12-31-2012, 06:01 PM | #1 |
Rock Stacker Join Date: Sep 2010 Location: Norway, HOME OF THE VIKINGS
| Surface to silver solder on?
Hello good people of the interweb :-P I'm looking for a surface that i can make a chassis mock-up and solder on. Is there such a thing? I'm using a torch able of delivering 1900 C (3452f if you live in the US of A).. Links to webshops are VERY welcome... |
12-31-2012, 06:56 PM | #2 |
Rock Crawler Join Date: Apr 2009 Location: NE Ohio
| Re: Surface to silver solder on?
Any type of heat-safe mat, weld mat or spark mat will work. Here's good results https://www.google.com/search?hl=en&...1.Y8PyUktjFug# --Dan |
12-31-2012, 08:17 PM | #3 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
I use fire bricks. I bought mine locally for $3.99 a piece but here's an amazon link.... Amazon.com: AW Perkins Fire Bricks - Used To Repair / Build Fireboxes: Home & Kitchen |
12-31-2012, 09:28 PM | #4 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
Nothen wrong with a good ol piece of sheet metel..... is there! Sent from my GT-I9100 using Tapatalk 2 |
01-01-2013, 09:08 AM | #5 |
I use a large piece of steel on top of bricks. I like the steel because I use magnets to hold pieces in place.
01-01-2013, 09:25 AM | #6 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i use a 3/8" thick alum plate so if any silver solder gets away it won't bond my work to the steel plate like i have seen done ....
01-02-2013, 12:46 AM | #7 |
I use a 1/4" thick 6"x12" chunk of steel plate. Solid and straight, though I keep whichever joint I'm working on hanging off of the edge so that the plate doesn't suck the heat away, and so that it doesn't accidentally become brazed to the plate. |
01-06-2013, 06:16 PM | #8 |
Quarry Creeper Join Date: Jan 2009 Location: B-E-A-utiful Vancouver Island
I use a 18"x18" ceramic tile from my local Home Depot
01-07-2013, 12:29 PM | #9 |
| Re: Surface to silver solder on? how straight and true is it? now does it hold up to the mapp gas? does it draw some of the torches heat like steel/alum? i tried a scrap piece of granite one time. bad idea. extremely dangerous. it litterally slowly exploded. the heat of the torch make the tiny peices of rock etc glowing red and shoot off in all directions. little molten missiles |
01-07-2013, 04:03 PM | #10 |
Newbie Join Date: Feb 2012 Location: Williamsburg
| Re: Surface to silver solder on? Yep that's how they create a "flamed" edge on the granite. Basically the quartz crystals in the stone expand when exposed to the heat and pop out of the surface.
01-07-2013, 05:01 PM | #11 |
| Re: Surface to silver solder on? |
01-07-2013, 08:40 PM | #12 |
| There r dozens of different patterns/colors to choose from... I found one that's straight and flat( no texture) It seems to hold up to the heat just fine. As for mapp gas I use a full size brazing tourch on oxy propane and the tile holds up fine. It dosnt seem to suck up the heat like steel dose but I try not to direct the heat directly to the tile
01-11-2013, 11:04 PM | #13 |
Rock Crawler Join Date: Aug 2010 Location: Saint Marys, OH
I bought a 12x12 tile from Menards and was able to get 3-4 joints done before is shatter-exploded. Thank goodness for safety glasses. I ended up getting some firebricks from Tractor Supply. I've had good luck with them so far. I would love to get something different, they seem to suck a ton of heat away from the workpieces.
01-12-2013, 08:16 AM | #14 | |
Surface to silver solder on? - Similar Threads | ||||
cheap silver solder | stanmondz | Tools, and Procedures | 6 | 05-17-2012 07:36 PM |
Silver Bearing Solder | steven9026 | Tools, and Procedures | 4 | 12-07-2007 09:04 AM |
silver solder | rash_powder | Tools, and Procedures | 5 | 11-14-2007 06:11 PM |
silver solder for a tuber | ridgewalker | Tools, and Procedures | 17 | 06-29-2007 11:49 AM |
Brazing vs. Silver solder | mxrider99 | Tools, and Procedures | 27 | 03-20-2006 10:15 AM |
