan California
also some solders have lower temps than others, I have 3 different ones I use, lower temp stuff for smaller more delicate and high temp for deans and motor wires.
09-07-2012, 02:52 AM | #7 |
Newbie Join Date: Apr 2012 Location: canada
generally you wanna use the hottest heat you can with out causing damage. this allows the solder to get into the wire and prevent a cold solder which is weak and is a poor conductor.
Soldering Temps? - Similar Threads | ||||
Soldering info.....temps & tips | Charlie-III | Electronics | 4 | 08-27-2012 08:10 PM |
Burning through soldering tips? And other soldering questions | losikid | Electronics | 14 | 12-16-2010 10:04 AM |
Diff Temps | 93firebird | Team Losi Comp Crawler | 5 | 06-14-2010 02:35 PM |
What soldering iron for battery soldering? | Flatty | Electronics | 1 | 06-23-2008 07:35 AM |
temps | mudboger07 | Electronics | 2 | 02-28-2008 07:41 PM |
