Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Tools, and Procedures
Thread: Rate your tools!!! looking for a new hex driver set
Old 09-02-2006, 03:04 AM   #1
Default Rate your tools!!! looking for a new hex driver set
last month i bought a hobbico hex driver set because it was cheap and the pouch thingy was what i needed to keep track of my shiz, well two of the ball ends are already stripped. i had an RPM set that lasted me 8 years or so but i figured hobbico makes ok stuff right? anyways what do you guys use ?
peej410 is offline   Reply With Quote
Old 09-02-2006, 03:15 AM   #2
I've been using a brand called Wiha 7 piece metric set, from towerhobbies, so far so good. As far as the ball hex type, I got some from Snap-On tools, pretty expensive but worth it in the long run.
Kev808 is offline   Reply With Quote
Old 09-02-2006, 04:57 AM   #3
Bondhus hex drivers are the best, they also have a lifetime warranty. You can get them from MSC.
http://www1.mscdirect.com/CGI/NNSRIT...38269&PMT4NO=0
Tumbleweed is offline   Reply With Quote
Old 09-02-2006, 08:20 AM   #4
Link's Avatar
I have the same problem with the Hobbico set also
Link is offline   Reply With Quote
Old 09-02-2006, 08:39 AM   #5
I use similar stuff from the same company, Bondhus. They work great... Also, you can get them from Tower too: http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
Cake Eater is offline   Reply With Quote
Old 09-02-2006, 08:47 AM   #6
I have the AE set and the bit has held up very well. The handle could be a bit bigger but then again I have big mits.
FrankyRizzo is online now   Reply With Quote
Old 09-02-2006, 09:58 AM   #7
I use Crafstman allen wrenches, I also have a set of Metric and SAE ball end wrenches that I got fro Harbor Freight, and they have lasted a couple years.
TMXONR is offline   Reply With Quote
Old 09-02-2006, 09:59 AM   #8
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Wiha, Wiha, Wiha
JohnRobHolmes is offline   Reply With Quote
Old 09-02-2006, 12:56 PM   #9
CLODZIRRA's Avatar
mine are snap-on
CLODZIRRA is offline   Reply With Quote
Old 09-02-2006, 01:20 PM   #10
06 Super National Champ
JasonInAugusta's Avatar
The Wiha sets are nice, but the handles are too small for my taste.
Peter, you've seen my long tool set from Imex. They're great for working on the Revo. They're not cheap at $40 for 4 tools, but I use them all the time.
JasonInAugusta is offline   Reply With Quote
Old 09-02-2006, 03:11 PM   #11
Ace
Normally I think Snap on's are way overpriced but I've got a 3/32 allen driver that I've used steadly for about 20 years...
Ace is offline   Reply With Quote
Old 09-03-2006, 11:04 PM   #12
I have Snap-On screwdriver handle type. They didn't have a set, so I bought 2, 2.5, & 3mm. Kinda pricey about $8 apiece, but liffetime warranty.
redbeard is offline   Reply With Quote
Old 09-03-2006, 11:33 PM   #13
OCCUPY RCC!
dezfan's Avatar
I use the Bondhus drivers w/o any issues.
dezfan is online now   Reply With Quote
Old 09-04-2006, 12:16 AM   #14
I'm a stupid C U N T!
slobin3d's Avatar
hate to say it but i run a complete set of dynamite SAE and metric allens and they have outlasted my craftsman set by years they still look new. http://www.horizonhobby.com/Products...ProdID=DYN2904
http://www.horizonhobby.com/Products...ProdID=DYN2909
+ a 3mm and 5/32 sae $27 a set each
Plus you can get replacment tips if you do happen to break or strip one
slobin3d is offline   Reply With Quote
Old 09-04-2006, 02:01 PM   #15
any good name brand like all of these guys have mentioned. buy a high quality tool and it will be the last one you ever buy.
gregrocks90046 is offline   Reply With Quote
Old 09-04-2006, 02:15 PM   #16
I use Craftsmen all in one type thingys for out in the feild , but at home I use Dubro or Snapon.
CustomFabber13 is offline   Reply With Quote
Old 09-04-2006, 08:47 PM   #17
i think its snapon or craftsmen then !!!
Old 09-04-2006, 10:44 PM   #18
I've been using the DuraTrax Ultimate Drivers w/ replaceable tips that never need to be replaced
I've had this set for well over three years and they have never failed me. Perfect tips and the knurled girp is really the best thing about them.
I've tried the Integy tools and I can't hold onto them and have seen the tips break.
DuraTrax Ultimate are the best RC-based drivers I've used.
sicj is offline   Reply With Quote
Old 09-04-2006, 11:53 PM   #19
Axial Team Driver
Brandon's Avatar
Ive been using the integy allens for a while now, I love the handles and never broke a tip, if I did my lhs has a full line of spares So people must be breaking them lol.
Brandon is online now   Reply With Quote
Old 09-05-2006, 12:10 AM   #20
MWRCA'er
Mnster's Avatar
I have Hudy, Duratrax, Craftsmen and Integy. I like the Integy ones the best so far, they were the cheapest ones pricewise to. Well I did win the Hudys but thats different.
Hudy
Pro's
Big comfortable handle
great work bench tools
Long reach bits
Cons
screws that hold the bit to the handle loosen up.
To big and long takes up alot of space in the tool box
To long to fit in tight area's.
Bit section is very short not allowing for deep engagement
Duratrax
Pro's
Small comfortable
Tips are unbreakage
Affordable
Great to travel with
Cons
Cold to pickup
Tips like to tarnish
Integy
Pro's
Cheap and affordable
titanium coated tips
Small and comfortable
Color coded so you don't reach for the wrong wrench
Con's
to soon to tell
Craftsmen
Pro's
Ball driver
Awesome warrenty
Con's
Tiny low torque handle
crappy tips
Handle has a rubber grip insert that loosened up.
Mnster is offline   Reply With Quote
