Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: bending 1/4" square tubing
Old 08-27-2006, 03:37 PM   #1
Default bending 1/4" square tubing
ok, so i am finally gonna attempt to make my first scale ladder framed rig, and as wondering if anyone had some ideas and/or helpful hints on bending 1/4" square tubing.
thanks in advance for any help yinz can offer...
STEEL_CITY_CRAWLER is offline   Reply With Quote
Old 08-27-2006, 03:40 PM   #2
A vice.
CoreyK is offline   Reply With Quote
Old 08-27-2006, 04:00 PM   #3
Ace
What material?
I bent 1/2" square steel by heating it red hot and bending around a round piece of steel.
The sides will bulge a little, I squeezed them back with the vice before it cooled.
Ace is offline   Reply With Quote
Old 08-27-2006, 04:29 PM   #4
Originally Posted by Ace
What material?
oh yeah, should of mentioned that. and actually, i think i'm gonna use 1/2" square steel tube anyway.
also, has anyone ever used one of these benders? and if you have, will it work on square tubing?
http://www.sears.com/sr/javasr/produ...EARS&ihtoken=1
Old 08-27-2006, 04:56 PM   #5
I got kind of the same dilemma going on with my build, but I had figured on using heat and bending against things... my dilemma is how to cut it up the middle to make two rails after it's bent...
As of right now I think I'm opting to go the 3/16" x 3/4'" steel strap route, cut and welded like rbgerrish does...
Oh, yeah... hey you yinzer!!! whereabouts in the steel city you from? There's two of us out here in the mon valley area... right around Kennywood to be more specific... I'm gonna be done with my first TLT soon, scale style, and my bud already has his first done, kinda comp style, and he's already gathering parts for his second...
bird is offline   Reply With Quote
Old 08-27-2006, 06:07 PM   #6
Ace
I bent up a Bronco frame rail (to the original Ford specs) and then cut down the middle with a metal cutting bandsaw to make two identical frame halfs.
Could be done with a hacksaw and a little time.
