09-09-2012, 04:06 PM | #21 |
| Re: indexing w/o a rotary table?
If you have a chunk big enough to slide one of the barrels in then just make a fixture with a set screw and you can avoid the flats on the barrels themselves.
09-09-2012, 04:25 PM | #22 | |
| Re: indexing w/o a rotary table? Quote:
I think that you had some creative methods for doing something like this on a drill press and I was not trying to discount you in any way. You are in here talking with people who have done this kind of work for a living on machines that cost in excess of $100,000 dollars in many cases. While your way would probably work its not the kind of solution the OP was asking for. | |
09-09-2012, 04:50 PM | #23 |
Newbie Join Date: Dec 2011 Location: valley of the sunstroke, az
coming from a 1:1 background and new to the scale hobby scene i'm just trying to participate not step on toes. i have a smithy 3in1 that is a pretty nice machine for what i do, but its about as accurate as spitting on a pie plate from my roof so i still manage to figure out ways to make things simpler and more efficient when using it. not to mention i'm finding out just how clunky a full size machine is on scale stuff. i tell you i have been amazed at some of the things i see folks here doing, even the simple stuff. |
09-09-2012, 06:51 PM | #24 |
Rock Stacker Join Date: Feb 2012 Location: Longview
a pin can do a good job of orienting a workpiece 90* to an existing hole.. press it into a soft rear jaw -- add a second pin that orients to the parts profile and you've taken care of rotation on all 3 part axis even easier, though, is to mill a flat spot onto the face of the initial hole-- then you can simply clamp this face in the vise, which sets you up perpindicular. And if the holes are for the trunnion/base of the cannon, it will probably make for a better functioning piece anyhow. Last edited by rlockwood; 09-09-2012 at 06:58 PM. |
09-09-2012, 07:58 PM | #25 | |
It's still sorta ghetto but it might work. | |
09-09-2012, 08:45 PM | #26 | |
09-10-2012, 02:32 PM | #27 | |
09-10-2012, 02:46 PM | #28 |
| Re: indexing w/o a rotary table? |
09-10-2012, 04:44 PM | #29 |
09-10-2012, 04:55 PM | #30 | |
I can get you measurements. Last edited by Grizzly4x4; 09-10-2012 at 04:58 PM. | |
09-10-2012, 05:07 PM | #31 |
That is the benifit of the block set I posted, they are square and the whole block is ground so you know they are nice and true. It comes with a square and a hex block for the same price as the one like Grizzly has and a nut for the back or a quick release handle. Combine that with a collet stop and you have a nice repeatable fixture for all your 5c collets. |
09-10-2012, 05:29 PM | #32 | |
09-10-2012, 05:29 PM | #33 |
Why couldn't you make your own block? Grab some aluminum or even acetal, bore a hole it in to fit the barrel, drill/thread some bolt holes to keep it all together, then slice it in half. Put the barrel in the block, tighten the bolts to keep it in there snug, clamp it in the vice, drill, then flip 180* and drill again.
09-10-2012, 07:14 PM | #34 | |
Honestly, I doubt that I could get it as square, or keep the bore as concentric as the part they offer, and for the price, there's really no incentive to attempt making my own. I'm leaning this way, I just spent the past few hours looking at a few different tools, this collet block set seems to be the most versatile and easiest to use. I'll start searching for a used set of the 5C collets, I just don't have another $100 to lay out right now. | |
09-10-2012, 07:18 PM | #35 | |
Once you get it locked into the block and find center, there shouldn't be much of an issue. | |
09-10-2012, 08:07 PM | #36 | |
I do agree though, you could probably find a nice used set for cheap if someone is going out of business or something but I would assume that stuff usually goes with any machines they are getting rid of. | |
09-10-2012, 09:21 PM | #37 | |
Put your stock in the block, snug the bolts down. Put it in the vice against the stop, use a dead center to meet up on the grubby line on top of the block, lock your axis down, move over to where you want your hole, punch it, flip the whole thing over, punch the other hole. Last edited by Duuuuuuuude; 09-10-2012 at 09:49 PM. | |
09-10-2012, 09:29 PM | #38 |
Quarry Creeper Join Date: Apr 2009 Location: Lincoln
Can you just cut the stock a 1/8" long and mill the flats on that end. Face it to length and they are gone. |
09-11-2012, 09:16 AM | #39 | |
just bust mah ballz... seeing the pics of your holder, it's not what I was envisioning when reading the description. That would be a decent way of solving my immediate issues. I'll head over to the local plastics distributor and see if they have any small pieces of Delrin. I know I don't have any engineering plastic laying around. | |
09-11-2012, 05:35 PM | #40 | |
For just doing a small run of stuff, its totally worth the time and effort. If you're going to be doing a whole bunch of stuff, buy the fixture. The nice thing about building your own is that you aren't limited to the size of collets you have on hand. I'm not sure what the material is that I used. I thought it was acetal when I snagged it, but I think its actually pvc. It seems stout enough to use for a while, but you wouldn't get years of use out of it. | |
indexing w/o a rotary table? - Similar Threads | ||||
Southern Scale Crawlers at Rotary Park | CBR | Scale Videos! | 1 | 04-22-2012 12:34 PM |
Cordless dremels? rotary tools? | D-ran83 | Tools, and Procedures | 5 | 10-22-2010 05:43 AM |
Cheap Rotary Tool? | alexchen86 | Tools, and Procedures | 21 | 10-12-2010 12:32 AM |
Centering rotary tables | Mnster | Tools, and Procedures | 7 | 11-24-2006 12:34 AM |
Rotary Switch for TQ3 3rd Channel? | Trike Kid | Electronics | 0 | 01-18-2006 10:26 PM |
