11-23-2012, 10:56 AM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: Bloomington
| RC Power Drill
I would like to know what small power drill you use for your rc's? I am lookin for one to speed up tire changing process, is there one with either variable speed or a torque clutch that will go low enough?
11-23-2012, 11:21 AM | #2 |
| Re: RC Power Drill
I use a battery powered Makita drill (it has a clutch on it & is variable speed) at times, it's a work tool so I didn't have to buy it. Others use similar battery powered drills. I have also seen people use "battery powered screwdrivers" which are usually slow but single speed & reversible. Either route can use a cut down Allen wrench, or a "hex driver bit" or screwdriver bits. |
11-24-2012, 07:52 AM | #3 |
Newbie Join Date: Apr 2012 Location: Maytown
| Re: RC Power Drill
I have a Dewalt Battery screwdriver that has a clutch on it and is adjustable torque. It takes all standard hex bits and works great. I have used it for work for years on very small items and it has worked great.
11-24-2012, 09:20 AM | #4 |
Quarry Creeper Join Date: Dec 2009 Location: Tehachapi, Ca
| Re: RC Power Drill |
11-24-2012, 10:11 AM | #5 | |
| Re: RC Power Drill Quote: | |
11-24-2012, 12:19 PM | #6 |
11-24-2012, 02:10 PM | #7 |
Quarry Creeper Join Date: Jun 2010 Location: Ireland
| Re: RC Power Drill
Get an extra set of beadlocks (and foams if you're using the same set for different tires). Much quicker and easier.
11-26-2012, 10:44 AM | #8 |
Quarry Creeper Join Date: Apr 2009 Location: Ottawa, ON, Canada
| Re: RC Power Drill
I took out the two NiCd sub-C batteries in a power screwdriver and wired it to the 3.3V output of a PC power supply (same one I use for my charger). It has just enough torque that if I stop quickly I don't strip plastic, it's small and lightweight, and I don't have to worry about recharging or replacing batteries. I also prefer the slower speed, going too fast in plastic can heat it up and deform it. |
11-26-2012, 01:31 PM | #9 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
| Re: RC Power Drill
Been using this for a couple of years now for RC, my cars, motorbikes, boat and around the house. Been absolutely faultless and the clutch is very accurate. |
11-27-2012, 10:03 PM | #10 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: RC Power Drill
Call me old fashioned but I use one of these. Clutch works perfect. Batteries last forever it seems and I haven't stripped out any screws yet. |
11-28-2012, 04:26 AM | #11 | |
Who has the HoTtEsT husband | |
11-28-2012, 04:53 AM | #12 |
Newbie Join Date: Nov 2012 Location: North georgia
I use the snap-on power screwdriver. Works great, clutch is spot on, comes with two batterys so when ones dead you have a charge one. Price is a big downer though. 200$. Hope this helps(:
RC Power Drill - Similar Threads | ||||
what kind of drill bit do i need to drill out Rc4wd gears? | Rox4life | Axial XR10 | 5 | 11-07-2012 08:34 AM |
Hex set for power drill ? | scrofcheck | Tools, and Procedures | 16 | 01-19-2012 01:57 PM |
Hammer Drill Power | Krawlin | General Crawlers | 29 | 08-01-2007 10:44 AM |
drill motor power plant | jetboat | Electronics | 4 | 01-07-2006 08:29 AM |
using a power drill motor? | VTEC | Electronics | 6 | 02-13-2005 04:41 PM |
