Go Back   RCCrawler Forums > RCCrawler General Tech > Tools, and Procedures
Thread: Lets see your handmade tools!
Old 03-18-2013, 10:54 PM   #21
Pullman Crawler
A_Jeeper's Avatar
Default Re: Lets see your handmade tools!
Here are a few of the tools I made when I had accessed to a shop. I sure miss it..... If I still did I would be making all kinds of the parts I want. I really want to get more of my trusses made up.
A_Jeeper is offline   Reply With Quote
Old 03-19-2013, 01:53 PM   #22
Not even comparable to your tools, but here's my bender
richierm is offline   Reply With Quote
Old 03-19-2013, 02:24 PM   #23
looks like mine!
1tonscout is offline   Reply With Quote
Old 03-25-2013, 04:11 PM   #24
I've made bunches of tools and fixtures but these are just a few of my RC related tid bits that clutter my bench:
Yes basically it's an indicator base, I got the idea measuring stuff at work lol. This is just a quick and dirty not so accurate base ;) couple lock collars and a scrap chunk of steel. I've been using it with my scale to compare shock springs.
Made my own soldering jig because I couldn't stomach $30 for a store bought model. Actually comes in handy, more than I thought it would.
Assembly tool for EC3 plugs. I've got one for EC5s drawn up but haven't made it yet.
Broke down and bought myself a set if good hex drivers for my bench. Made an organizer with provisions for another chunk of plastic behind for the dynamite but drivers if I can ever afford them lol.
Sent from my iPhone using autocorrect
happymachinist is offline   Reply With Quote
Old 04-07-2013, 12:52 PM   #25
Here's a bender I made from 1/2" keystock and some mild steel.
Old 04-07-2013, 02:46 PM   #26
happymachinist,
What material did you use for the jig? Do you have a cad file you would be willing to share?
7echo is offline   Reply With Quote
Old 04-11-2013, 01:58 AM   #27
Originally Posted by 7echo View Post
happymachinist,
Had a random chunk of Teflon. I would have rather it been thicker (hence the legs) but it is what it is. PM me your email and I can hook you up with an autocad .dxf or .dwg.
Sorry it took so long to reply I've been busy busy.
Old 04-19-2013, 08:08 PM   #28
Could the tool be an electronics project? I just built a "device" that allows me to cycle electronic fuel injectors for a 1 or 5 second pulse, or with the flip of a switch it can cycle as long as I push the button.
BigSki is offline   Reply With Quote
Old 04-20-2013, 02:37 PM   #29
Lets see it
Old 04-23-2013, 07:48 AM   #30
Got my link bender somewhat complete this weekend. It's basic as of yet for bending solid links but I have provisions in the works for tubing.
Old 04-23-2013, 08:07 PM   #31
Is it set for one width, or are the bolts in the 2 top plates cam style?
Old 04-23-2013, 11:46 PM   #32
The wider plate towards the top of the picture has slotted holes to acomidate 1/16"-1/4" rod.
I plan on making a variety of rollers or handles based on what I need bent in the future.
Old 04-30-2013, 01:29 PM   #33
Defy Gravity
broke down and made a bender today. had all of the materials in the shop so why not. it's not a very flashy unit, but i won't have to make it again. used 5/8" steel plate for the base, 3/8" hardware for the bending pins (tapping that plate was a pain). some random stock for the arm, and some 5/8" aluminum rod around the main bolt as a spacer. forgive the crap welds on the arm pin, i haven't touched a welder in years, and stacking old rod and galvanized on top of that is just a mess. and the lock washer is just there for moral support, couldn't find anymore normal washers in my bolt bucket.
this is 3/16" tubing, i usually fill tube with packed salt to help with support, this was done empty, so not bad for me.
ghtpdm5 is offline   Reply With Quote
Old 05-10-2013, 11:38 AM   #34
Defy Gravity
i'll post this here too:
decided that i needed a new solder spool holder a couple days ago. had a sheet of .064 aluminum laying around and figured why the hell not. hand beat the bends (forgot how much easier a box and pan is) and then delrin spreaders. not esd safe (working on that part, got lazy, didn't want to cut 3/4" aluminum round stock), but it works better than the fishing box i was using. i may round the corners, but its a really comfortable thing to use.
one side is loaded with .062 kester water wash, and the other side is loaded with .020 kester no clean, both leaded. i keep the lead free separate, i rarely have myself spec lead free on projects.
EDIT: modified it for quicker spool changes.
Old 05-10-2013, 04:15 PM   #35
I like it.
I would round the corners...might save you from a scraped wrist.
Goatsniper is offline   Reply With Quote
Old 05-10-2013, 04:36 PM   #36
Defy Gravity
so far it hasn't been a problem with how i rest my arm on it, i probably will round them when i can get back to the shed.
Old 05-15-2013, 11:14 AM   #37
A simple tool to clean up revo or similar style rodends. I cut four grooves along the length of a revo ball end and simply screwed it to a piece of aluminum pipe. A minute or so in a hand drill and it completely frees the rod end and ball without changing the size of the socket.
SINister is offline   Reply With Quote
Old 05-15-2013, 10:58 PM   #38
Defy Gravity
a tool of sorts, old suryerer's tripod (5 dollars at the thrift store) and some spare aluminum rod, boom. nice camera tripod that actually works really well for about 10 bucks and some time. tuning the clamp screws to get it perfect took some time, cleaning, and blue loctite, but i saved money.
old point and shoot used for pictures, the brass adapter is uses standard 1/4"-20 threading for mounting
without the handle, it could get a bit touchy on pan and tilt, with the handle, dead smooth after a few adjustments. sometimes the best things are salvage parts and time.
Old 05-15-2013, 11:40 PM   #39
Very nice score on the tripod! FYI for everyone, almost all cameras use 1/4"-20 thread to mount.... in case you want to build your own mount.
KJ10 is offline   Reply With Quote
Old 05-16-2013, 03:16 PM   #40
Wife got me a new BBQ for our new place and I decided to buy some steaks to do on the grill. Realized I didn't have a tenderizer...
After work, spent a few minutes to write a program on the lathe and 20-30 mins on the Bridgeport spent squaring up the stock and figuring out the grooves, drill and tap the bottom an viola!
Nice weight to it, just under 2" square on the face. Other side is flat. Handle could be a little longer and larger diameter but it works.
mtdriver is offline   Reply With Quote
Lets see your handmade tools! - Similar Threads
Handmade CJ7 first run novianto Scale Videos! 9 01-15-2013 10:55 PM
Losi Micro Crawler handmade. Alex_Core Losi Micro-Rock Crawler 45 07-11-2012 08:28 PM
A handmade axe opek Chit Chat 9 04-24-2012 04:30 PM
