10-03-2012, 06:33 PM | #1 |
Rock Crawler Join Date: Jul 2007 Location: Rectalville
| Ripping 1/2" square steel tubing down the middle?
been having some trouble with this. I won't even attempt it on my poor old POS bandsaw. (Seriously, it sucks major Donkey ballz when you take it to steel). There are two local metal fab shops, I talked to both of them and both said it would be nearly impossible. I said "BS, I've seen it done a couple hundred times, by guys on their bandsaw at home. Mine just isn't up to the job." One shop flatly said no, the other said they would attempt it, but it would cost me $150 to rip two pieces of $5 48" tubing, whether it worked or not!!! So... any ideas? |
10-03-2012, 06:52 PM | #2 |
Rock Stacker Join Date: Sep 2009 Location: griffith nwi
| Re: Ripping 1/2" square steel tubing down the middle?
jig saw and metal blade thats what i use i clamp the metal and take my time works like a charm blades are 5 dollars or so from home depot
10-03-2012, 06:53 PM | #3 |
actually i bend up my frame first then rip it with the saw
10-03-2012, 06:58 PM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: Tehachapi, Ca
I've done it with a 4 1/2" grinder with a cutoff wheel
10-03-2012, 07:51 PM | #5 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
Hacksaw, jigsaw, bandsaw, reciprocating saw, grinder with a cutoff wheel...
10-03-2012, 08:50 PM | #6 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
I saw in a similar thread someone chucked up a 3" cut off wheel in a drill press and cut a pre-bent piece in half. I have the parts needed but i haven't tried it yet
10-03-2012, 08:51 PM | #7 |
Rock Stacker Join Date: Feb 2012 Location: Longview
| Re: Ripping 1/2" square steel tubing down the middle? |
10-03-2012, 08:56 PM | #8 |
10-03-2012, 10:06 PM | #9 |
10-03-2012, 10:57 PM | #10 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
Anyway you do it is not doing to be "easy". Its metal working, if it was easy everyone would do it. I would either use a grinder w/ a thin cut off disk, a jigsaw, or the drill press method. All depends on my mood of the day. |
10-03-2012, 11:07 PM | #11 |
Newbie Join Date: Oct 2011 Location: Hamilton ON Canada
I say the table saw is the best bet |
10-03-2012, 11:07 PM | #12 | ||
| Re: Ripping 1/2" square steel tubing down the middle? Quote:
10-03-2012, 11:52 PM | #13 | |
| Re: Ripping 1/2" square steel tubing down the middle? Quote: well i stand corrected. | |
10-04-2012, 07:12 AM | #14 |
I use a cutoff wheel with the mandrel in the drill press, then I adjust the table height so that it hits the center of the square tubing, then very slowly feed the tubing through the wheel.
10-04-2012, 11:59 AM | #15 |
Pebble Pounder Join Date: Aug 2005 Location: coshocton
Here is a suggestion and I have seen this done, works well. Take your stock, round or square, and get a piece of flat stock. Then take your frame stock and tack weld it to the flat stock, just in a few places. Then set up a straight edge for the flat stock, adjust for the center cut, and cut away. -Gary |
10-04-2012, 12:07 PM | #16 |
Here is two more way to do it as well. How to Cut a Pipe in Half Lengthwise on a Vertical Band Saw | eHow.com How to Cut Pipe Down the Center with a Vertical Band Saw | eHow.com |
10-04-2012, 04:23 PM | #17 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
my home depot has some 3" x 1/16" thick metal cutoff wheels with the same companies mandrel i used and chucked it up in my drill press and cut frame down the middle....kinda like MR VERT did making his beadlock wheels......bob .... |
10-19-2012, 12:27 AM | #18 |
Quarry Creeper Join Date: Jul 2011 Location: olympia
i used a milwaukee deep cut bandsaw on a swag offroad table... one of the most useful tools in my garage... only problem is flattening the two peices after the cut (they bow from the heat)... the cutoff wheel would probly have the same issue tho... any decent fab shop should be able to do it for WAY cheaper than what you were quoted... its just a cut, not rocket surgery...
Ripping 1/2" square steel tubing down the middle? - Similar Threads | ||||
source for small steel square tube? | R/CMaxximus5.0 | Tools, and Procedures | 12 | 02-19-2013 09:54 AM |
2011 Nevada National Invite "meet in the middle" Crawler Death Match | DRIVNMF | Competitions | 58 | 06-23-2011 08:01 AM |
bending 1/4" square tubing | STEEL_CITY_CRAWLER | Tools, and Procedures | 5 | 08-27-2006 05:07 PM |
