Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: What Size
Old 10-29-2012, 06:26 PM   #1
Default What Size
When building a buggy what size nuts are you guys using to secure your panels & where can I get them? Thanks in advanced
Dtempleton is offline   Reply With Quote
Old 10-29-2012, 06:49 PM   #2
Default Re: What Size
2mm...I think. If you have a Ace Hardware near you, try them. They usually have a ton of bolts of all sizes.
KennethXJ is offline   Reply With Quote
Old 10-29-2012, 06:58 PM   #3
Ok thanks man but the only thing close to me is lowes besides mom & pop shops
Old 11-01-2012, 05:24 AM   #4
may have better luck with the mom and pop shop. lowes is gonna have mostly 4mm and bigger, home depot as well.
iv found that the little shops sometimes cater to local crafters and old retired guys farting around with stuff just to pass the time.
stanmondz is offline   Reply With Quote
Old 11-01-2012, 07:52 AM   #5
Originally Posted by stanmondz View Post
May have better luck with the mom and pop shop. Lowes is gonna have mostly 4mm and bigger, Home Depot as well.
I've found that the little shops sometimes cater to local crafters and old retired guys farting around with stuff just to pass the time.
+1.
Also look for a "Sears Hardware", it's different than just a "Sears". The one close to me has some 2mm, 2.5mm, 3mm and up.
As to a LHS, if they don't carry much "typical crawler hardware", let them know what you usually use. They may start to carry some of it, mine does.
Charlie-III is offline   Reply With Quote
Old 11-02-2012, 10:08 AM   #6
And if all your local options don't pan out, I generally use RTL Fasteners online and they are great!
Dukk is offline   Reply With Quote
Old 11-02-2012, 11:47 AM   #7
Unfortunately I don't have any LHS close to me but I checked out the mom & pop place & they had some 3mm that will work just fine, Thanks for the help!
What Size - Similar Threads
Servo Armor...Standard Size or 7980 Size!!! Chaotic Crawlers Electronics 2 07-26-2011 12:33 PM
